Question about Dualit 20247 2-Slice Toaster
The heating elements are giving out very weak heat and the toast is unevenly browned
ukvacfan
  • 328 Answers
SOURCE: The heating element doesn't work in two of the slots.
If its a Dualit model then you should be able to get it repaired. Generally replacing parts on a Dualit is not easy but spares are usually available thanks to the fact that its one of the most well known commercial toasters on the market. Google and see if there's a repairer in your area.
Posted on Apr 05, 2009
espressonist
  • 1711 Answers
SOURCE: Our 4-slice toaster (model 4cbc) is only toasting
Inside your toaster there are eight heating element plates six in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
Posted on Apr 02, 2010
Ned Luddd
  • 14 Answers
SOURCE: will not toast bread
needs new timer best price I have found, with instructions http://www.mcssl.com/store/electra-craft/catalog/product/522920765afa4d168f30d465bed95c1a
Posted on Jul 15, 2010
kalamazoo222
  • 285 Answers
SOURCE: After 20 years, the timer
Perhaps it is time to get a new toaster?
Posted on Dec 04, 2010
mnwarfield10
  • 452 Answers
SOURCE: RH end element was not heating to same
the new version has a plastic cover over element wires its best just to change all elements to solve this if you have had this toaster a wile the old elements dont have it,,,make sure its correct ones fitted as they are all different watts ..
Posted on Feb 23, 2011
How do i fix an oven that bakes unevenly
the cooking I can't help with, but the oven I can.
sounds to me like the bottom element or what controls it is not working. the reason the ones on top are cooking is that the top element is coming on and browning them on top after the heat has made the dow rise and cook.
so essentially everything is cooking from the top down. so when the temp drops its using the top element to heat with and thus browns the top rack.
check ur elements to make sure both work, if so, move on to the thermostat which I have to be the culprit many times.
Feb 26, 2015 | Ovens
Toast is dark on one side and white on the other
The heating element on the white side probably is burned out.
Dec 21, 2014 | Cuisinart Kitchen Appliances - Others
Black & Decker FC150R heating element needed
go to http://www.blackanddeckerappliances.com/
God bless you
Jun 22, 2012 | Applica Kitchen Appliances - Others
Just got 4 slice de longh iconai toaster and husband made toast last night in right hand side. No problem last night but this morning this side will not toast as the lever which one pushes down to keep...
I have no experience with the deLonghi toaster but in my experience automatic toaster all work in similar ways since they went electronic - toasters were about the first to do that.
Pressing the lever down against the spring pressure also presses an internal switch that sends current to the heating element as well as to the electronics that control an electromagnet, the purpose of which is to keep the mechanism engaged until the toast is brown enough and then the current to the magnet will be cut by the browning brain and the toast pops up.
If removing any crumbs from inside by inverting it and giving it a good shake and then pressing the lever a few times fairly vigorously doesn't make it work then nothing short of surgery will make it work so returning it will be the only realistic option.
Aug 22, 2017 | DeLonghi CTO4003 4Slice Toaster
RH end element was not heating to same temperature as middle element. Bought and fitted new end element but still same problem ie this new element still not heating to correct temperature high causing...
Feb 23, 2011 | Dualit Vario Combi 2+1 65-Slice Toaster
Toast cooks corrctly on one side and hardly at all on the oher. I have cleared all the crumbs out. It is the same whichever opening I use.
it means the other side has no heat to toast the bread!
The heating element might have been disconnected already, worst of all it is already burned!
try to contact the manufacturer to get the HEATiNG ELEMENT part or repair and replace the said part!
That'll solved ur probs!
Dec 01, 2010 | Prestige Appliances 50973 Toaster
In the upper oven, the lower heating element started sparking when turned on, and now it looks like it has a 'bubbled' area (about inch long) on it and it looks bent on one area. I guess I need to...
Hi, Yes, that element is toast...
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Sep 20, 2010 | GE JKP27 Electric Double Oven
The oven is heating up but not browning the food like it did. The upper heating element seems to be heating up, but not browning the food. How can I fix this?
Either replace the thermostat for the broiling element or try leaving the door part way open while you are trying to brown. This will allow the upper element to run hotter to get you to the browning stage that you are looking for.
John
Sep 28, 2009 | GE Spectra JBP78 Electric Kitchen Range
Dualit 20247 2-Slice Toaster Logo
88 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Herve Boissonnault
Herve Boissonnault
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
