Flashing "Burner On" green light - Glow Worm Boiler, Central Heathing off and no hot water
SOURCE: how do I relight the
How do you relight the pilot light on a rudd heating and air conditioner?
Posted on Sep 24, 2008
  • 30 Answers
SOURCE: bosch greenstar 30 CDi - no central heating or hot water!
it sounds like the system was not cleaned properly when the new boiler was fitted. all new boilers need to have the pipework flushed to remove any debris scale sludge and flux from the system. this is now usually done by a power flush which is basically a big pump mounted on a big bucket and it washes the dirt out of the pipework and collects in the bucket. if this is not done the dirt will block up the small passages in the heat exchanger. i suggest the system is cleaned flush and the heat exchanger changed to help protect the boiler a filter should be fitted (for example a magna clean) if the company who installed the boiler is corgi registered then they are liable for the damages. call corgi for advice.
Posted on Mar 26, 2009
  • 30 Answers
SOURCE: Vaillant combi boiler problem
when the tap is turned on and the water light on the boiler doesn't this means the diverter valve is not operating it could be down to low water pressure in the house this can be checked at the cold tap in the kitchen. if there is plenty of pressure then it could be the diagphram in the diverter valve is worn or split. the diagphram is only a few pounds but it depends on the engineer you get as to how much money he wants to fit it.
the egg timer symbol (or two pyramids together) is an ignition indicator turn off and on again to see if it will fire with the tap running. reset the boiler with the lower right hand control knob.
shastalaker7
  • 1515 Answers
SOURCE: Drayton Digistat SCR thermostat not working.
Go online to www.cheapboilers.com who deal with this type of boiler. It would be very difficult to troubleshoot this boiler with the information supplied. I hope this will be of some help to you.
Sincerely, Shastalaker7
They should also be able to get you a manual for your thermostat.
Posted on Oct 31, 2009
SOURCE: got a Alpha HE CB33
Problem is normally the hot water flow switch -
Posted on Jan 11, 2010
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Why does it take two bowls of water before water gets hot on combi boiler
The water isn't maintained hot (unless the central heating is on) in a combi boiler. you will, therefore have to turn the water on, which activates the burner. The burner will then have to heat up the heat-exchanger which then supplies the hot water through cold pipes. Once the pipes are warm, you will receive hot water.
Jan 29, 2015 | Water Water Heaters
Burner not quite right
You need to get an engineer urgently , there could be a flue problem , i would suggest shutting the boiler off until then
Jan 23, 2014 | Water Heaters
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
Glow worm 45 60 boiler
You have to have 12" clearance on all sides.
Apr 02, 2009 | Water Heaters
Honeywell T403A1174 suddenly doesn't appear to call for heat
some times inside the boiler on the internal pipework you will see little sensors, on the central heating piping there sometimes is a thermastic sensor on side of flow pipe with a little reset button on ? i guess with the problem you said the poiler locked out and the pipe work overheated ? this is a safety feature on some boilers not, all and easerly reset via this button ?
Jan 31, 2009 | Honeywell Water Heaters
How water problem
Your should be able to find the information here. Don't forget to check under discontinued products. www.glow-worm.co.uk
Dec 03, 2008 | Water Heaters
Glow worm combi boiler
check the pilot line for an obstruction. check the millivolt generator that's supposed to keep the pilot valve open. check for a high limit control being bad.
Dec 14, 2007 | Desa International GWP20T GLOWARM Wall...
Heating & Cooling Logo
132 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
