Question about HP LaserJet 2550L Printer
I have a HP Laserjet 2550L printer that has always worked well. Recently when printing the pages had lots of black dots on them. Now all the cartridge lights are flashing and nothing will print. Can anyone help?I would hate to replace it when there maybe a simple solution. I have asked FIXYA for help on another occasion for a Bosch Fridge-freezer and you were very helpful thanks guys!
  • nahmana_thap Oct 10, 2010
    This a colour printer however - should I still try changing the toner cartridge?
    It is a colour printer. Should I replace the toner cartridge. The problem is it was printing something but now nothing is coming -the power comes on as usual the rollers/paper feeders seem to be moving. The red light by the triangle flashes too but all the cartridge lights flash when I try to print.
    President:
  • 1,216 Answers
You should try checking your printer by replacing the cartridge to replace the print cartridge.
click here for instructions on how to do it.
This is a common issue with laser jet printer,
Try running cleaning modes under the service menu on the printer, run 5 back to back. if the issue is still showing, try using a different cartridge and run the cleaning mode again. If you have an old cartridge even if its close to being empty you can do an override on the printer to test the cartridge:
1.press ok
2.use the arrows and navigate to the system set up menu
3. press ok
4. print quality
5. press ok
6. override out
7.press ok and again ok to set
This could also be a build up of toner in the fuser assembly, and you may have to adjust the fuser temperatures in the embedded web server. You can print a blank word document (20 pages) and see if you still see black dots, if you do it is likely to be the fuser, set the driver and printer settings to card stock or heavy in order to heat the fuser more than the usual temp and print 30 blank pages this should resolve the issue. if this does not there could be damage to the ETB or the fuser assembly and servicing of the printer would be required.
take care,
REGARDS
Posted on Oct 10, 2010
    Genius:
  • 1,478 Answers
First, the fuser assembly may be damaged or at the end of its life. The solution is to replace the fuser assembly. Repairing a fuser assembly is generally not recommended because the fuser is considered a consumable printer part and not worth the time or effort to fix. Second, the toner cartridge may be defective and letting too much toner out at one time. In a black-and-white laser printer, the solution is to replace the toner cartridge.
Take care.
  • Jimoh Adeleke Muyideen Oct 10, 2010
    In a color laser printer, only replace the cartridge that is exhibiting the problem
Spots on paper
Does the pitch of the dots look like it could be caused by the pin wheels on the exit of the paper path?
If so it could be that the wheels have got knocked or sagged and are just touching the print as it exits the machine. Try gently prizing them up out of the way.
Nov 03, 2012 | HP LaserJet 2550L Printer
Did the Laserjet 2550L make duplex prints? if
It is called a manual duplexing option, the bottom rung of the duplexing ladder, you phisically have to take out the peice of paper after one side is printed, turn it over and reinsert it
http://www.retrevo.com/r/258bh050/38/Printing+on+both+sides+%28duplexing+manually%29#q=HP+2550L
Sep 09, 2009 | HP LaserJet 2550L Printer
HP 2550L printer
Theblack print cartridge is empty or missing. The black-print-cartridgelight is blinking, and then printer stops printing. An error 40208 iswritten to the event log. The printer cannot detect the print cartridgecorrectly. Action
  1. Reinsert or replace the print cartridge.
  2. If the print-cartridge light is still blinking but the Attention light is not on, turn the printer off, and then back on.
  3. If the problem continues, contact HP Customer Care at http://www.hp.com/support/clj2550 or see the flyer that came in the printer box for other contact information.
Mar 24, 2009 | HP LaserJet 2550L Printer
HP 2550L low yellow toner -- can i still print just black???
Unfortunately if one colour is out, then you cant print. These cartridges contain a chip and once depleted will not print until a new cartridges is installed
Dec 12, 2008 | HP LaserJet 2550L Printer
Still using color toner when printing in black
Check the black toner cartridge. Most printers that use multiple cartridges will use the black cartridge as long as it has toner in it but will then start using the color toner to do the black/grayscale when the black cartridge is empty.
-Graye-
Nov 21, 2008 | HP LaserJet 2550L Printer
Prints dark page
Try to change toner cartridge, I had this happen with my old laserjet 5, and it was a faulty cartridge on mine.
Aug 16, 2008 | HP LaserJet 2550L Printer
Printing problem
the problem exclusive between the drum or the fusser unit
Apr 25, 2008 | HP LaserJet 2550L Printer
HP 2550L Printing Problem
check to be sure you tool the strip out and that it's seated correctly
all the way down.
Dec 07, 2007 | HP LaserJet 2550L Printer
HP LaserJet 2550L Printer Logo
81 people viewed this question
Seeker5211
Seeker5211
