I want to set up my computer so that it may use a media center edition remote that come with the computer
    Genius:
  • 1,142 Answers
Follow step by step instructions
http://www.windowsreinstall.com/
Posted on May 30, 2008
HP TSGH-IR02 Remote Control how to install
This document pertains to HP Media Center computers with Windows XP, Media Center Edition.Use this document when the remote control does not work correctly with the Media Center software.Troubleshooting the remote controlUse the following items to troubleshoot when the remote control does not respond or when the remote control does not work properly. For example, when a key is pressed the selection moves all the way to the top or bottom of a list, or moves a selection many different places instead of the item you were trying to select.Before attempting these steps, make sure that PC has been updated with all of the latest Windows updates. Many updates for Media Center, like Update Rollup 1 for eHome Infrared Receiver, can be downloaded easily through the Windows Update software Tool.
Make sure that the batteries for the remote control are installed correctly and charged.Make sure that the front of the remote sensor is unobstructed, within a 45-degree range, and is less than 26 feet (8 meters) away. Disconnect all devices that use a USB connection except to the receiver, keyboard, and mouse. Restart the PC, and then try the remote again.If a pressed button repeats itself (sticks), unplug the IR receiver from its USB connection, wait one minute, and plug in the IR receiver. If the pressed buttons continue to repeat, alter the lighting conditions in the room or move the location of the IR receiver. Other remotes and HP Media Center PCs within range can also cause this issue.Try pressing the Enter key on the remote after changing a channel.If the remote control works when using the media center software, but does not work when changing the television channels, re-configure the Media Center software settings for the cable set-top box or satellite receiver
Point the remote control towards the IR receiver and press a button. A faint red light should appear on the IR receiver. If the light appears, then the problem is probably in the software that is using the remote control (most likely the configuration of the Media Center software). Close the software, restart the computer, and then re-open the software to solve this issue.
Troubleshooting the IR receiverThe IR receiver is the small device that receives the signals sent by the remote control. Use the following steps to test and reset the IR receiver.Disconnect the IR receiver from its USB port on the computer, maximize the Media Center window if it is open, and then reconnect the IR receiver. Test again.Point the remote control towards the IR receiver and press a button. A faint red light should appear on the IR receiver. If the light appears, then the problem is probably in the software that is using the IR receiver (most likely the Media Center software). Close the software, restart the computer, and then re-open the software to solve this issue.Click Start , right-click My Computer , and then select Properties .Click the Hardware tab and then click the Device Manager button.Click the plus sign next to Universal Serial Bus Controllers.If the eHome Infrared Receiver is listed under Universal Serial Bus controllers, Windows is properly detecting the IR receiver. If eHome Infrared Receiver is not in the list, or there is an exclamation mark or a question mark on the device, perform the following until eHome Infrared Receiver appears correct in Device manager:Unplug the end of the USB cable on the IR receiver from the computer and plug it into the same USB port.Plug the end of the USB cable on the IR receiver into the front USB port on the computer.Disconnect all other USB devices, leave the IR receiver plugged in, and then restart the computer. Plug in other USB devices after the IR receiver shows up in device manager.Figure 1: IR receiver listing in Device Manager
Testing the remote controlUse the following steps to check the responsiveness of the remote control:
  1. Open the Media Center software by double-clicking the Media Center icon the desktop or by pressing the green Start button on the remote control.
  2. Click Settings , and then click General .
  3. Click Check Your Remote , and then click Next .
  4. Press the numbers on your remote control. The corresponding numbers on the numbers on the screen should glow when each button is pressed. A faint red light should also glow inside the IR receiver each time a button on the remote pressed.
  5. Click My control is working properly , and then click Next . Do not click I am having problems with my remote control as this will not do anything.
  6. Click Finish after you are done.
Dec 17, 2011 | HP Computers & Internet
Xbox set up
If you have an Xbox 360 connected to a home network that also has a Windows Media Center, you can add your Xbox 360 as a Media Center Extender device so that you can enjoy the digital media on your Windows Media Center computer by using Xbox 360. For more information, see Xbox 360 online.
1. Turn on your Windows Media Center computer and log on to Windows. Verify that your computer is connected to your home network.
2. Turn on your Xbox 360 and verify that it is connected to your home network.
3. In Windows Media Center, on the start screen, scroll to Tasks, and then click add extender.
4. On the Welcome to Windows Media Center Extender Setup screen in Windows Media Center, click Next.
5. Press the Green Start button blank.gif on your Xbox 360 remote control or use your Xbox 360 controller to select the media blade.
6. On your Xbox 360, select Media Center.
7. On your Xbox 360, follow the instructions on the screen to obtain an 8-digit Windows Media Center Setup Key. Write down this 8-digit setup key. This is the key that you will use to affiliate your Xbox 360 with your computer that has Windows Media Center.
