Question about Maytag PYE2300AY Electric Dryer
Little pressure in vent--clothes dryer very hot but clothes not drying
    Problem Solver:
  • 11 Answers
Have you cleaned out the filter?
Posted on Oct 10, 2010
Takes to long to dry clothes
after checking and replacing the vent going outside still the air was not venting and inside my drier everything was wet although the air was hot. After removing the rear panel i saw the blower belt disconnected. it took me some time to get the belt on but everything is ok and the air is venting and clothes getting dried. Also note that the little pulley came off its positio too.
Feb 14, 2013 | Whirlpool Dryers
Outside of dryer gets hot, but clothes do not dry. Where dryer vents to the outside has little to no pressure coming out. Inside of dryer has completely cleaned of excessive lint.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Aug 11, 2011 | Dryers
My hotpoint dryer takes hours and hours to dry clothes?
clean the vents as it is an air restriction, first take off the vent house run dryer and feel for hot air, if no or little hot air then then inside of the dryer needs to be cleaned, now if you run the dryer with the hose off and it drys like it should then the vent hose needs cleaned/unrestricted. Hope this helps Tim
Nov 07, 2010 | Hotpoint Dryers
My dryer runs and gets hot but cloths don't dry.
Your problem may be attributed to a clogged exhaust system (e.g.: clogged inside the dryer's vent, flexible vent behind dryer clogged and/or clogged inside wall, etc.).
Feb 22, 2010 | Whirlpool GEW9250 Electric Dryer
My electric dryer gets hot but the cloths are not drying
Please check your dryer venting, all of it, or at least as much as you can. I would start at the discharge outside. May be full of lint, covered by plants. or a bird may have built a nest inside. If air is not flowing through the dryer and to the outside clothes get hot but stay wet. Is the case of the dryer hot? Another indicator your vent needs to be cleared. This should be done before you run the dryer again, or you could cause thermal fuses and other little gizmos to break.
Jun 14, 2009 | LG DLE2532W Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Dryer won't dry
Remove the rear connecting vent and try it again.
If it dries correctly...and it probably will. , clen the connecting vent and the vent in the wall.
Mar 27, 2009 | KitchenAid Dryers
Gas Dryer Heats up very little, but not enough to dry my clothes
you need to check that for vent hose is not kinked if it is not then remove it from the dryer and see if it work right if it does then the vent tube that goes thourgh the wall has a blockage
Feb 24, 2009 | Whirlpool LGR3624JQ Gas Dryer
Maytag PYE2300AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
