Question about HP Photosmart C6180 All-In-One InkJet Printer
Hp c6180 ink system failure error:0xc18a0206
  • 100 Answers
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures (0xc1....) the printer was having. A similar fix may apply to other printers. hp c6180 ink system failure - acca299.jpg
Posted on Nov 15, 2010
  • minpdx Jan 28, 2011
    This info has been so helpful along with this group of pictures:http://picasaweb.google.com/109215435720... The pictures show how to get to the logic board. Thank you for helping me fix my printer instead of turning it into a boat anchor!
2 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: HP Photosmart C6180 All- In- One Printer "ink system failure"
hELLO PLEASE TRY
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 13, 2010
Ink system failure
A Google search found this possible solution for you at HP:
Ink System Failure C6180 error 0xc18a0306
Jul 25, 2014 | HP Photosmart C6180 All-in-One Printer,...
0xc18a0206 error
ink system prime failure- the printer is no klonger able to hold pressure in the ink tubes- suggest you replace ALL PRINTHEADS in one go ( the problem may lie in just one printhead or the tubes themselves
If the prinhead replacemnet doesnt wotk then a new set of ink tubes and heads will be needed- this costs about the same as three new c6180 printers and is not worth the money- sorry for thew bad news
Jan 20, 2014 | HP Photosmart C6180 All-In-One InkJet...
I have an HP Photosmart C6180 i get error 0xc18a0206
Welcome to Fixya.
Here's how to resolve this issue :
HP Photosmart Reset
Basically, this error denotes "Ink System failure" and can be resolved by Printer reset. Follow the easy steps and you should be good to go.
Thanks for using Fixya.
Aug 20, 2011 | HP Photosmart C6180 All-In-One InkJet...
Ink System has failied. Error 0xc18a0206 on HP Photosmart 6180
Press *(star) and # (hash) together on the printer and let go.
Key 1 then2 then3
Press the right arrow key until the onscreen menu shows System Configuration
Press OK
Press right arrow key until failure status is displayed
OK again
I think there was another OK after this but not sure????
Keep pressing cancel til you get back to the main menu then
Unplug from power for 1 minute then plug back in
Power back on.
Mar 07, 2011 | HP Photosmart C6180 All-In-One InkJet...
I recieve Ink System failure error message with error code 0xc18a0206 on my HP PHOTOSMART C7180 ALL-IN-ONE PRINTER.
The error that you are having is a hardware issue, it means your printer has an Ink System Failure. Believe me, there's no use going through troubleshooting for this one. Call HP and just Upgrade your printer. HP Printer Tech Support would be more than happy in giving you discounts and an extra year of warranty for $1.00.
Feb 03, 2011 | HP Photosmart C7180 All-In-One InkJet...
I haven't used my HP Photosmart printer in awhile and now I'm getting a 0xc18a0206 error - I've tried taking out the ink cartridges, powering off, unplugging the usb cable etc. and I still get the error. ...
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fixed the on and off problem and also fixed the ink system failures the printer was having. A similar fix may apply to other HP printers. acca299.jpg
Jan 20, 2011 | HP Photosmart C6180 All-In-One InkJet...
0xc18a0401 ink system failure error on hp C6180 printer
Check out this link.
http://www.out-of-warranty.com/ink-system-failure-error-0xc18a-hp/
Apr 28, 2010 | HP Photosmart C6180 All-In-One InkJet...
Ink System Failure
below is to document that i want you to follow exactly inorder to resolve your issue..
CLICK HERE ==>> DOCUMENT
Please let me know the result after following the document.
thank you so much.
adonscott
Aug 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
1,302 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
