Do you have the newlec economy 7 water heater manual?
  • 417 Answers
SOURCE: heaters stopped working
It could be a faulty timeswitch on the E7 circuit.
Posted on Dec 02, 2008
  • 9 Answers
SOURCE: I need a user manual for a newlec storage heater
http://www.neweyandeyre.co.uk/pdf/276-310%20HVAC.pdf
It's not a users manual but you can get the number and call them for help.
Posted on Dec 04, 2009
  • 150 Answers
SOURCE: ECONOMY 7 METER & SYSTEM WONT SWITCH OFF AUTOMATIALLY
Your appliances will charge up no matter what time of day/night it is if they are turned on unless they are wired so as to only come on during Econ7. Usually this through a separate supply out of the meter to that part of the fuse box [split load type] or to a 2nd box supplying only those appliances. This area is your responsibility.
Try testing the power supply tails with a volt stick. It's a non-contact neon indicator about the size of a thick pen
If during Econ 7 period you appliances are using electricity at the higher [day] rate, - & it doesn't matter how they are wired in [see above] - call the power supplier. The meter belongs to them.& is their responsibility.
Maybe wise to check the meter readings at times both day & night with appliances both on & off
Posted on Dec 23, 2009
  • 3280 Answers
SOURCE: Hi 1 of my economy 7 heaters has stopped working
Hi in side the case on the left hand side there is a reset looks like a flat pieceof metal push this it will make a loud click this should reset heat , turn heater off first
Posted on Jan 21, 2010
SOURCE: i have just moved into
I think it is the same as the Horstmann Electronic 7 immersion heater timer. You can download it free from the Horstmann web site.
Posted on Mar 05, 2011
Newlec water heater
what is the model number?
May 22, 2013 | Dishwashers
Creda storage heater manual
I'm not a heating expert, but according to the information I could find, Economy 7 utilizes cheap electricty at night, during off-peak hours (7 hours) between midnight and 7AM. Economy 7 costs about 4p per unit compared to peak electricity, which is about 10 to 15p per unit. If you do not have Economy 7, you can request it FREE of charge from your electricity provider. You will either have one meter with two readings or two separate meters. A two tariff electric meter will record the electricity used during off peak times, so it can be billed, separately, at a lower rate. If you have two meters, one meter controls on peak daytime electricity and the other controls your night time economy 7 electricity.
I would need to know what model Creda heater you have installed in order to determine how energy efficient it may be. I also will need the model so I can determine operating instructions. If you need further assistance, please post back and let me know. I hope this helps.
Nov 15, 2011 | Heating & Cooling
I have just moved into my new apartment it as a newlec nle7 water heater with a timer, i can't get it to work, i need a user guide manual lisa
Dec 24, 2010 | Heating & Cooling
Newlec nle7 instruction manual
Struggling to get the timer sorted on the newlec nle7 to get regular hot water
Oct 28, 2010 | Kitchen Ranges
Jan 19, 2010 | Heating & Cooling
Economy 7 water heater prblem
If you are still getting power to the HW heater, more than likely the heating element has gone out.They can be easily changed from behind little panels on side of heater. Usually screw in.
Aug 20, 2009 | Water Heaters
Dec 25, 2008 | GE 3.2 cu. ft. Washer
Heating & Cooling Logo
301 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
