Question about Zoom X6 (5590) DSL Modem (55900003)
Status Light is red....can figure it out
I have checked my ethernet card and it works(my phone company says thats the prob). As far as I can tell, everything else is in order.
My net was working fine till recently. It will sometimes load FEW web pages SLOWLY or it will load none at all saying the server at blahblah website cant be found.
Ive tried all I could think of or that was suggested. Turning it off and back on(the 30 sec. thing), and even used the help part on my comps start button. Nothing seems to work. Please email me at Curseof111@hotmail.com
I had the same problem twice, once 1 month after i bought it, had to get an exchange item, and happened again last night, the power light is red which means service error, i cannot even communicate with it via 10.0.0.2, says unable to produce page or something. will be getting a different modem/router now...
Posted on Sep 02, 2008
2wire Modem blinking red dsl light problems. Tech came out and check out phone line, tried his own Ethernet router and still got the blinking red under DSL. Tech order for a port change on att company...
if the speed was upgraded to ADSL 2 you need ADSL filters that match this. Check the model number of the ADSL filters and check the type of DSL is compatible with the Speed change.
Apr 11, 2017 | 2wire (1000-000057-000) Modem
Hello i am having probelms with my Belkin g basic router it has wireless and it works but when i connect it to my computer it does not it says it can't find or something but if i plug in my other box that...
It's sounds like you're getting your cords mixed up. The modem (the box from your company that provides internet) needs it's power cord plugged in, a phone cord or a cable cord plugged in, and an ethernet (LAN) cord plugged into it. The power cord will plug into the wall obviously, the phone cord or cable cord will be coming out of the wall obviously, but the Ethernet (LAN) cord will plug into your computer or a router. A router in your case. So the Ethernet cord from your modem (box that came from you company that provides internet) will plug into the router in the specific slot that says Internet or Modem connection. Now you need another Ethernet cord to go from your router to your computer. Try to plug the cord that goes from the router to the computer into the 4 different ports on the router until one of them works, you'll have to give it about a min to check each one. If that doesn't fix it then you need to make sure your LAN card is being read correctly and installed correctly, best way to do this is to go to Start > Control Panel > Device Manager and look at Network Adapters. If there is a Red X next to a conenction, right+click the conenction and tell it to enable, or update drivers.
Dec 13, 2010 | Belkin (F5D7231-4) Wireless Router
Leviton Home Network Patch Panel Question
Unless your switch is very, very different from all the other switches I have used, simply connecting the ports to live systems is all you need to do. Have you tried this?
It may be that the patch panel is not wired, and that is kind of a pain.
Mar 01, 2017 | Leviton 5225WSP Switch and Outlet
Turned my ethernet adapter off on the upstairs one and back on to find that there is no green lights anymore, just a red light on status. Then did the same with the downstairs one and they both have a red...
Powerline adapters are generally not durable. You can try to reset the power adapter by pressing the reset button located on the device itself. If it still gives you a red light than call the manufacture and get it replaced.
Jul 15, 2010 | Powerline Ethernet Network Adapter
Headset does not flash red/blue so I can pair it with my phone
To get it into pairing mode (flashing red and blue) turn the headset off.  Hold the main button down until the light goes red and then off.  Then push and hold that same button and keep holding it even after the blue light comes on.  It will now go into pairing mode, flashing red and blue.  Set your cell phone to find it and it should work.
May 09, 2009 | Plantronics Discovery 925 Bluetooth...
I have 2 comtrend dh-10pf powerline adapters. one of the adapters status is a red flashing light and the AP light and the Ethernet light are blank. the second powerline adapter has a solid red status...
To start you need to factory reset both adapters,
plug them both into a wall socket next to each other, press the config/f reset button, hold in until ap light goes off, repeat on the other one.
Now you should have a red status light on both.
Press the config/f reset button on one for about 5 seconds, wait until ap light stays on, this one is now your access point (ap) that should be plugged in to your router when you have finished config.
Now press the ap adapter config button again for about 5 seconds until ap light flashes, then press the config button on the other adapter until ap light flashes, wait until they both stop flashing, wait a few seconds, the status light on both adapters should be green, and one adapter should have an amber ap light.
Hope this helps.
Jan 28, 2009 | Computers & Internet
How to connect Motoyuva W270 with PC for internet purpose?
Hi!
As far as i know, no one has checked out pc suites of other motorola mobiles i guess.As of now, no pc suites available.
As i use the same phone, its given in the manual that it supports only sandisk company micro SD memory cards to my horror.Somehow i got the fly mobile memory card working but this card doesn't work in other mobiles.The only way to get mp3 is to activate internet, GPRS and download songs.Else you got to use an adapter for the memory card, connect to pc, store info and go on with the mobile.You got no prob with connecting phone to pc or instead using an adapter for a memory card.
Both the same.
Anpother prob is that you will have a very low download speed through the internet.So, its better you connect memory card to the pc.
Jan 02, 2009 | Motorola Mobility Mobile PhoneTools 3.0...
PROBLEMS WITH MODEM
well.as far as i know, it really depends with what red light it is.if you're pertaining to the RED light for power, then it's an issue with your power adapter.make sure it's getting the right volts from your outlet.if this is already done, try to plug the modem in different outlets esp. your kitchen and bathroom outlets. if same thing occur,your modem might be defective.
for ethernet light, if it is red, just make sure that your cable is properly plugged in, if yes, unplug the other end of it from the back of your computer and plug it on the other port of your modem,(what we're trying to do here is making sure that your cable is working fine)..the ethernet light must be green if it's ok but if it wont change,replace the cable with a new internet cable. this should solve the prob.
if the DSL/broadband link light is red,there might be an outage on your area. most of the time, if this is red, the next light wont lit or red as well.
hope this is helpful.
Apr 26, 2008 | 2wire (1000-000057-000) Modem
Commtrend powerline ethernet adaptor
You can find out by clicking on Start, Run, type "cmd" hit enter, a black window will open, in that window type: ipconfig , hit enter, you should see 3 address's IP, DNS,Default Gateway. if not their could be other issues causeing the prob. or the hardware is faulty and needs replacement.
Nov 03, 2007 | Powerline Ethernet Network Adapter
Totally cannot run!
have you got your lan card drivers installed and is the windows firewall blocking connection as this can cause problems also check that the device is not being shutdown in windows newtork manager, if problem persists then get a converter to change lan to usb and install drivers for camera. good luck on connection.
Oct 03, 2006 | Axis Communications 2100 Network Camera
Zoom X6 (5590) DSL Modem (55900003) Logo
127 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
