Question about Lexmark P4350 All-In-One InkJet Printer
Lexmark 4580 my printer prints up to 40% then freezes. sometimes it will will work ok from a usb cable and other times not.phoned lexmark and they tried to say my antivirus was stopping communication so uninstalled it and it still would not work .....any advise would be appreciated
  • johnmc1717 Jun 17, 2008
    exactly the same problem ,then works fine for a few days then goes gaga
    thanks john
  • aga151 Jul 19, 2008
    Printer worked for 3 weeks then nothing,I can tell you I have had 2 diagnostic checks done and countless help on the phone and still no joy,Lexmark have now blamed everything and everyone else,the problem seems to be that they cannot accept that there is a problem with their printers and are reluctant to admit it's their fault,my problem has now been ongoing since the 23rd MAY,it's now packed up and ready to return but neither they nor the dealer seem to want to take this printer back,the latest episode was They asked for my phone number(which they have a copy since the problem began) and the last email was; the number you gave has NOT been recognised!! I then found the mail I sent when they first asked and sent it AGAIN to them,now waiting to find what the next excuse WILL be.
    NIGHTMARE
  • 4 Answers
Pls format you pc then checked
Posted on Jun 13, 2008
Lexmark 4580 all in one prints data not on page to print
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/pOdfTQ. Select your operating system, download and execute the file.
Oct 07, 2011 | Lexmark X8350 All-In-One InkJet Printer
When I try to print I get an error and it won't print. The error message never shows up so I don't know what the error is. I have removed and reinstalled this printer 6 times now. I have rebooted...
Sounds to me like a bad USB cable,
Also when you're re-installing the printer are you using new/different drivers?
I would try a new cable and the latest drivers direct from Lexmark.com
Jun 01, 2011 | Lexmark X4650 InkJet Printer
My lexmark printer wont connect with my computer
Lexmark provides a line of wireless printers and sometime printer won't print with wireless...so here is what you may have to do in order to get this fixed
1.make sure your wireless password is right
2. uninstall the printer software and reinstall it once again ( make sure you configure the router with wireless router) for more assistance contact with Lexmark Printer Tech Support
3. 3. now type the right password and try to print it
i hope this may help you.. thanks
Sep 06, 2010 | Lexmark X1195 All-In-One Printer
Printer is not printing - i have started, restarted diagnosis tests, changed the ink, uninstall and installed program. I have a Lexmark X2600. It says that it's ready; but still doesn't print? what else...
Check the USB cable to make sure it is connected, then restart your computer. Sometimes the computer registers it on a different USB port. When you go to print look at your printer options, is there a Lexmark and a Lexmark (copy 1)? Try printing from Lexmark (copy 1) if it is showing. If there is still a problem, try putting the print on another computer, to see if the printer is malfunctioning. If that is the case, you'll need to get another printer.
Sep 14, 2009 | Lexmark X2600 InkJet Printer
LexmarLk X4850 fax wireless set-up
Printing: since Lexmark say you can either connect wirelessly or wired and not both, you must either connect your daughter's machine to the hub by wire or yourself to the printer wirelessly.
Fax: this will need a phone line.
May 27, 2009 | Lexmark X4270 All-In-One InkJet Printer
PRINTER READY , BUT WONT PRINT
Try unplugging the printer (both the power and the USB cable), plugging the power and USB cable back in, and restarting the computer. Sometimes this solves the problem.
Feb 04, 2009 | Lexmark X2500 All-In-One Printer
Lexmark X4850 wireless set-up
I have a Lexmark X4850, every time I print a job it prints a blank page first then the document. I have tried to tell it to print 1-1 or 1-3 but it continues to print that blank page first. any suggestions.
Oct 05, 2007 | Lexmark X4270 All-In-One InkJet Printer
Laxmart x73
Insert your Lexmark Xx3 Installation CD (disc 1) in your CD-ROM drive. Make sure your computer is on. Once you see the Lexmark Installation screen, click the Install Now button. Wait while files are loaded onto your computer. Click the Next button. Click the Next on the directory window. Click Next on the following screen. If your USB cable is connected to your Lexmark All-In-One product, disconnect it now. Click OK. Wait while the software is installed on your computer. When the next screen appears, connect the USB cable and click OK. The printer should now be installed and ready to use. Already installed the software but it appears the printer driver is not installed To verify the printer driver is not installed follow these steps: Attach the USB and power cable attached to your device Restart your PC Click Start. Click Control Panel. Click Printers and other Hardware if the icon exists. Click Printers and Faxes If your printer does not appear in the list then please follow the remaining instructions below. Unplug the USB cable and power cord from the back of the printer Insert the Lexmark Xx3 CD into your CDROM drive if it is not installed already. If the CD automatically runs, click Cancel. Click Start and select Run. In the Open box, type the letter of your CDROM drive followed by prtsetup.exe. For example: D:\prtsetup.exe and click OK. A Lexmark License Agreement will appear, click Accept. A progress bar with the percentage of files copied will be displayed. Next a communication error will appear, click Cancel on this message. A printer registration screen will appear, click cancel or exit. Click Start and choose Shut Down. In the Shut Down window select Restart. While the computer is restarting reconnect the USB and power cables and power the printer on. Once the computer has restarted Windows should detect the printer. if still it is not working try with another usb cable
Sep 12, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark X5150 No printing
uninstall the printe driver,then try reinstalling the printer back.if no luck,change the usb cable or printer cable as the case may be,if doesn't work,try using the printer on a friends machine. did it work?let me know. eyo7 eyoifiok2005@yahoo.com
Sep 01, 2006 | Lexmark X5150 All-In-One InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
50 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
