Question about Fisher and Paykel Fisher & Paykel Washer
My Aquasmart WL80T65D washing machine is telling me that it cannot lock the lid - but it is shut and appears to be in place.\r\n Does anyone have any suggestions for this?
  • pat_hanly Oct 10, 2010
    The LCD display says:
    "HELP! I can't lock the lid. Close the lid and press START."
    It beeps constantly
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Does the machine stop and beep and show an error code in the form of lights on or an error code in an LCD display?Please reply with additional information and I am sure I can help you rectify the fault.Looking forward to your reply.
Posted on Oct 10, 2010
WL80T65CW1. Why is it displaying fault 234 and will not cycle?
Replace just the lid lock assembly to start with and see how it goes. Lids are quite expensive and don't usually need replacing. You can always get a lid later if you still have problems.
Aug 25, 2015 | Fisher and Paykel Aquasmart wl80t65c
Simpson deluxe 526 stops at beginning of deep rinse cycle
fisher and paykel aquasmart model no. wl80t65d serial no.lyn686144
Aug 13, 2013 | Washing Machines
Aquasmart lid
Is the lid lock tang on lid broken.
2.9 Lid Lock
The Phase 7 Washer uses the same lid lock that is used on
the Phase 6 series 11 & 12 machines. The difference being is that the lid is now locked for the entire cycle. When the lid is locked the Lid Locked LED will illuminate. Once the spin
has completed, the lock will release and the lid can be
opened. To open the lid during the cycle the
START/PAUSE button must be pressed, the machine will
come to a halt, and the lid locked LED will extinguish.
If the lid is left open, the machine will be unable to lock the lid
and the cycle will be halted. The machine will play a tune
and the lid lock will flash until the lid is closed and START/PAUSE is pressed.
• If the lid-lock fails in the closed position, the locked lid can be forced upwards and out of the
lock. Note: This is the only time in which we would recommend doing this.
• If the harness is damaged, the complete lid lock assembly will need to be replaced.
If the power supply is cut during the spin cycle, the machine will keep the lid locked until the rotor has ceased to turn (3 to 10 secs). Only then will it release the lock. The motor is acting like a generator and allows the lock to stay energized under the bowls inertia.
Mar 16, 2013 | Fisher Paykel EcoSmart GWL15
What's your problem?hello i have a auqa smart washing machine WL80T65D and the service spanner comings up beeping continously. At the same time the sheet, delecate, and hight efficency buttons li
That is fault code 49,
But in AquaSmart machines the pump has shorted mosfets on the board and caused this to blow the fuse that controls the water valves.
49. (00110001) Cold Valve or Cold Valve & Hot Valve Faulty
The Motor Control Module has measured a voltage from the valve diagnostic circuit that
indicates the cold valve or both the cold and hot valve is faulty. The most likely cause is
that the valve harness has not been connected correctly or the valve(s) is open circuit.
Primary Source: Wiring.
Action: Check the valve harnesses are correctly fastened to the valves and
the motor control module or the pins are not bent backwards.
Secondary Source: Water Valves.
Action: Measure the resistance of the cold and hot valve coils.
Tertiary Source: Motor Control module.
Action: Replace the Motor Control module.
May 14, 2012 | Fisher and Paykel Washing Machines
Hitachi washing machine sf6500px washes ok but wont spin, digital signal says dE, does anyone know what that means please?
im not 100% on hitachi gear dont see alot where im from, but for most washing machines DE normally means the lid is open as they have small magnets in both the lid and frame of the washer, most machines will not begin to spin if the lid is not shut they will fill and wash but not spin purely as a safety precaution, if the lid is shut it means the lid (you may have a latch that actually locks the lid shut or just a reed switch magnet sensor that simply detects if its opened) reed switch or lid lock is broken or faulty normally pretty quick and easy to repair
Jan 18, 2011 | Sprint Hitachi P300 Cellular Phone
My aquasmart fisher and paykel washing machine flashes up with error 235 about 2 mins after starting
Sounds like the 'lid lock' has shorted out. They're not completely waterproof and have seen pins completely blown out inside them. Should measure 73 ohms (or very close to it) across the terminals. Hope this helps.
Jan 16, 2011 | Fisher and Paykel WL26CW1 Top Load Washer
Fisher and Paykel WL80T65D washing machine won't fill or spin
Hi just read your posting.Now when the red spanner light was flashing were there any other lights that were on.If there was then they will be in your cycle selection row.This row has 8 lights on it.Starting from left to right what lights were lit?Is it the 1st and 4th or the 3rd and 7th ---etc---?Please reply with additional information on the questions and I can help you rectify this problem.
Jul 10, 2010 | Fisher and Paykel Washing Machines
Washing Machines Logo
289 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
