Question about Miele Dishwashers
We have a Miele G 692 SC PLUS dishwasher. We moved into our home four years ago. This is the first time it has flashed on red inlet/drain . Our filters are obviously blocked, but there was no manual left for us to refer to. How do we go about fixing this problem ?
SOURCE: Miele Model G 692 SCI
The inlet/drain light also comes on when there is water in the base pan. There is a float switch that triggers this and over time if water has collected in the base pan the float switch can stick. Pull out the dishwasher and tilt it towards to back. If there is any water in the base pan it will come out. To be thorough, put the machine on it's back and remove the base pan (4 screws by the feet), the float switch is a circular plastic casing with a polystyrene float in it. It comes apart for servicing, the float can jam if there is any rubbish in the water.
Posted on Jan 30, 2009
dragonsthatk
  • 547 Answers
SOURCE: Change miele dishwasher door seal
http://www.partstap.com/ please go to this site for diagram please rate me thank you for useing fixya
Posted on Feb 25, 2009
SOURCE: miele dishwasher red inlet light flashes
This is most probably a software glitch. I had the same issue a week ago and my dishwasher is only about 2 yrs old and only gets used on average once a fortnight.
At first I did everything as the manual shows in the troubleshooting section. The whole process takes only about 5 to 15 minutes depending on how good of a handyman you are.
When I cleaned all the parts involved (all pretty clean to start with anyway) and connect them all back, sadly the red light wouldn't go.
It looked like I was stuck with the most hated option I had left: call the dreaded technician and be prepared to depart with some hard-earned cash.
Before doing that and out of desperation, I decided to surf the net for clues, blogs, forums, etc... and on one of them I found my answer.
One blogger suggested that "if anything else fails, try the 'reset' step" which means pressing at the same time the On/Off button and the Start/Stop button. That operation put a big smile on my face (and my wife's face too) as the red light magically disappeared.
My suggestion is "first try the reset trick and if that fails try and clean the parts as the manual shows". It'll save you headaches because the reset would do the trick in 90% of cases.
I work in IT and I can understand the fact that a software malfunction would trigger the red light and not reset it.
Good luck.
Posted on Aug 14, 2009
  • 122 Answers
SOURCE: outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
Posted on Sep 23, 2009
  • 177 Answers
SOURCE: Have Miele G653 SCVi plus. We have inlet/drain flashing red light
Sounds like something is caught in th drain pump as the unit has to drain first before anything else happens. Remove the filter and the non return valve which is under the clip in the sump of the unit. In the manual it shows you this. Make sure the drain pump is free of any foreign particles like broken glass. Then start the unit again so it goes to drain without the non return valve in place. This will then throw out any foreign particles as well.
or it could be the drain pump is activated all the time which is the noise you hear as there is a flood in the base of the unit which activates the float switch and constantly activates the drain pump until the water has gone. Isolate the unit at the power switch and remove the bottom panel under the door panel. Dry up the water as best possible with a towel. You will see the float at the front. Run the unit again and check for any water leaks. You may just have over sudded the unit with too much detergent. Only use 2 teaspoons of powder. To start with while testing don't use any detergent. Good luck
Posted on Mar 02, 2010
Testimonial: "Thank you for your excellent advice, the machine was flooded in the base when the panel was removed. "
Miele G641 SC Plus Drain /inlet light 4 short 1 long flash. How do I find a fault code chart?
Inlet / Drain is a general fault meaning there was no water movement when it was necessary to start the pump. Either it didn\'t drain out or it didn\'t fill the last time.
Call 800-999-1360 for free Miele tech support. They will advise you free of charge. You will perform step by step control board operations over the phone to clear the fault code as well as advise you how to cleanout the drain pump.
Dec 27, 2014 | Miele Dishwashers
Hi, Our Miele G611SC plus is making a high pitched noise for about 1 minute when (I think) it is on the rinse cycle. When it then changes to the next cycle, the high pitched noise stops. We got the unit...
Hey Berni,
I've been having the same problem for quite sometime with my Touchtronic G 892 SC. It goes away if I open up the cabinet under the sink and wiggle the water inlet hose where it's connected to the dishwasher's "backflow" water inlet. I'm getting ready to disconnect the fitting and see if there's lime (or some other type) of buildup in the filter screen. I don't know what else it could be. I'll try to follow-up when finished with this task.
Nov 02, 2010 | Miele 18 in. G611SC Plus Slim-Line...
Hi My dishwasher Miele G692 SC has the inlet/drain light illuminated. I have cleared the inlet and tap connection..... Any other suggestions before I ring Miele?
Have you checked the drain? On mine a small piece of broken glass had got past all the filters and had blocked the paddles of the pump - you have to release the spring clip and take off the top of the pump housing. Miele's seem very fussy about any blockages to the water outlet system.
You then have to hold down the start button to force a restart (cost me a call out to learn that) - but it is stated, sort of, in the problem fixing manual.
Nov 01, 2010 | Miele Dishwashers
Water staying at the bottom of the washer.When i close the washer an press start the inlet/drain light comes on and nothing else happens.Miele G 692 SC PLUS
Your drain outlet is blocked , pull all the filters out and then check nothing is stopping the impeller from turning. You have to bucket out all the water first of course. It can be a toothpick or just some gunk,
Mar 25, 2010 | Miele 24 in. G692SC Plus SS Free-standing...
Outlet/inlet light flashing on miele dishwasher G674SC
Sep 22, 2009 | Miele Dishwashers
Feb 25, 2009 | Miele Dishwashers
Miele Model G 692 SCI PLUS does not start up. It drains water if you put water in the bottom. The Inlet/Drain light flashes. I have checked all the water filters and cleaned any very small particles...
Apr 02, 2008 | Dishwashers
Miele G892 SC Touchtronic
check drain pump impelar is free, it can be found under the non-return valve below filter. also make sure drain hose and S trap is clear.
Mar 29, 2008 | Miele 24 in. G638 Plus Free-standing...
Miele G646SC Plus dishwasher Drainage / inlet warning light
I had the same problem a few days ago. I followed the instructions to clean the filter and check to see that the impeller was free to rotate in both directions. The problem persisted. After reading this thread, and a similar one on another site, I tried what mikeboerma suggested in "solution #3", and bingo, problem solved. The magic combination is to push and hold the on/off button and the start/stop button.
Sep 15, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Dishwashers Logo
171 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
