Question about Sanyo SR-4912M
What is the part number for the evaporator plate? because i accedently punctured the plate while cleaning it?
    President:
  • 1,891 Answers
Cant help you with the part # but i would try to repair it rather than replace it . there is a epoxy kit for refrigerators . about 10 to 12.00 dollars, and if the hole is not too large most repairs do work . you will have to vacuum the system and replace the gas . . the repair will be by far easer than replaacing the plate. hope this idea will help you . mm
Posted on Oct 10, 2010
IF REFRIGERATOR EVAPORATOR/CHAMBER PUNCTURED SO WHAT IS THE SOLUTION OF THIS PROBLEM?
99% of the time a punctured evaporator is a bucket job unless your appliance has been designed in such a way that it can be replaced providing the system has not become contaminated due to air entering the system.
Sorry to be the bearer of bad news.
Ian
Aug 22, 2015 | Refrigerators
I need to know the correct part name or number so i can order it. Punctured the coil inside of the fridge. Its the white thin metal plate hooked inside at the top. I think it serves as the freezer section...
The coil inside the freezer is the evaporator coil. You probally need a refrigerant technician to properly install and charge your refrigerator.
Aug 23, 2010 | Refrigerators
How do I clean air vents in 2000 Toyota Camry
If your talking about the a/c and heater vents basically put a vacuum cleaner in front of them. The same holds for blower motor intake ports. First clean debris from under wipers by hand then vacuum.
Lastly the a/c evaporator hose should be drain and cleaned. basically get under vehicle with eye protection and use a tongue depressor to clear the hose of debris. Be careful cold water will pour out and be gentle with deopressor no need to go deep into hose you can puncture evaporator. Thats big money$$$$$$.
Jul 14, 2010 | 2000 Toyota Camry
I DID CHIP ICE AWAY CAN IT BE FIXED
If you punctured the evaporator coil, causing a loss of refrigerant, then no practical repair is possible on a compact.
If only part of the cooling coil(evaporator) is frosting over with the remaining part not active, then the system either has a small refrigerant leak or the refrigerant system has developed an internal restriction, and is not a cost effective repair.
Note: If the coil was not punctured and the unit is under 5 years old you should have warranty on it.
*If that is the case, air dry the machine with power disconnected and door left open. Restart, with control set at normal, close door and recheck in 24 hours. If coil is only partially frosted, contact Sears with model number and any paper work you have. They usually keep records on potential in warranty equipment.
Oct 30, 2009 | Kenmore 91365 Compact Refrigerator
Punctured evaporator on my Sanyo SR-2570 fixable?
Unless you know someone that can replace the evaporator and regas this unit very cheap as it's a major job, I'd say it's alot cheaper to buy a new one. cheers
Oct 30, 2009 | Sanyo SR-2570 2.5CF Mid-Size Dorm...
Need freon recharge. punctures freezer coil in
You punctured the aluminum evaporator . In the many years I've been in refrigeration , I have yet to find any way to patch a hole in the evaporator . I've used epoxy , solder , and all different advertised ways to try to patch aluminum . Nothing worked ( for long anyway ) . My suggestion would be to buy another refrig . You will be wasting time and money trying to " fix " this problem . To repair it yourself , you have to have a license to buy R12 , maybe you can buy R134A without a license , you have to look on the " modell , serial number tak to see which it uses and how much to use . Also , the system has to evacuated ( all air removed from the lines ) . Do you have a vacuum pump ? You have to buy a solder on connector ( or saddle valve which WILL leak eventually unless you get a solder on valve ) which will connect to the larger tubing on the compressor or use the access line already on the compressor but is pinched off . Do you have guages for the refrigerant type you need to use ? Once you have these things , reply back and myself or someone else will help you procede .
Aug 19, 2009 | Refrigerators
I HAVE A HOLE IN THE REFRIG.LINE OF A HAIER MO.HC125FVS
Hi, unfortunate, sorry to hear that, but it could be repaired, you should immediately dried up water/ice around punctured area, prevent water/ moisture entering punctured area (evaporator. lines), it's one of the worst thing, that could happened to any refrigeration system, it will be costly to repaired, if water get into your evaporator lines, compressor oil have to be replaced, evaporator will need to be flush out, repair puncture, change filter drier, it's better to replace compressor, vacuum system for about 2hrs. then recharge. it's better to use welding/ soldering, to repair punctured line, epoxy repair kit can be used to repair punctured (evaporator) lines . you will have to call a mechanic, if very little water entered punctured( evaporator) lines, then flushing of evaporator, (internal cleaning of lines (tube) changing of filter drier, with overnight vacuuming will do the job. take note, job like this, cannot be guaranteed. check cost for repairs, sometimes it's better to purchase a new one, and save yourself some headaches.next time never use sharp instruments in your freezer, it happened to me sometimes, it's what you get your hands on, what's available at the moment, good luck.
Aug 15, 2009 | Haier HC125FVS Wine Cooler Beverage Cooler
Re: Sanyo SR4310W mini fridge freezer plate broken
Ok, I know I should not have done this but I did. I was impatient with the defrosting and stabbed my Sanyo SR3770s' evaporator with my Smith and Wesson switch blade knife. A very tiny hole, made a swooshing noise and now the fridge won't get cold. Can this be repaired for a minimal price? Perhaps just replacing the evaporator plate and reinstalling some freon, maybe, hopefully?
Let me know. Basically a brand new unit, hate to see it go to the dump!
Sandra
Jul 20, 2009 | Sanyo SR-4310 Compact Refrigerator
HELP - I punctured the Evaporator coil - is it junk now?
i will give u an experience
if u can see that tiny puncture then u can fix it.
how? well take a 100 grit sand paper and slowly rough the punctured hole on the side of the hole approx 1 inch around it.clean it with a clean cloth. next take some petroleum ether soak a tissue in ththat and with the ether moist towel wipe the area and the hole nicely .now buy fro the market aluminium epoxy tubes. mix a little bit of the epoxy in a i:1 rratio and apply a coating of this stuff on and around the just cleaned hole.After about 12 hours the puncture is repaired now dont touch it.
Take the fridge to a professional refrigerant filling person who has experience in filling gas. he will vacuum the system and remove any ingress of moisture and then begin filling gas. your fridge will be good as new after this job
Jan 11, 2009 | GE Refrigerators
Beer dispencer brewmaster Model#HBF05E
If you punctured the evaporator plate, you will need to replace the entire plate, which means brazing a new one in, evacuating the unit, and replacing the refrigerant charge. If you can't defrost the coil, unplugging it with the door open, would work much better than chipping at it.
Jul 03, 2008 | Haier (HBF05EAVS) Beverage Dispenser
Sanyo SR-4912M Logo
107 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
Steve
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
