Question about Vizio P2 42 in. HD-Ready Plasma Television
My Vizio P42 HDTV has a glitch. I have absolutely no issues turning it on/off, or watching movies on my DVD player through the HDMI input. The problem is that when I turn the TV off, sometimes, when I come back to watch local channel (using my digital antenna and coax cable, it won't see any inputs at all. Before, if I turned it on and off a few times, it would work, but now it's to the point that it's not recognizing any input from the DTV cable. I have great picture/sound with HDMI cable and movies, but can't watch local show. Please advise.
  • 520 Answers
SOURCE: connecting antenna cable and cable from cable company
Use an A-B switch.
Posted on Jun 26, 2008
SOURCE: Vizio P42 HDTV no picture
My P42 has same problem. Factory says it is the power supply to vidio.. They want me to pay someone to remove it. Then they want $162.00 to repair it (no new ones available). Looks like a 3 or 4 hundred dollar problem.
Gee maybe I'll run down to Costco and buy another Vizio, Right.
Posted on Oct 21, 2008
  • 31 Answers
SOURCE: No picture...but there is sound
still in warranty ? take back to store . anyplace in the video section may go including screen hope you bought a service contract take my advice on Serv Contract. get one ! also Vizio does not have too many techs as well Sams Manuals for Vizio available for techs.
Posted on Apr 26, 2009
  • 8457 Answers
SOURCE: hdmi on vizio hdtv input says not support
Ur board is shorted it cost alot to replace the board for just the HDMI port to use.Must change the board or use the S-Video port.
Posted on Aug 17, 2009
SOURCE: Indoor antenna problem with Magnavox LCD TV Model 15MF605T/17
I have found most of these indoor antennae to be ineffective and a waste of money, however, I do not know anything about this particular antennae. I to have a Dish DTVpal, which I love! It's ugly and probably won't fit in your kitchen, but the best solution is to make your own "bow-tie" antennae, mount it indoors or on the roof and run a cable to the kitchen. Directions can be found on You-Tube. I live in SE Idaho (Pocatello) and can get 13 channels, most without having to adjust the antennae.
Posted on Feb 26, 2010
How do I set my Vizio tv up so it will let me watch movies on a Sony DVDs player
Assuming the DVD player has an HDMI port, run an HDMI cable from the DVD player to an available HDMI port on the TV. Let's say you have your TV service going to HDMI #1 on the TV, you can run the DVD to HDMI #2. When you want to watch a DVD, you must select the input/source on the TV remote to change it to HDMI 2(or whichever port you used). When ready to watch TV again, use the same button to change back to HDMI 1 (or whichever HDMI port you used for TV service). If you do not have an HDMI port on the DVD player, then you must use whatever type of connection it has and connect to the corresponding port(s) on your tv, Then follow same directions as above regarding choosing the input/source on the TV remote.
Dec 02, 2017 | Sony Televison & Video
Vizio tv - plays fine and in color. hooked up phillips dvd player - all connectors connected correctly. when i play the dvd, it is only in black and white . . . not color. how can i get my dvd to play...
Which input on the TV and which output on the DVD player are you using? HDMI is the best and easiest. Next is standard video plus audio (3 leads, yellow - video, red and white - audio). If you are using the component input, you can get B&W if you have the leads incorrectly connected. If you're going from component to video in, you might have the same result, I'm not certain. I hope this helps you resolve your problem. Let us know.
Mar 23, 2014 | Vizio E601I-A3 60-inch Class Razor LED...
How do you connect the dvd so you can watch a movie?
be sure you have selected the proper input on your TV; looks like you have an option of 2 HDMI inputs on the back or 1 on the side; or 2 component inputs on the back
Nov 28, 2013 | LG 42LG30 42 in. LCD HDTV
Where do to plug in the cord to connect the tv to the DVD player?
Hello
You have several options for connecting your DVD player to your GV42L FHDTV10A - HDMI,
Component, S-Video and Composite (AV) inputs. Based on your home theater configuration, you can
decide which option is the right one for you.
connected to the HDMI input of the VIZIO GV42L FHDTV10A for optimal results.
To maintain the display quality, use a VIZIO certified HDMI cable available up to 10 meters or less.
1. Turn off the power to the LCD HDTV and DVD player.
2. Connect a HDMI cable to the HDMI output of your DVD player and the other end to the HDMI
Input (white color area) at the rear of the LCD HDTV.
3. Turn on the power to the LCD HDTV and your DVD player.
4. Select HDMI using the INPUT button on the remote or side of the LCD HDTV, or directly by
pressing the HDMI button on the Remote Control.
a) If you are already using the HDMI 1 input for another component, or you do not want to use
the HDMI 1 input for the DVD player, you can connect the DVD player to the HDMI 2
connection.
b) Refer to your DVD player user manual for more information about the video output
requirements of the product.
OK
Apr 24, 2011 | Vizio 42 in. LCD TV
I HAVE A VIZIO LCD TV AND WHEN WATCHING ANYTHING THROUGH THE hdmi INPUTS LIKE BLUERAYS THE SOUND GOES STATICY AFTER 30 MINS. AND TO RESET IT I CHANGE THE IMPUT CHANGES THEN BACK AND THEN ITS FIXED. WHAT...
This problem happen to all the HDMI inputs?Only one HDMI input,that one properally is shorted.Might even the HDMI cable is old,and worn out.U have about 6 HDMI inputs on ur tv,rent about 3 DVDs movies and watches test out all ur HDMI ports out.
Mar 25, 2010 | Vizio VW42LF 42 in. LCD HDTV
Hdmi on vizio hdtv input says not support
Aug 17, 2009 | Vizio VW22L 22 in. LCD HDTV
Sound is okay watching tv on hdtv - but crackles with dvd playing
If your DVD player supports HDMI or OPTICAL / DIGITAL audio then I would take a look at swapping to those type of connection first. This would help eliminate bad cords / connectors / electrical interference from other sources
Your TV has two hdmi inputs and optical so you have a choice
Aug 08, 2009 | Vizio GV42L 42 in. LCD Television
Screen goes yellow, fades, then NO SIGNAL
try using an alternate input source like a dvd or game console and see if you can duplicate the problem. then call vizio support and describe your problem. a lot of vizio parts have lifetime warranties on certain parts and a free service call to change out parts.
could have an issue with main board that has hdmi input. if you have 2 hdmi inputs on the TV, try the alternate input, too. vizio has had some issues with main boards. have worked on them for 3 years. hope this helps.
Apr 07, 2009 | Vizio VX32LHDTV10A 32 in. LCD HDTV
Vizio L32 32 in. HDTV LCD HDMI input not working
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
May 14, 2008 | Vizio L32 32 in. LCD HDTV
Vizio P2 42 in. HD-Ready Plasma Television Logo
271 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
