Question about Panasonic KX-TG1033S Cordless Phone
Kx-tcd735 cant change pulse to tone. - Panasonic KX-TG1033S Cordless Phone
  • 3 Answers
SOURCE: pulse and tone
in GE:
TONE/PULSE DIALING
This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for
touch-tone use. To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Posted on Aug 09, 2008
SOURCE: changing from pulse to tone dial
All phones have a sliding switch either at the bottom or sides of the instrument. The same is marked with "P" & "T" on either side of the switch, meaning Pulse or Tone. Shift the sliding switch to T for Tone or vice-e-versa.
Posted on Dec 12, 2008
SOURCE: KX-TGA110FX
1.Press (ok)
2.Arrow down(twice) to "setting BS" then right
3. Input PIN code.Usualy 0000
4.Press "1"if you want TONE dialing or "2" for PULS
5.Press right arrow,then on/off button
Posted on Mar 12, 2009
SOURCE: Changing from Pulse dial to Tone
Go to Menu > Set tel line > Set dial mode > Tone. That should solve it.
Posted on Aug 08, 2009
Sijju
SOURCE: TO CHANGE PULSE MODE TO TONE MODE- INSTRUCTIONS ON
-Press "Program button"
-Press "AUTO" buttton (Just left to the "TALK ON/OFF")
-Press "*" two times
-Press "Program"
Along BEEP sound will come. That's all..!!
Posted on Feb 16, 2010
Changing from pulse to tone panasonic phone
Touch the following keys: Menu 0 5 1 and then select 1 (tone, the factory default) or 2. Then Save (a softkey with the label in the LCD screen) and Off (opposite Talk on the keypad).
The manual for the Panasonic KX-TG5664 is available from Panasonic here: http://service.us.panasonic.com/OPERMANPDF/KXTG5664.PDF . See page 17 for setting the Dialing mode.
I hope this helps.
Apr 06, 2013 | Panasonic Lands Phones
I nead manuals for my panasonic kx-tcd735
Thanks for visiting FixYa!
Click on the link provided below to download the user guide and operating instructions for your Panasonic KX TCD735. After you click on the link, a pop-up download box will appear in the upper right side of your screen. Select, Save and download it to your desktop.
Once downloaded, double click on the file to open it. It's in pdf format.
If you need a pdf reader, you can download Adobe reader free from the internet.
Click here to download the manual: http://downloads.devicemanuals.com/showfile.php?file=TDJGc2NHbHVaUzlQVFY5RFJFVXRPVGczTVZKU1gwNU1MbkJrWmc9PT0=
Feb 23, 2011 | Cell Phones
How do i change from tone to pulse on panasonic kx- tg6511 cordless phone
Try this.....Press menu....enter (# 1 2 0). Now select up or down key to get tone or pulse. Then select Save then off.
Nov 10, 2010 | Panasonic KX TG6511 Cordless Phone
Can you change the system from pulse to tone?
Yes. In system programming under trunk type, you can set it to pulse, tone, or call blocking. It's in the 401 section of programming in a TA series system.
Carl
Sep 22, 2010 | Panasonic KX-T7731 Corded Phone
Both phones have no dial tone and don't work - could it be because they don't support digital?
Hi, Welcome to FixYa.
The cordless phones supports pulse dialing than tone now a days.
If your provider supports pulse dialing & tone you can just change the tone to pulse to use cordless phone. Otherwise you have to request for pulse dialing from your provider.
We appreciate your feedback; it will help us improve this Web site.
Please select 'YES' if satisfied.
Jul 08, 2009 | Panasonic KX-TG2352 Cordless Phone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Is it possible to change from pulse into tone on Panasonic phone KX A145? I can't find this function on the phone. Does anyone know if it exists at all? Is there any general rule that may apply to all...
On this side of the pond, a KX-145 is a drum for a KX-F3000 fax machine with phone ! If that happens to be yours, under the * key, there's a stencil that says TONE. If you are trying to convert all calls to tone, then try the panasonic web site and look at the nameplate on the machine for whatever it happens to be.
If the search engine screwed up, then look to use the # key or a tone/pulse switch on the side of the phone.
Carl
Apr 11, 2009 | Lands Phones
Change pulse into tone
Go to the menu and choose Tel line and the go to set dial mode and then choose the dial mode like dial or pulse mode
Nov 22, 2008 | Panasonic KX-TG2631 Cordless Phone
TC1200 TONES/PULSES
There is usually a switch to change it from dial pulse to touch tone.If there is no switch check your user manual to see if there is a screen option.
tk46
Jun 19, 2008 | Panasonic KX-TG1033S Cordless Phone
May 26, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-TG1033S Cordless Phone Logo
91 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
