Question about Nokia 5630 XpressMusic Smartphone
Not getting battery full and easily low battery
Change ur charger use original nokia charger. Change also ur battery 5630 uses bl-4ct which only have 860mah u can use a bl-5ct which has 1050mah better battery life. Or u can order a bl-4ct battery from dyno online shop which is modified for bznes purposes it has a 1500mah like E-series
Posted on Feb 19, 2011
The computer is plugged in but we are getting a message that the battery is low.
How old is the battery that you are currently using?
It is possible that if the battery is old it may need replacing as it is no longer holding the charge.
Replacement Batteries can be obtained easily enough through the Internet.
I hope this helps you.
Jul 02, 2014 | Acer Aspire One PC Notebook
Canon PowerShot SX110 IS Digital Camera charge fully battery after one pics show low battery sign
This is probably a battery issue and not a camera issue. Batteries with low output or low power can be due to them sitting and not being used for long periods of time. This can affect their ability to get a full charge as their "memory" is reduced regardless of what the charge light indicator displays. Even taking a battery that has been sitting for a long period and charging it to full charge, might only have limited power. Some of these can be returned to almost full capacity, but it takes multiple, repeated, alternating, charges and power deletions to rebuild the memory. In many cases, however, the battery just needs to be replaced.
Feb 10, 2013 | Canon PowerShot SX110 IS Digital Camera
N 95 After a full recharge says battery Full in the night ,Cell phone seems switch off in Morning but try to open no results only reboot after plugging in to charger
try to change battery first.
some tips :
* proper way of charging your mobile must be turn off
* using your mobile while charging is not recommendable because this is the reason why battery is easily drain and it suddenly turns into low battery level.making a call and player music as well as video is also a factor of making the battery weak while on charge.
* might your phone end to a shorted or shortage mobile because of overcharging the phone...and for sure some of the internal components of the mobile might get damage...
please rate me if this solution helps...you can ask testimonial too... thanks
Jun 02, 2011 | Nokia N95 Cellular Phone
Nokia 1100 shows battery low even after full
your mobile battery is dull check battery first by using another mobile
Jan 18, 2010 | Nokia 1100
Atv not charging
stator or voltage regulator. are you riding with a space heater plugged in maybe?
Jan 14, 2010 | RTO 125cc Full Size Adult Quad ATV
2003 ACURA TL VEHICLE MAKES CKICKING SOUND WHEN KEY IS TURNED,
that pretty much sounds like a bad battery, next time its jumped, autozone or any other shop like that will usually test the battery for free. if you have a volt meter, measure the voltage on the battery with the vehicle on and off. vehicle running should have about 14.4 volts, and off 12.6 at a full charge. if there is low voltage at the battery after a full charge, its most likely the battery.
Oct 26, 2009 | 2003 Acura 3.2TL
Can't dial 1 and get voicemail
2 possibilities: -Wipe/clean key pad NO WATER,dirt dust moisture affecting key function -Low battery charge so reboot/Hold keys down till screen goes blank. Then removing battery clean contacts on battery itself and phone battery metal tabs carful they are very fragile break easily that happens phone will need to be replaced/refurbished etc.Full charge downside phone can't be used for awhile
Aug 07, 2009 | Motorola Mobility RAZR V3
Batery gone quickly in one call, eventually cut off
is your battery easily fully charge when you charge it? and easily went down after?? if yes, that migth be battery failure..
if not, there can be some shortage in your phone.
Mar 17, 2009 | Lands Phones
Seems to be electrical problem
What initiated the need for jump starting? Is the alternator charging? Has the battery been checked?
To check the alternator, once the engine has been jumped and is running, remove one of the battery post connections. If the engine dies, the alternator is not charging the battery, and the symptoms you describe are the on-board computer going through low voltage spasms until sufficient electrical power to operate the engine / tranny is drained and the car dies.
If the car continues to run with no battery attached, the alternator is charging - - - and I would recommend removing the battery and having it checked and (if good) recharged to full capacity. I would also recommend having it charged even if the alternator is the problem just to delay the onset of the low voltage problems. The car should operate normally for a few miles before the battery drains too low after a full recharge, enabling you to get it to a shop for alternator service / replacement.
If you attempt replacing the alternator yourself, make sure the battery is disconnected prior to starting the job. Saves blowing up good stuff by accidental short.
Hope this helps and good luck!
-WB.
Jun 12, 2008 | 2002 Mazda Tribute
Battery low
u have 2 chenj ur mobile's battry connector.
Mar 09, 2008 | Nokia 3230
Nokia 5630 XpressMusic Smartphone Logo
129 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
