Back to:
Tags:
Panasonic LF D311SC DVD-RAM/DVD-R Burner
Drive won't recognize discs
posted by BajaPaul on May 30, 2008
The drive will not recognize any disc that is inserted. I've replaced the drive with another of the exact same model, and I'm still having the problem. I'm running Windows 2000, Ver. 5.0, SP4. Is there a driver somewhere that may fix the issue?? Thanks!
Comment by BajaPaul, posted on Jun 04, 2008
The drive is a Panasonic DVD-RAM drive, and I'm using Panasonic 2~3x DVD-RAM double-sided discs.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 03, 2008
Thanks for Trying (70)
JBD73
Rank:Wiz Wiz
Rating: 75%, 23 votes
the blank media must be compatible with the burner drive that you're using... meaning if the drive is for CD-R you can only use CD-R blanks not CD+R. if the drive is CD-/+R then you can use either CD-R or CD+R
Comment by JBD73, posted on Jun 08, 2008
imho... if you use an exact drive model, the computer's response is the same as the previous setup, you use the same media on both drives you tested, drive can read other media...
* i would suggest to change media, try a single sided dvd, maybe a slower read/write media.. get the exact brand/model of the drive and search the internet for the compatible media for that drive
* try using other third party software to burn the disc
* make sure the os has the correct driver and drive is properly dectected
what else can i say.... good luck?
Rating Locked! (?) BajaPaul has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Drive won't recognize discs:
I don't want to Accept this solution
Solution #2
posted on Oct 08, 2008
Not Rated (0)
dgudahl
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
My Dell laptop just started having this problem also. I've never had any problems, but all of a sudden it won't recognize any disc that is put into it. Is there a solution without buying a new computer? DG
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Solution #3
posted on Sep 26, 2008
Not Rated (0)
justinandrep
Rating: 0%, 0 votes
Is your DVD drive supports Dual Layer? Because if you use a Dual Layer on your DVD burner that does not support DL's it has a big possibility that it won't work. Try a single layer, or if you want to still use DVD DL's I suggest buying a single CD/DVD DL drive. Preferably with Blue Ray capabilities. Technology is even expanding right now. Of course it will cost more, but I think that it will be worth it.
Thank You!
Can you Help with these CD and DVD Burners problems?
CD and DVD Burners
hi ive down loaded a firmware from the LG site as my...
CD and DVD Burners
Windows cannot load the device driver for DVD/CD-ROM...
CD and DVD Burners
My problem is that my long-term DVD R/RW drive,used...
CD and DVD Burners
i have lg mobile c2500 i dont now which software should i...
CD and DVD Burners
it has been acting strange for a while now it refuses to...
Loading problems.
Repair Service
Find CD and DVD Burner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
