Question about KitchenAid KEMC308 Electric Double Oven
Panel says "close door' when door is closed. How to replace door latch, which is apparently defective?
  • 1 more comment
  • hjellen1 Oct 10, 2010
    True, but they sell only the whole assembly, which I would have to buy in order to get the switch. my question is how to replace the latch, how to get to it. Do I have to take off the front of the oven, the part containing the door gasket?
  • hjellen1 Oct 13, 2010
    The switch itself does not appear to be available as a separate part, but only as part of the motorized door latch assembly. Even if I could buy it separately, it is located several inches inside the vent space between the upper & lower oven. There is no apparent way to unscrew the switch from the assembly without removing the entire assembly to gain access to the screws. And there is no obvious way to remove the assembly from the very restrictive space.
    Ii have two experts working with me on the same question. Maybe I did something wrong by posting the question twice. Now what do I do?
  • 11,896 Answers
That would likely be a faulty door switch. Remove two screws to remove the swich. Then pull the two wires from the switch and replace the switch.
Posted on Oct 10, 2010
Testimonial: "Not the question I asked. Plus, they don't sell the switch separately, only the entire door latch assembly. I couldn't see how to install it. "
  • 2,973 Answers
It may not be the latch. It could be a small micro switch that gets pressed when you close the door. This switch may be defective. Needs a change.
Testimonial: "That solution would have been helpful if I had not already thought of it. It was correct. I had to come up with a way myself to test the switch. "
  • hjellen1 Oct 19, 2010
    This is what I finally did. I removed the plastic vent cover that is in between the upper
Whirlpool TXFE366LVQ. When I turn selfclean after few minutes it shuts itself off and displays code F5E2
An F5 error code indicates that you need to check the oven door or the latching switch. The switch is used when cleaning the oven, for safe closure. If you find that the door or the latch switch do not function, you may need to replace them
F5-E2 means latch during clean error; the door and latch switch need checking and possible replacement.
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Hope helps.
Jul 14, 2011 | Ovens
F5 E1 error. Oven door won't open after running cleaning cycle
1.
If door latched:
    step C.
  4. Re-apply power.
    step C.
5. If
6. If failure
Note:
Applies to all F5-E... codes.
F5 - E1
Feb 21, 2011 | Whirlpool RBS275PD Electric Single Oven
F5 error door locked
F5
- E0 Door switches do not agree (condition
exists when door switch is closed indicating an open door, and latch switch is
closed indicating a locked door) 1. If door latched:
    step C.
  4. Re-apply power.
    step C.
5. If
6. If failure
Note:
Dec 27, 2010 | Whirlpool RBD275PD Electric Double Oven
Error code F5EO
F5
    step C.
  4. Re-apply power.
    step C.
5. If
6. If failure
Note:
Dec 19, 2010 | KitchenAid KEBC107 Electric Single Oven
E1 -F5- Error code appears when attempting to start self-cleaning mode.
F5
- E1 Self clean latch will not
lock
1.
If door latched:
    step C.
  4. Re-apply power.
    step C.
5. If
6. If failure
Note:
Dec 04, 2010 | Whirlpool RBS275PD Electric Single Oven
We have a wall mounte singe maytag oven. When I go to set the oven temp. the panel reads"door" and I am unable to set it. I have opened/closed the door and put the lock lever on and off, but to no avail....
Hello there:
Here is all of the possible error codes for the door and what they mean and what to look at
DOOR Bake or Broil
· Defective latch switch
· Shorted wire from ERC 10-pin connector, pin 10 to ground
· Door latched Replace latch switch if defective.Replace wire from 10-pin connector if defective DOOR Self-Clean
· Open wire from ERC 10-pin connector, pin 10 to ground
· Door not latched Replace latch switch if defective.Replace wire from 10-pin connector if defective LOCK Not in Self-Clean
· Oven temperature sensor resistance too high Check oven temperature sensor resistance, wire harness and connections, replace defective component
Sep 28, 2010 | Maytag MEW6527DDS Electric Single Oven
I have a Whirlpool stove (model# RF385PXE)and I tried to start the self clean oven cycle the letters "door" appeared along with "E1" and "F5". The door is closed all the way. I even tried pushing it closed...
HI. This code is an indicating that the Self clean latch will not lock. Lock mechanism failure. follow the procedure below to address further.
1. If door latched:
A. Disconnect power from unit.
B. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
C. Replace door switch.
D. Re-apply power.
E. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
B. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
C. Repeat steps A and B for door switch.
Nov 16, 2009 | Ovens
FSE7 appears on kitchenaid built in oven
Here is the fault code for F5:E7...
1. If door latched:
  4. Re-apply power.
Sep 16, 2009 | KitchenAid Ovens
Oven wont come on -I get E1 F5 on display.
Jul 04, 2009 | Whirlpool Ovens
Code fse1 comes up when a few minutes after pushing start to cle
F5 - E1 Self clean latch will not lock
1. If door latched:
  4. Re-apply power.
Apr 01, 2009 | Ovens
KitchenAid KEMC308 Electric Double Oven Logo
239 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
