Question about Quantum Fireball Lct15 (QML20000LC-A) 20 GB Hard Drive
Sir, my hard drive Quantum 20GB fell down in my hand now when I connect with computer it did not show. Please tell me How I can recover my Data.
ginko
  • 19396 Answers
SOURCE: hard disk data recovery
In effect the reading head is almost for sure damaged and there is no easy DIY way to recovery data at home.
If the content is really important you can send it to a company who does data recovery. Service is expensive and probably it is going to cost over $1000, furthermore they do not guarantee success.
This company does hard disk data recovery
Alternatively you can ask to a local repair shop to take a chance , get an Hard disk of same model and replace the disk. I warn you that chance of success working in this last way are very scarce and there is good possibilities that you lose your data forever
regards
Posted on Mar 11, 2008
  • 265 Answers
SOURCE: USB port broken in 1TB seagate Freeagent external hard drive
Yes you can just take the hard drive out of the case, can use it with any other case, you can also just put it inside your computer and connect it to the sata cable :)
Heres a case you could use for your drive... Click Here
Please rate
Many thanks
Posted on Feb 20, 2009
  • 13433 Answers
SOURCE: Does the Intel 82801 chipset recognize the full
Yes it should recognize such small drive. Note that the partitions on the drive will affect how big drives are shown.
If the drive is partitioned into two 10GB parts then you should have C: 10GB and D: 10GB
Note that if the drive is partitioned not to use the full capasity then the capasity it is partitioned to will be shown instead.
Also Note that computer hard drives the capasity is not accurate presentation of the GB available. it will always be somewhat less than the reported size, for example 1000GB disk is shown as 931.50GB
500GB disk is shown as 465.76GB and so on.
see picture:
Posted on Jul 29, 2009
  • 1752 Answers
SOURCE: How to recover data from a faulty hard drive
Go to OnTrack.Com, they're pretty good.
Posted on Dec 03, 2009
  • 14 Answers
SOURCE: how to recover data from corrupted hard drive?
Hi, liub97.
In your case, it is recommended to use this data recovery tool to recover as much data as possible. If you are Mac OS X user, go to this Mac hard drive recovery software.
Then follow the procedure to reformat your corrupted hard drive. Mycomputer -> Computer Management -> Storage-> Disk Management . Note: you can also opt for a third-party formatting tool.
Things are not over, after formatting, retry the program to see if more data can be recovered as you know a simple format option won't erase data permanently.
Best regards.
Posted on Nov 17, 2011
I have a Maxtor 20GB Hard Disk which when connected to a computer the BIOS is able to read it but the problem is the HD only shows ZERO GB(its empty).Can this problem be fixed in order to make it show 20GB...
Computer sees the drive. That is important. I'm assuming this uses a standard IDE cable and the drive isn't physically damaged. Make sure it is the only drive connected and it is the Master. Try flipping the cable if you have checked that the connection has a snug fit. Put the connector that you had the hard drive originally on and place it on the motherboard and the connection that the motherboard had insert it in the hard drive.Or better yet try a new cable. IDE cables have a tendency to fail. You could also try some recovery software. Maxtor is now part of Seagate so you can try here:
http://www.seagate.com/support/downloads/
If you absolutely have to get data off this drive and you are desperate, then you could try the freezer trick. Put a dry towel and hard drive in the freezer for an hour or 2. Take the hard drive out and wrap it with the cold dry towel. That is to try and minimize any condensation build up. Plug in the hard drive and see if it works. This could potentially kill the hard drive but I have recovered data using this method before. If this works for you do not depend on this drive anymore. Good luck.
Feb 11, 2014 | Compaq Evo D500 PC Desktop
I/O device error
Hard drives are easily damaged beyond repair by dropping them on the floor.
There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.
Feb 24, 2013 | Western Digital 1TB My Passport Essential...
I have a FreeAgent 1 TB external hard drive. It worked fine for over an year. And it just fell down from a table and since then the drive is not recognized. I can see it under device manager, but do not...
You could try to use file recovery tools like File Scavenger or similar. If at fall moment Hard Drive was ON, then there is bigger chance that information will be unrecoverable because of damage of Hard Drive disc surface. If data is very important like work data (MS Office files and so on) I would suggest to hand this item to local data recovery center. It might be costly but if data is essential then no doubt it is worth to try.
Aug 24, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My WD800 hardrive fell down and now its not
Try connecting it to some other computer, and see if you can retrieve it. Also try a different OS too if it does not work.
May 17, 2010 | Western Digital External USB 2.0 80 GB...
Dear sir, i have a wd1600xmsb external usb. it fell flat on it's bottom on top of my cpu (about 1-1/2 ft. high). my computer cannot recognize it, but it's blue led light lits when it's plugged to the usb...
your disk motor is stuck and not turning the disks from being compressed from the fall. you will need to take it to a computer shop that agrees before they work on it they will be able to save your data. tell them exactly what happened
Dec 27, 2009 | Western Digital External USB 2.0 80 GB...
I am looking for a Quantum Fireball 20.5 GB hard
The board alone is not available for sale. To recover the data you will need to buy a 20GB Fireball with same board and swap the control board.
You can buy a 20.GB Fireballl QMP20000AS-A from links below:
QUANTUM QMP20000AS-A - Buy Now at Cuetech, Inc.
QMP20000AS-A DELL 20GB 3.5" IDE 7.2K HARD DRIVE
Quantum QMP20000AS-A Fireball Plus 2 QUANTUM FIREBALL PLUS AS 20GB HARD DRIVE QMP20000AS-A -
Oct 22, 2009 | Quantum Fireball Plus AS (QMP20000AS-A)...
Hard disk data recovery from a bad sector
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Jun 30, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Data recovery from corrupt external hard drive
download and install R-studio ntfs this run r-studio ntfs then locate drive in screen then scan drive It will take awhile to scan once scanned you may open the scanned drive let it search for all files to be recovered then just place a tick by the files or folders to be recovered then click recover then select destination folder then click the appropiat button and wait for allfiles or folders to be recovered.
good luck
Jun 28, 2008 | Western Digital Caviar WD2500BB 250 GB...
System not detecting hard disk
is that a sata drive or ata?...if ata, try to change the IDE Cable that connected to your Hard drive?..
Feb 26, 2008 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Slave Drive not recog in my computer but it is disk management with no drive letter
A quick thing to try Is
remove the 80gb from ide cable and power plug and set the 20gb back as master.
boot into windows from 20gb 1 time ,
then shut down hook the 20gb as a slave and the 80 back up as master
Allow windows to find new hardware , "watch closely down by clock ". It will tell you when windows has finished and will say you might need to reboot before new hardware will work properly
After rebooting Both should show inside My computer
Good Luck I hope this helps
Nov 14, 2007 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Quantum Fireball Lct15 (QML20000LC-A) 20 GB Hard Drive Logo
236 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
