Question about Hotpoint WMA74 Front Load Washer
Pumping water through soap draw - Hotpoint WMA74 Front Load Washer
    Problem Solver:
  • 10 Answers
Check filter is not blocked accessing it via the rear access panel. Also check no soap build up in downpipe restricting water flow. Hope this helps
Posted on Nov 02, 2010
Pav1000aww leaking during filling
not when its filling........pump is for emptying.......
if theres a soap draw........then there is a pipe from the draw to the tub.......it will be leaking from that pipe.....
cheers
Nov 20, 2016 | Washing Machines
Water is coming out of the drawer when in a cycle and leaking on the floor
g'day, water fills up drum via soap draw. this is how the soap mixes with water and enters the drum. U might need to check hose clumps and hoses that enter onto the back of draw (you'll need to access the top of machine when machine is unplugged). Also be sure to clean draw as soap can build up causing problems. Be sure draw is closing properly. Hope this helps. Let us know how u get on.
Aug 08, 2011 | Washing Machines
HI. My Comet FWS 4030 works just great and i am very pleased. what i DON'T know is how to draw up soap to mix with the water. there is a big red knob, and another brass adjustment but i have no manual...
The red knob is to regulate the pressure. The soap siphon should be hooked up to the pump at the high pressure outlet and the pressure hose hooks up to it. You do just have to drop the tube into your soap solution but I recommend you dilute the soap down as the siphon usually sucks the solution up fairly fast. The trick to making it work is to use the low pressure, soap tip on your wand. They are black and help fan the water/soap out but give no resistance to the water coming out. If you are using a high pressure tip, usually red, yellow, white or green, there will be too much back pressure in the hose and siphon attachment for it to **** up any solution.
May 18, 2011 | Comet GXD2527G Pressure Washer Pump
My pressure washer will not pump the soap, when you take the pipe loose from the handle it pumps out when you hook it back to the handle it quites pumping
Most pressure washers introduce soap into stream of water by the siphon method. In order for the system to siphon the pressure tip must be changed to one with large opening. Once the large tip is install, the fast moving low pressure water thru the hose and wand will draw-in soap. With the pressure tip installed soap will not be drawn-in. To spray soap and water under pressure use a large container (larger the better like clean 30 gallon trashcan) and fill with clean water and measure of liquid detergent. Use short water hose from with-in container and connect to pressure washer as normal. Keep checking water level so that washer will not run dry. Most pressue washers will **** water in quickly from container, however you can pre-fill the water hose with water to speed things up. Trailer mounted pressure washers use a very large container for water. You can estimate how log the pressure washer will take to use the water by checking the gallons per minute rating of your machine. Good luck
Sep 02, 2010 | Campbell Hausfeld PW2102 Gas Pressure...
WATER IS POURING OUT THE DISPENSER DRAW OF MY WF000G
Normally if you take the soap slide draw out,you will see a hole underneath where the slide draw was. It normally blocks up with undesolved soap. Clear the channel then retry.Or sometimes water pressure is to high and then tends to splash internally causing water to drip out. Also make sure the slide draw is cleaned properly..
Sep 21, 2009 | Washing Machines
My 2100 will not pull up the cleaner solution. Hose is not kinked, I have primed it, and nipple does not appear to be plugged.
THE DETERGENT HOSE USES THE VACUME FROM THE WATER MOVING THRU THE PUMP TO DRAW THE SOAP INTO THE PUMP.
CHECK THE AREA WHERE THE HOSE CONNECTS TO THE PUMP THERE SHOULD BE A SMALL BALL CHECK THAT MAY BE STUCK AND NOT LETTING THE VACUME PULL THE SOAP
Sep 16, 2009 | Campbell Hausfeld PW2102 Gas Pressure...
The motor works fine , no pressure out of hte hose, could it be the hose or pump, how do I trouble shoot. Also, how do I draw soap from a bottle to shoot out of the washer onto the house?
Since you did not mention the pump brand or type. I will just assume it to be a pressure washer, complete
with gun. The pump comes two suction hoses. One for the water supply and one for the soap bottle or pail There is pressure adjuster right at the pump near where the hose is connected. You can adjust to higher pressure by turning it clockwise. You can adjust the nozzle spray pattern by turning it. However, if your pump comes with only one set of suction hose. Then, it is designed to get the water
supply from the faucet with hose bib. The only one
set of hose is for the soap bottle or pail. It will **** the soap once the nozzle spray is opened.
hose,
Jun 30, 2009 | Plumbing
Ryobi 3000 psi pressure washer detergent injector
Most detergent injectors work by the venturi system. That is that the detergent is drawn into the stream by the forward flow of the water thru a very narrow port after the water passes thru the pump. This system works best when the pressure at the tip of the wand is low. Trying using a very large tip to draw in and apply the detergent, then remove injector and rinse with high pressure. Not good for the pump but to apply soap reliably under high pressure the soap needs to be injected through the intake of the pump. enjoy
Oct 13, 2008 | RTO 1800 PSI Pressure Washer
Troy bilt pressure washer 2200 psi
inlet valve connected to water inlet is stopped-up. Unscrew it, take a safety pin run through valve then take the pin and push through valve connected to pump. should do the trick. (the valve the suction hose for the soap is connect to)
Mar 31, 2008 | Washing Machines
Hotpoint WMA74 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
