Question about Fisher and Paykel Fisher&Paykel E522 Bottom Freezer Shallow Depth Refrigerator
I need to remove the doors from my E442B Fisher Paykel fridge. I managed the top door, how do i remove the bottom freezer door?
SOURCE: Fridge and Freezer losing cooling
we bought a f&p fridge freezer and in summer noticed it wasn't cooling and the freezer wasn't freezing, when the service guy came out he noticed our ducted air con was blowing onto the fridge, once we had redirected the air con outlet the fridge started working as normal, apparently f&p's work on air being convected around the cabinet of the fridge and air blowing on the fridge can effect the temperature of the convected air. hope this helps you or someone
Posted on Dec 10, 2007
SOURCE: Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
Posted on Sep 29, 2008
SOURCE: Fisher Paykel Fridge Freezer
I have a Fisher and Paykel E442B upside down, which is a very similar model, and I just fixed the same problem (temperature was around -4C even though I set the fridge temperature as warm as possible).
The cause of my problem was excessive ice build up on the side of the evaporator coil (which is in the back of the freezer compartment behind the rear plastic panel). I had the same problem around a year or so ago, so I expect it to be a regular occurence. To defrost the coil, I removed all the drawers in the freezer, and the plastic insert by pulling out the bottom of the panel out and rotating it upwards until it released at the top. There are a couple of snap-in tabs holding the panel in, so with a bit of pulling they released. The tabs are either side of the slot at the bottom of the panel.
I then supported the panel horizontally on the top shelf so that I didn't have to disconnect the thermostat wire and the circulating fan wire.
52de81a.jpg With a small fan heater set on low, aimed roughly at the ice buildup on the left hand side of the evaporator coil, I defrosted the ice built up. This took around 2 hours or so. Then put it all back together and it worked fine.
I'm not sure why the ice build up on the side caused the problem, but presumably it interferes with the proper flow of cold air to the fridge compartment.
If you don't seem to have ice build up like I did, then it could be a thermostat problem, or a fan problem (a symptom of which would be fridge being colder at the bottom than at the top).
Posted on Oct 04, 2008
SOURCE: Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model.  Mine was the fridge (not freezer) door handle ie. the upper door.  There are no small holes on the bottom of my fridge handle.  Working from the outer door edge, I gently prized loose the plastic trim located under the door.  I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door.  The trim will prevent you from using a conventional screw driver to tighten the screw.  I used a screw driver bit which is only 25mm long.  It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure.  Good luck.
Posted on Nov 15, 2008
SOURCE: top of fridge warm but bottom freezer working ok
there is also a fan in the freezer compartment which if broken will cause this problem. you need to check that both fans are working. please refer to other fridge posts here re repairing/ replacing the freezer fan- there is a document here which shows you exactly what you need to do. important thing is to switch off the appliance first and leave the freezer door open for about 20 minutes before attempting to remove the back cover ie let it warm up first, so that you don't break any of the panels.
Posted on Jan 05, 2009
How do i take the bins out of the freezer? fisher and paykell product no 20717 model E372B.
Text, manuals and videos.
[PDF]Installation instructions and User guide - Fisher & Paykel Appliances
https://www.fisherpaykel.com/.../838360b-nz-au-gb-ie-eu-ae-hk-sg-refrigerator-active...
Never freeze liquids in glass containers. Liquid expands during freezing, which may cause the container to explode. ?. ?. Never freeze carbonated drinks. They may explode. ?. ?. Do not consume food if it is too cold. Food removed from the freezer compartment may be cold enough to cause damage when brought into ...
[PDF]Refrigerator & Freezer - Fisher & Paykel Appliances
https://www.fisherpaykel.com/.../821187-nz-au-gb-ie-pac-refrigerator-freezer-guide.p... Food removed from the freezer compartment may be cold ... E372B. E381T. E402B. E411T. E415H. E406B. E413T. E440T. E442B. E521T. E522B. A inside height. 853 1255 1635 1255 1635 1475 1735 1465 1635 1735 1635 ..... The humidity lid seals the bins to provide a humid microclimate to extend storage times of fruits.
Page 41 of Fisher & Paykel Refrigerator E372B User Guide ...
kitchen.manualsonline.com > ... > Fisher & Paykel Refrigerator Permanently fixed bins and trays (Freezer drawer models only). The freezer bins and trays in this model are permanently fixed. They cannot be removed from the. freezer compartment. To clean simply wipe with a soft, damp cloth. On vacation/holiday.. Turn the ice maker to OFF on the internal control panel (refer to page ...
