Question about Dell Inspiron 2600 Notebook
Laptop doesn't power up. battery charge light flashes. no other light on.Dell Inspiron 2600. model PP04L
Kegtapper
  • 94 Answers
SOURCE: Dell latitude D600 battery charge light flashing
You have a ground fault issue in the DC JACK.
There are escentially 4 circuits in the jack and one is not making contact.
1: Negative Charge circuit (outter ring)
2: Negative Run circuit (outter ring)
3 Positive (Inner Ring)
4: Signal (center pin)
I believe the negative charge circuit (outter ring) is not making contact internally. Typically what happens on that model DC Jack is the tension contact metal becomes fatigued, and does not touch the outter ring.
This could come from Heat causing early fatigue of the metal.
Or normal wear, the metal has simply worn out from regular insert/removal.
Don't forget to rate suggestions
Posted on Apr 01, 2008
  • 629 Answers
SOURCE: Battery Charge light flashing 4 red one green Dell Inspiron 9200
usually, its an indication that the battery is nearing the end of its useful life. you can try to use another battery to isolate it further. If the same thing happens with another battery, chances are, the mobo is failing. Flashing the BIOS can usually help with battery issues. If another battery works fine and your computer is within its first year since you bought it, you can request a replacement battery from Dell
Posted on Mar 16, 2009
  • 130 Answers
SOURCE: Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Posted on Jun 21, 2009
SOURCE: Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
Dell inspiron 6000 laptop battery URL(UK shop): http://laptop-battery.org.uk/laptopbattery/1001074.htm
Dell inspiron 6000 battery URL(US store): http://www.cheap-laptop-batteries.com/laptop-battery/dell-inspiron-6000.htm
Dell inspiron 6000 battery URL(AU Buy): http://laptop-batteries.com.au/computer-battery/dell-inspiron-6000.htm
Posted on Jul 31, 2009
SOURCE: My Dell Inspiron 6400 battery is overheating and light is flashin
Hello I own a Dell Inspiron 6400, i guess what happened was that it must have overheated of so but its on the screen your system automatically powered off because it became warmer than expected. This may have been caused by:o) operating or storing the system in an environment where ambient temperature is too high or o) obstructing the air flow from the system fan vents. if this problem recurs please call dell support with error code #M1004. strike the f1 key to continue. f2 to run the setup utility pressf5 to run onboard diagnostics.
Posted on Aug 03, 2010
Dell Inspiron 5160 doesn't charge
you mite have fried the power supply. or the battery.. try removing the battery and pluging it in,and then power it up
Jun 13, 2012 | Dell Inspiron 5160 Notebook
I have a DELL Inspiron Mini. The power LED light is alternately flashing white and red. The netbook will not come on unless I have the power cord plugged in. When I do plug it in and power on, the...
This could indicate a bad battery. Try removing the battery and powering on the laptop. If the power LED remains white then you have a problem with the charging circuit. That means your battery could be defective or the battery charging circuit on your motherboard is faulty.
Feb 21, 2011 | Dell Inspiron Mini 10 Notebook
Inspiron 6000-flashing battery light
Since you said the battery is not charging, why don't you remove the battery and charge directly to see if your laptop adapter will charge your laptop. Because i for see your laptop adapter been bad that is why it is not charging your laptop.
If it did not, it means your laptop adapter is bad and will need to be replace in order to charge your laptop.
Just change the adapter as advice and your laptop will charge.
Take care.
Apr 19, 2010 | Dell Inspiron 6000 Notebook
The light for the battery charging on my inspiron 1300 Dell laptop is now flashing amber??
Means:
1. Your battery is low and needs charging which possably means you need a new battery.
2. A battery replacement is needed.
Dec 30, 2009 | Dell Inspiron 1300 Notebook
Dell Inspiron E1705 battery light flashes 4 amber lights, then 1 green. The battery seems to charge.
The ambar lights are warning you the battery is becoming to dead, it means in a short time, if it has not happens now, the battery won't retain the charge anymore, it is time thinking in a replacement if you use your laptop without plug in the power outlet.
Dec 29, 2009 | Dell Inspiron E1705 Notebook
Inspiron Battery Light Flashing Orange
Battery.
Dell has a chip internal to the battery programed to shut down after a certain number of charge cycles. This means every time you plug the laptop in with the battery installed. When it reaches this determined number the battery effectively shuts down, even though technically it's still good. There have been loads of complaints on the net toward Dell over this issue. I have myself experience this. Battery good one day, powered down, went home, powered up... only to receive the deadly flashing light. Only cure is to replace battery. Several hacks trying to get around this but they're all horrible. Bad Dell - bad, bad Dell!
Jun 29, 2009 | Dell Inspiron 6000 Notebook
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
Labtop not charging
Try removing the battery and see if the laptop powers on. If it still doesn’t power on then either the motherboard is defective or the AC adaptor may have a broken wire in the cable.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 03, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 2600 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
