Can somebody help me? I need a service manual for my EIKI LC-XB23. Thanks.
  • 4,737 Answers
Here it is (click here), it's a pdf file, you'll need a pdf reader like adobe reader to open the fine on your computer.
click here to download adobe reader
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Oct 10, 2010
The projector shuts off after running 60-90 seconds
The air flow might be clogged. This is REAL common on projectors and before replacing anything, you should make sure it is clean inside.
Oct 15, 2014 | Eiki LC-XB23 Projector
Eiki LC-XB23 Projector vertical bands top to bottom of screen
almost sure 1 or more lcd panels are defective
sorry, but than it is end of life for this projector.
May 20, 2012 | Eiki LC-XB23 Projector
Need driver for LC-XB23
driver for what ? for rs 232 ?
Apr 07, 2012 | Eiki LC-XB23 Projector
My data projector eiki LC-Xb23 goes off without warning and the warning light is flashing
If the power light & warning light both flash red, this indicates that the projector is overheating. Once the projector has cooled down the warning light would continue to flash red and the power light would be solid red.
You should clean the air filters.
The filters are located on the underside. Disconnect all cables and invert. remove the 2 air filters located at the front and rear by pullingthe latches. They are both rectangular in shape.
Being very careful not to damage them, you should rinse the dust out and leave them to dry fully before replacing them in the projector.
This should cure the problem.
Feb 17, 2011 | Eiki LC-XB23 XGA LCD Projector Multimedia...
How do I get the eiki to turn on?
HI
PLEASE CHECK KEY PAD IF NOT WORKING SOMEBODY LOCKED .TRY WITH REMOTE .IT SHUOLD WORKED
M.R.CORPORATION MUMBAI -DUBAI
Aug 27, 2010 | Eiki LC-XE10 Projector Multimedia...
I do not know how to use Eiki LC-300
The operation manual is at this addres (http://www.eiki.com/docs/owners-manuals/lc-300_owner-manual_2000-06-05_en_na.pdf?sfvrsn=14). It is a PDF & very easy to download. If you need any other help, write back.
Oct 14, 2008 | Eiki Projector lamp Projector Lamp for...
EIKI LC-XG210
I t may be a dust or somebody before you tried to clean it and didn't make optical adjustement.Its very tricky to disasembly and if you want service manual conntact me at sanjinbosna@yahoo.com
Feb 16, 2008 | Eiki LC-XG210 Projector Multimedia...
Won't power up
Hi, The owners manual says that if the red light is flashing, it is an indicator that it is ready to be turned on (use remote or onboard on button); flashing red & green - too high temperature inside, the unit is overheated. Check and clean the air filters; If the red light is steady, abnormal condition and you have to call for service. A copy of your manual is available at http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_xb25_20_sb20.pdf Hope this be of some help. Pls post again how things turn up. good luck and kind regards.
Jul 31, 2007 | Eiki LC-SB20 Projector Multimedia...
48 people viewed this question
jasbo
jasbo
