Question about Jacques Lemans Watches
My model is 1-1245. I have already been carrying them for 2 years. I have bought them in Baku, Azerbaijan. I am in Vienna and my watches have already stopped for two days. May be you could help me to find any place to show it and to fix the problem. Many thanks in advance MD Vugar
  • 110 Answers
SOURCE: I impulsively bought a Swiss kinetic woman's watch
Please do not trust a person that is not experienced in replacing the capacitor. This is not a simple job like replaceing a battery in a quartz watch. I do this every day and like to use a good microscope to be sure of proper alignment of the insulator that goes between the battery and the strap. Don't let an inexperienced person screw up your nice watch
Posted on Dec 12, 2009
SOURCE: I just bought my wife a michele csx-36 watch. Its brand
that happened to me too...the watch repair man told me that I had the stop watch on. The stop watch should serve as a stop watch, not the second hand. The second time on your watch is the small dial at the bottom middle of the face. Once I turned off the stop watch feature, my battery life is fine...I have not had to change my battery in over 2 years now. HOpe this helps.
Posted on Feb 28, 2010
mcdevito75
  • 1970 Answers
SOURCE: battery? or can any jewlry/watch repair shop fix?
mcdevito75 here Best Bet, look for a small watch repair shop in yourarea, most likely you need a battery or even better, loosened the one already in the watch.
Posted on Jul 03, 2010
  • 2501 Answers
SOURCE: I need to fix a
If you go to http://www.diorhorlogerie.com/en and click on "find a boutique" and you will be able to find your nearest place who will be able to help you.
Unfortunately, Austria does not appear in their list, so you may have to choose between France or Italy!
Posted on Jan 05, 2011
watchandpen
  • 45 Answers
SOURCE: Watch stopped working 11 months
It is best to go to a watchmaker for this issue. If the battery was improperly installed, it can damage the movement or contacts, which will mean the movement must be replaced. We see this issue often. Another common problem is that the oils from the installer's fingers may be causing a bad connection if the battery and the contacts are not properly cleaned. We would use the Pulse test to see if the watch has current, if so, the movement is bad mechanically, it must be replaced. If it has no current, we would check and clean all connections and replace the battery. If there is still no current (using Pulse diagnostic) then the movement is bad and it must be replaced.
Posted on Jan 19, 2011
I bought it new and then a few weeks later the battery seemed to stop. I did not wear it often. I heard some watches do not use battery and function with the movement of one's arm. Is this the case for...
If the watch is a self winding type, then it generally says "automatic" on the face. These will run for about 2-3 days if they are not worn, as the self winding action only works when the user is moving).
Battery driven watches should run for at least a year before needing a replacement, so if it has stopped already, it could be self winding or manually wound type. Some self winding watches can be manually wound so you could try this to see if it starts.
Aug 14, 2010 | Watches
Hi - I bought a DKNY NY1304 watch three years ago, and unfortunately my digital screen just broke. I was wondering if it is possible to replace it with a new device? The only information given for the...
You have to speak to your nearest DKNY distributor - they might help you and carry out necessary repairs. Alternatively visit your nearest watch repair shop and ask if they can help.
Jul 31, 2010 | DKNY NY1304 Watch for Men
How long should a watch battery last? I bought my
It is hard to say how long a battery should last without knowing the details of the model.
If it is just a timepiece without any additional functions, then a battery should last at least one year and often will run for two or three.
If there are other functions e.g stop watch, back light, memory, alarm etc., then the life of the battery will depend upon the extent to which these functions are used. How long is a piece of string?
If you think that the battery failing, then take it back to the supplier and ask for a replacement, (if you have the receipt).
Mar 30, 2010 | Watches
Need to replace a Paul Jardin watch band
Catz, did you find the watchband. i'm also in the need for one. i think the watch repair techs dont carry that odd band
Mar 13, 2010 | Watches
I BOUGHT A CASIO WATCH A178WA-1AV CASUAL CLASSIC .I CANT GET CORRECT DAY SAT BUT MONTH AND DATE ARE OK 2-13. NO INFO IN MANUAL HOW TO ADJUST.
Hey makfloyd2
Sounds like you have set the year incorrectly. Continue as if setting the time as you already have done by holding top left button, then when screen flashes scroll with bottom left button and the watch scrolls in the following order - seconds, hour, mins, YEAR, month, day. Check that year is correct and also check the format of the month and date. In England our format is 10/2/10 which is 10th Feb 2010 (dd/mm/yyy), however some casio watches are in US format mm/dd/yyyy. So check this out too.
Hope this solves your problems
Kind Regards
Jim
Feb 13, 2010 | Watches
I just bought my wife a michele csx-36 watch. Its brand new. The watch runs for about one day then stops . What do you think it is. We did replace the battery already. Thanks
Dec 14, 2009 | Michele CSX Diamond watch
I just bought a Mondaine travel alarm pocket watch. Instructions say the crown has 3 positions. 1> Home normal for a quartz watch. 2> Pull out 1/2 way to set alarm. 3> Pull out all way to set time. My...
It seems like your watch has a little short stem and that's why it has only 2 positions. This does not affect battery in any way, nor the timekeeping.
The only downside of this is that you can accidentaly reset alarm time without knowing it as your watch crown is in permanent 1/2 way position.
If you are happy with that - keep your watch.
Dec 12, 2008 | Watches
Replacement watch batteries
When you buy your watch the manufacture puts in a battery that is made to last 5 years so that the watch can sit on the shelf and not need the battery changed before you have even bought it. Batteries you buy from a store or a watchrepair usually last about 1.5 years. Sometimes you can find a watchmaker who carries the five year batteries, but most people don't want to pay the $25-$30 to have it installed so most places won't carry them for rear they will never sell.I would also tell you NOT to buy your batteries from a grocery store or a Wallgreens type place because those batteries could have been sitting there for months, or even over a year. If you go to a watch repair they go through so many batteries that almost evey time you are getting a fresh battery.
Oct 21, 2008 | Watches
Watches Logo
141 people viewed this question
Top Jacques Lemans Watches Experts
Ansel Alberto
Ansel Alberto
Tom Chichester
Are you a Jacques Lemans Watch Expert? Answer questions, earn points and help others
