Question about HP Computers & Internet
HP MINI 1033 CL HOW DO I REMOVE THE LCD - HP Computers & Internet
  • rapidrick200 Oct 10, 2010
    THIS ISA HP 1033 CL NO SCREWS I CAN SEE 10.2 INCH MINI NO RUBBER PLUGS
    Scholar:
  • 104 Answers
Tools required: A screwdriver (Phillips, the X shaped one), something pointy (fingernail, penknife).
Assuming you just want the LCD, not the whole screen assembly plastic and all.
Use the pointy object to pull out the rubber knobs placed around the edges of the panel, revealing the screws.
Use screwdriver to remove screws.
Use pointy object to pry gently between the two halves of the panel, they are snapped in place so do this gently but may require some force. Front half should come off.
Use screwdriver to remove the screws keeping the LCD in the frame.
Lift the LCD out of the frame by its edges, do this gently, they are fragile especially where the label reads on the top half 'DO NOT TOUCH THIS'.
Voila, but be careful.
Posted on Oct 10, 2010
  • Puck Mahee
    Puck Mahee Oct 10, 2010
    True, upon further research the design for this LCD panel differs from the norm.
    The link provided:http://bit.ly/9LQLU
    Is the User Manual for your netbook. It is a large document, goto 'Removal and Replacement Procedures' then 'Component Replacement Procedures' then 'Display Assembly'.
    This details exactly how to remove/replace the LCD panel.
    Champion:
  • 274 Answers
Good answer.
Meanwhile, it helps me.
Electronics wholesale
Posted on Nov 08, 2011
HP TouchSmart 310-1033 fan
If you do not know how to do it, take it to a repair shop.
Mar 31, 2014 | HEWLETT-PACKARD Black 20" TouchSmart...
Changed the lcd screen but all i have is a white screen
1) Loose connection of the Video Cable TO the motherboard, and/or TO the back of the LCD screen.
Can easily happen when reassembling.
(If you can't reuse the sticky tape on the back of the LCD screen, that holds the Video Cable to it, use more tape )
2) Incompatible LCD screen.
MATCH up the manufacturer's numbers on the back of the old LCD screen, to the new one.
They MUST crossover, and match up, if they are two different LCD screen manufacturers.
The screen Inverter is MATCHED to the LCD screen, also.
Matching up the Model Number, (Product Number for HP), may not be all the info you need.
Matching the numbers off of the old screen, for the new one, is.
http://www.sparepartswarehouse.com/HP,Mini,1000,Laptop,LCDs-Displays.aspx
Under the red heading - Find Your Spare Parts - click on the blue Down Arrow to the right of the - Choose Model - box.
What Model is yours?
Write down the manufacturer and product ID number.
Now go to the far upper left of the page. In the box under - Part Number Search, type the letter/numbers for your old LCD screen.
On the page that comes up. Do they match?
Putting the letter/numbers in for the LCD screen you just purchased.
Do they match?
IF the old LCD screen works at all, reconnect it, and see if it works.
If so the LCD screen you purchased does not.
3) Make SURE the screen Inverter cables (Wires) are connected tightly.
[ Check the connection of the Video Cable to motherboard first.
Then the Inverters wires, then the Video Cable connection at the back of the LCD screen ]
Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL or a series of LED lights
The HP Mini 1000 series of Netbook PC's uses a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
OR a series of LED lights. Depends on the model. (8.9 inch LCD screen models usually use CCFL. 10.1 models usually use LED lights)
A screen Inverter (FL Inverter) is used to convert power from the laptop, for the Backlight, and LCD screen.
Make sure there is 6 Volts DC power going through the Inverter.
[ NOTE*
90 PERCENT OF THE TIME the fault is the Inverter ]
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=3832471&
HP Mini 1000 and Compaq Mini 700 - Maintenance and Service Guide
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 28, 2012 | HP Mini 1000 Netbook
My HP mini 1000 is locked and I can't even get
Remove the cmos battery for 5 - 10 minutes. That will reset all data in the bios.
Jul 25, 2011 | HP Computers & Internet
One thin green line down computer screen any idea how remove it
Unfortunately, a thin straight line of any color on an LCD screen is an indication of a hardware failure in the LCD screen itself. The only fix is to replace the LCD screen.
Apr 10, 2011 | HP Mini 1000 Netbook
My printer is not in english mode
Hello
First you need to unpacked the .EXE install utility, using WinRAR,then execute the setup file using a switch for the language you want like this;
<files path>\setup.exe /L "language code"
For an English (language code = 1033) installation, where the files are located at c:\printer, we then have:
c:\printer\setup.exe /L 1033
Dec 11, 2010 | HP PSC 950 All-In-One InkJet Printer
The screen on my hp mini 110 went white
A white LCD screen can be caused by (likeliness):
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard.
A local computer repair store should be able to fix this for you.
Jun 25, 2010 | HP Mini 110-1037NR Netbook
HP Solution Center
When you click on the icon it is trying to open an xml file which is like a web page. The parsing error means there is an error in the page. I think the best way to cure this problem is to go to http://www.hp.com/#Support and put in the model number of your computer and download new drivers for your printer. You should also uninstall any current drivers you have from control panel's add and remove programs.
Dec 07, 2009 | Office Equipment & Supplies
Customer has * Installed Size 1024 MB * Technology DDR II SDRAM how many gigs is this all ready? What is it equal too 1gb, 512, etc........ . what type of memory should i use ............ its a...
256MB = .25GB
512MB = .5GB
768MB = .75GB
1024MB = 1GB
Your HP Mini takes this type of memory:
DDR2 PC2-5300 • CL=5 • Unbuffered • NON-ECC • DDR2-667 • 1.8V • 256Meg x 64
You can find the memory type for your computer here:
http://www.crucial.com/store/listparts.aspx?model=HP%20Mini%201151NR
Oct 19, 2009 | Computers & Internet
Horizontal line problem
Cl;ick on Link Below, Good Luck.
LCD Help
Helping you with questions and issues you may encounter with computer LCD displays. ... you would receive a solid black line going vertical or horizontal.
Please dont for get to Vote, Thank you
Dec 16, 2007 | HP D2835 17 in. CRT Monitor
Computers & Internet Logo
158 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
