Question about Akai Televison & Video
Myne is AKAI 32 inches LCD TV , Model Bravo . It is not starting . It remains in Stand by mode when tried both from remote as well as from TV button . We have found black mark near the " VGA in" port . Pls note that this TV is being used with LAPTOP also .
  • 597 Answers
The problem is that there is a burnt component inside the television, which could be the power panel of the television that is why it is not coming on.
Once you can open it up with the appropriate screwdriver, assess the parts to see the part that is burnt to know if it is replaceable.
Try to replace the power panel of the television first and try to turn it on to see if it will come on.
Take care and good luck.
Posted on Oct 10, 2010
Tv stuck in dvd mode
There should be an input button on the tv to allow you to switch between dvd, tv and any other device you have connected.
Aug 22, 2014 | Akai LCT3201TD 32 in. LCD Television
Remote code to turn akai TV/DVD combo on/off
Hi hojha, Here is the instructions from Dish Network. Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
Let me know if this helps and please rate this solution. lone99star
Jan 13, 2009 | Akai LCT3201TD 32 in. LCD Television
Akai LCT3285TA-need stand-remotes and 1 component input dont work
Check it out, is that remote you need for your Akai TV?
HERE is another remote but I'm not sure.
Dec 18, 2008 | Akai LCT3285TA 32 in. LCD Television
Need a stand and remote control for Akai LCT3201AD
Please check this Weblink as they might help you to provide desired parts for you Akai LCD TV.
Jul 27, 2008 | Akai LCT3201AD 32 in. LCD Television
Universal TV remote control
Target sells a GE Universal Remote Control, 5 Device with learning feature. I can't say if it works with your Verizon DVR, but its code for the Akai LCT3285TA is 1139. If you have the Verizon's remote, you should be able to use the learning function to make the GE control it - that's if the GE doesn't have a built in code that will work for this DVR.
Apr 26, 2008 | Akai LCT3285TA 32 in. LCD Television
Remote Control Code for AKAI 26 inch LCD
Go here: http://www.remotecodelist.com/remotes/ look it up by type of remote then to the device code...
Bill
Feb 01, 2008 | Akai LCT3201AD 32 in. LCD Television
Audio Output Problem
Select DVD Input source, then press the Setup button on the remote (it's under the DVD control block near Subtitle). Go to the Speaker Setup Page and select LT/RT or Stereo. After I set it up it seems to work for other Input modes also. I have the 27" model.
Dec 04, 2007 | Akai LCT3201TD 32 in. LCD Television
Televison & Video Logo
67 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