You do not need to download any additional software because the Extender functionality is built into Windows Media Center.
8. On the Enter the Setup Key screen in Windows Media Center, use the Windows Media Center remote control or keyboard to enter the 8-digit setup key that displays on Xbox 360, and then click Next.
9. Follow the steps in Extender Setup.
Several changes are automatically made to your Windows Media Center computer during the Extender Setup, including changes to the Windows Firewall settings. For more information about Windows Firewall, see Windows Firewall: recommended links. During this time, the Windows Media Center Extender service (which is named mcx2svc) starts on your computer, along with other dependent services.
If you have a firewall running on your computer that is not the Windows Firewall, make sure that the firewall software is set up to allow Xbox 360 to connect to your Windows Media Center computer as a Windows Media Center Extender. Some firewalls are already set up to allow Xbox 360 to connect to a Windows Media Center computer as a Media Center Extender. However, other firewalls will require you to make changes to how the firewall software is set up. For more information about which firewalls are already set up to allow a Media Center Extender connection, as well as information about how to set up other firewalls to work with a Windows Media Center Extender such as Xbox 360, go to the Firewalls and Media Center Extender article on the Microsoft website.
10. After Extender Setup has finished, in Windows Media Center, click Finish.
On the TV that is connected to Xbox 360, the Windows Media Center user interface appears. You can then enjoy live TV, recorded TV, pictures, music, videos, and other digital media on your Xbox 360 as you would in Windows Media Center. A new user account named mcx1 (by default) is automatically created to use the Extender.
Please see http://windowshelp.microsoft.com/Windows/en-US/Help/8076aff3-16ec-4751-9f57-d36e0ff407201033.mspx#EPD for more info.
Thanks and hope that helps!
Les
Dec 23, 2007 | Microsoft Xbox 360 Console
We have windows xp media center 2005 purchased in 2006-7 and I wasn't paying attention to our Help and Solution page until one day I saw that it said the Professional not the Media Center how can I change...
Hi There,
Windows Media Center Edition is exactly that; an "Edition" of XP Pro. If you go to My Computer and then click on System Properties, you will likely be comforted to see that you indeed have Windows Media Center Edition 2005.
Regards
Jul 13, 2010 | Microsoft Windows XP Media Center Edition...
Rebooted Microsoft Windows XP Media Center Edition and now media center gone
Click Start>All Programs>Accessories>Media Center>Media Center. That should get you going again.
Do you not have a Media Center remote for your computer?
Thanks for using Fixya.
Nov 29, 2009 | Microsoft Windows XP Media Center Edition...
My laptop responds to tv remote
you can turn off the IR on the laptop or put black tape over it!
Sep 19, 2009 | Microsoft Windows XP Media Center Edition...
Reset computer microsoft windows xp madia center edition 2005 pc
When we are restarting computer we can install media center edition 2005.
Jun 02, 2009 | Microsoft Windows XP Media Center Edition...
Media center doesn t start with remote
you have to install the media centers remote software
Apr 11, 2009 | Microsoft Windows XP Media Center Edition...
Xbox 360-computer?
To connect the Xbox 360 console to this computer, you must be running Windows XP Service Pack 2, Update Rollup 2 for Windows XP Media Center Edition 2005, or Windows Vista.
To obtain your setup package or instructions for connecting your Xbox 360, select the version of Windows installed on this computer from the following list.
To determine the version of Windows XP Media Center Edition that you are running, follow these steps:
  1. Start Media Center.
  2. On the Settings menu, click General.
  3. Scroll down, and then click About Media Center.
  4. Click Software Version
    The version number of Media Center you are running is displayed.
To determine the version of Windows XP that you are running, follow these steps:
  1. On the Start menu, right-click My Computer, and then click Properties.
  2. On the General tab, under System, look for the version of Windows that you are running.
Oct 05, 2008 | Microsoft Xbox 360 Console
Xp audio driver for fujitsu amilo
Downloads results for AMILO La 1703 CLICK HERE FOR AUDIO DRIVER
CLICK HERE FOR SUPPORT PAGE AND ALL THE DRIVERS
VT8237A imbedded / VT1708A codec(HD ADeck's default setting changed)
Title: VT8237A imbedded / VT1708A codec(HD ADeck's default setting changed) Date: 04.10.2006 Size: 7,17 MB Version: 5.10.01.1080 Manufacturer: VIA Technologies Status: Released for AMILO La 1703 Language: all.gif Supports all languages Operating systems: [Supported] Windows XP
[UnSupported] Windows XP Media Center Edition (WHQL)
Minimize up.gif Use in the following products: minus.jpg AMILO La 1703
Jul 03, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
