Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
The audio on my Samsung TV does not work. I took it apart and checked the speakers, which work fine. I've tried using the remotes buttons, TV buttons, Pressing mute/un-mute, plugging in a DVD player to tryaudio on input/av1/av2, also I didn't mess with it for a couple months hoping it would magically work. What more possible resolutions or tricks are there to try? 42in., rear projection TV, silver, and it is a Samsung Model# : HCN4226W. The quicker i can get some help the better because I would hate throwing it away.... Thank You
5 Suggested Answers
SOURCE: Samsung HCN4226W 42 in. Rear Projection
My 5 year old Samsung HCN4226W is not coming on (no picture and no sound). When pressing the "ON" button, I can hear a "click" like it wants to come on, but nothing happens. HEL
Posted on Oct 12, 2008
  • 41 Answers
SOURCE: Samsung HL-r4264w 42 inch dlp projection - Component inputs
I have seen that sometimes the solder becomes loose on the input board. If you are under a warranty I would call and get someone to check it out.
Posted on Apr 19, 2009
  • 23 Answers
SOURCE: i have a samsung rear
You have a convergence problem. It is much easier to replace the whole module, than just the STK's, no soldering required..It is so easy to do and electronics skill level is not required.One screw and five connections(plug in) is all it takes.The part number you need to order is BP95-00142E convergence amp. I would google search it and find it at the lowest cost
Posted on Apr 20, 2009
SOURCE: Sound quit on Samsung rear projection TV
We solved the problem by purchasing a surround sound system and hooked it up to the Cable box thus bypassing the TV speakers. It was a cheaper fix than having a TV repair service guy come out and we have even better sound! Thanks anyway!
Posted on Jan 14, 2010
Samsung tv mute button is not cancelling tried to get volume back but cant get any sound
  1. On the TV remote, find and press the Menu button to enter the display for audio and video settings on the TV screen. ...
  2. Locate the Audio menu to turn the speakers on or off and select "on"
  3. Select "Fixed" in the Audio out section of the setup menu if available.
If this does not work add the model number to your post.
Sep 25, 2017 | Samsung Televison & Video
Samsung Model PPM42m6hb No Volume
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Aug 05, 2014 | Samsung Televison & Video
Vizio tv problems
Have you checked the TV without other devices connected to the TV.
Eg. disconnect any home theatre or speakers from the TV.
Verify with audio menu if the settngs of TV speakers is on or off ?
To adjust the audio settings:
1. Press the menu button on the remote. The on-screen menu
is displayed.
2. Use the arrow buttons on the remote to highlight audio and press ok. The AUDIO menu is displayed.
3. Use the arrow buttons to highlight the setting you wish to adjust, then press left/right arrow buttons to change the setting:
• TV speakers - Turns the built-in speakers on or off.
Lastly have you tried restoring the TV to factory default settings.
To restore the TV to its factory default settings:
1. Press the menu button on the remote. The on-screen menu is
2. Use the arrow buttons on the remote to highlight system
and press ok. The SYSTEM menu is displayed.
3. Highlight reset & admin and press ok. The RESET & ADMIN
menu is displayed.
4. Highlight reset TV to factory defaults and press ok.
5. If you have changed the default parental control passcode,
enter it now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults and clear all account information."
6. Highlight reset and press ok.
7. Wait for the TV to turn off. The TV will turn back on shortly
afterward and the Setup App will begin
Apr 29, 2014 | Televison & Video
I have a Samsung LE40B650T2 - no sound direct from the TV
It sounds that the sound processing section [digital circuts] are working well, and the fault must be either to the speakers, settings or to analogue audio amplifier section. Make sure that the Mute function is OFF. If it is OFF, and still you do not get audio output by tV speakers, surely the fault must be to audio amplifier circuits, provided speakers are OK. If your TV has a headphone out socket, this socket should also checked for proper interconnection.
Jun 24, 2012 | Samsung LE40B650T2 40 in. Full HD Crystal...
I have a Samsung sound bar Model HW-D450 which I purchased last week along with a Smart TV and Blu Ray DVD player. I think the thing is possessed. It is not compatible with the TV remote or the Comcast...
There is usually and option in the tvs audio menu to enable only an external speaker output. On the remote for the soundbar, at the very bottom-- there are buttons to fine tune the audio-video syncing
Aug 01, 2011 | Samsung Televison & Video
Max. VOLUME on Samsung TVs Too Low
Some models have a volume limit setting, check the MENU and look at the audio settings.
If this has external speakers use other speakers. If it has audio output connect them to a external amp and useing the remote adjust the volume. Check if audio settings are set to internal, external and fixed or vairable output.
Jan 09, 2009 | Samsung LN19A451C LCD TV
Samsung TV remote control
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Sep 28, 2007 | Samsung TV Remote Control
Remote not working
Sometimes dust is accumulated in tv remote receiver sensor. This will give you the malfunction. Because your statement says TV is about 8 yrs old. Better solution is make one general service. If you have remote checker check the TV original remote working or not. We say universal remote, sometimes even technical person does not know how to use. Because in each and every brand and model there is a secret code to initiate the version. So better make one general service and check in your original remote it is working.
Aug 24, 2007 | Emerson ET-20F7 19" TV
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
116 people viewed this question
Jerry Greenberg
Jerry Greenberg
