Question about HP G60-235DX Notebook
Hard to explain i am wondering if you can replace the power board on a hp G60-235DX. and by power board i mean the one under the keyboard by the screen.
    Problem Solver:
  • 8 Answers
If it's similar to the Pavilion zd8000 that I have just had in pieces, then yes. I assume it is the panel with the power switch. I found one on ebay for about £10. Not currently one for your model, but keep looking. Lots of laptop breakers list all parts. Service manual for your model here
http://www.retrevo.com/support/HP-G60-235-Laptops-manual/id/23204dj578/t/2/
Gives dismantling instructions and part numbers.
Posted on Oct 10, 2010
Testimonial: "thank you sooo much i shall study this and hopfully be able the find and replace the part i need"
My customer explains that water got poured into her HP LaserJet 4200, now it won't power on, no display, no engine noise, nothing. I have replaced the large power supply on bottom, and the fuser,...
I have had this problem before and replacing the high voltage board ( that is the large board situated under the printer ) fixed it. However if you have replaced this board then I would agree that the water also took out the DC Controller Board.
The fuser probably did not need to be replaced.
May 26, 2011 | HP LaserJet 4200 Printer
I Need Help Unlocking My Hp Compaq 6910p Every Time I Turn It On A Blue Screen Pop Up And It Say POWER ON PASSWORD .... PLEASE ANYONE HELP ME UNLOCK MY LAPTOP!!!!
Unfortunately HP says: "If you forget the power-on password, the computer must be reset at an HP-certified repair center. Please contact HP to schedule a repair. The Drive Lock password cannot be reset. If you lose or forget the Drive Lock password, the hard drive must be replaced. Please contact HP to order a new hard drive. These services are not covered by the warranty."
Sep 13, 2010 | HP Compaq 6910p Notebook PC PC Notebook
How do I access the DC Power Jack on a Dell Latitude C510?
I assume you mean to replace it. You need to take all the screws out of the bottom,check under the battery too. Remove the hard drive,keyboard bezel keyboard, Remove all the screws under the keyboard except the cpu heat sink. Seperate the halfs & you should be able to remove the board. Now you can solder a new jack in. Good luck!
Mar 15, 2010 | Dell Latitude C510 Notebook
Not emptying and spinning
You may find it is hard let me explain kindly check whether proper power supply as been sent to the drain motor if power supply is ok means take the drain valve and give direct supply and check whether the valve is working fine if it is ok means the problem will be in main board of the machine kindly replace the main board
Jan 20, 2010 | Washing Machines
How do I install a replacement keyboard for my Dell Inspiron 6000 laptop?
Hi friend,
You need to open you keyboard then open your keyboard power lied from *********** board then put new power lied then close your keyboard. then restart your laptops
Dec 20, 2009 | Dell 0Y3740 Keyboard
My shift key will not work for all letters, forcing me to use caps lock by pressing it before typing the letter and immediately after typing the letter. any suggestions?
This can be either a bad keyboard or a bad system board. There's no way to tell without swapping out the keyboard. Laptop keyboards aren't hard to replace and cost about $50-60. If that does not resolve the problem, learn to live with it because a replacing the system board generally isn't worth the cost unless you have it covered under warranty.
Oct 13, 2009 | Computers & Internet
Help,please keep answer simple.
Clicking noises coming from a computer is generally a bad hard drive and must be replaced.
*However* the power going off may mean it is a fan that is bad and needs to be replaced.
Either way the laptop will require a replacement part, so take it to a computer repair shop and will be able to determine which it is fairly quickly.
Nov 11, 2007 | HP Pavilion ze5170 Notebook
Treo 650 keyboard not working
THere is a screw just under the antenna ( remove small rubber plug with a sharp knife) and the keyboard can be replaced although I had a similar problem and it was the ribbon not seated all the way into the holder.
Oct 05, 2006 | Palm Treo 650 Handheld
HP G60-235DX Notebook Logo
148 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