Page 25 of Fisher & Paykel Refrigerator E372B User Guide ...
kitchen.manualsonline.com > ... > Fisher & Paykel Refrigerator Remove all frozen food and wrap it in several layers of paper. Place food in the refrigerator. compartment or a cool environment e.g. insulated picnic bin. Switch the power off at the wall. The temperature control can remain at its normal setting. Remove the freezer baskets or shelves for ease of cleaning. Whilst defrosting ...
Fisher & Paykel E372B, E402B, E406B, E442B, E522B, RF522A ...
https://manualsdump.com/en/manuals/fisher-and-paykel-e442b...e372b/.../41 Fisher & Paykel E372B, E402B, E406B, E442B, E522B, RF522A, RF522W, RF540A, RF610A To remove trays or fixed bins, To replace trays or fixed bins:, Permanently fixed bins and trays (Freezer drawer models only), On vacation/holiday . To remove trays or fixed bins, To replace trays or fixed bins:, Permanently fixed bins ...
Refrigerators - Removing & Replacing The Drawer on Vimeo
? 2:35
https://vimeo.com > Fisher & Paykel Technical > Videos
Jun 29, 2012 - Uploaded by Fisher & Paykel Technical
This video shows the proper method for removing and replacing the drawer on Fisher & Paykel ...
Ice Storage Bin - Fisher & Paykel ActiveSmart E372B Installation ...
https://www.manualslib.com > ... > Installation instructions and user manual
Fisher & Paykel ActiveSmart E372B Manual Online: Ice Storage Bin. All models When going on vacation/holiday we recommend cleaning your ice bin and discarding...
[PDF]Fisher & Paykel RF522ADX5 519L French Door ... - Winning Appliances
https://www.winningappliances.com.au/.../Fisher---Paykel-RF522ADX5-519L-French... Note: non-Ice & Water models do not have an external water dispenser. Refrigerator French door and freezer drawer. Refrigerator door and freezer door .... 9. Installation instructions. Product dimensions (mm). E372B. RF372B. E402B. RF402B. E442B. RF442B. E522B. RF522B. A overall height of flat door product. 1620.
fisher & paykel e522b manual
https://sway.com/JxXqIwtViE8mDVwl Products 1 - 20 of 23 - Shop with confidence on eBay! Fisher & Paykel E372B, E402B, E406B, E442B, E522B, RF522A, RF522W, RF540A, RF610A To remove trays or fixed bins, To replace trays or fixed bins:, Permanently fixed bins and trays (Freezer drawer models only), On vacation/holiday . To remove trays or fixed bins, ...
fisher and paykell E372B remove freezer bins Google Search
Feb 18, 2018 | Fisher Refrigerators
How do i replace the heater defrost kit 821730p on a fysher paykel fridge freezer EB ?
its in the freezer compartment pull the back panel of in the freezer its self explainitory really.
Dec 12, 2014 | Fisher and Paykel Refrigerators
F&P fridge not cooling and the freezer is icing up model E442B it isn't flashing codes
Check fan by removing and connecting to a 12v dc source. Ensure 12v is available at the plug situated on the fan baffle plate. Allow ice to thaw on lower condenser before replacing fan (replacment fan if necessary) Fan must recirculate air to freeze contents of freezer.
Mar 06, 2010 | Fisher and Paykel Active Smart E522B...
Bottom of fridge section freezing, rest fine.
maybe fridge fan not working when door is closed could also be iced up air ducts between fridge and freezer
Oct 09, 2009 | Fisher Refrigerators
F&P E442b leaking from drain. Am i missing a evap tray????
Yes there should be a pan right next to compressor so heat from motor would cause it to evaporate.
You can just put a pan next to motor and strap it up
Feb 21, 2018 | Fisher and Paykel Active Smart E522B...
Top of fridge warm but bottom freezer working ok
Dear customer,
Please perform the following checks
Please rate this,. Thanks for using FIXYA.
Dec 16, 2008 | Fisher and Paykel Fisher Paykel 21768 -...
Fisher and Paykel Fisher&Paykel E522 Bottom Freezer Shallow Depth Refrigerator Logo
230 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
