Question about Samsung ML2251N Laser Printer
Manual tray not picking the paper pls advice how to solve the problem
    Problem Solver:
  • 13 Answers
When u press the sensor it come on green light or red
Posted on Nov 14, 2013
5 Suggested Answers
  • 5 Answers
SOURCE: paper tray problems
Re-Read the install data that came with the printer as to filling and inserting the paper tray
Posted on Jun 04, 2008
Bigevy
  • 4 Answers
SOURCE: printer will not pick up paper from paper tray?
There is a knurled roller in the back that comes down and grabs the paper. You can visually see this when the printer cycles or / and u can see it if you remove the Drum cartridge (the green handle), it is about 1 inch long and centered on a steel rod. Use some denatured alcohol or rubbing alcohol and clean this using a lint free cloth or a q tip if it will reach. This will soften it and give it some more stick ability!
Posted on Mar 12, 2009
  • 32 Answers
SOURCE: Paper wont pick up from Tray 1 .
You will probably need to change the pick up rollers.
Posted on Aug 03, 2009
  • 525 Answers
SOURCE: Feeding paper: how to fix the automatic feeding
Pull out a paper cassette, lift up the printer and under you see paper feed roller (it is rubber), just clean roller with cloth and water or alcohol
Posted on Jan 31, 2011
Bizhub c220 tray 1 problem
pull out tray and check any paper is jammed is remaining at the back end of that tray
Nov 19, 2012 | Konica Minolta Bizhub C220 Color Copier
Paper Feed Tray will not feed paper. There is a
goes through below link and download the manual and try to clean the paper pick up roller and check i think it will solve your problem .......
Dec 14, 2009 | Brother DCP-7020 All-In-One Laser Printer
Printer making crunching noise when printing. trouble picking up paper from main tray. keeps asking for paper to be loaded in tray, when its full. help D
It is a hardware problem.Your printer roller & paper sensor are not working properly. So pls checked it from service center
Oct 13, 2009 | HP Photosmart 3310 Printer
Paper pick up problem
hi,try to clean feed rolls,sensors.clear any misfeed sheet from paper supply area.send me a result.
thank you.
Jun 01, 2009 | Canon NP 6050 Copier
Paper jams when printing
just add some more paper to the tray..and arrange it properly..
i think the paper pick mechanism failed to pick the paper.or there is a long time delay before the paper reach the printing area..
thanks for using FIXYA!
pls let me know if it solve the problem..
May 21, 2009 | Dell 924 All-in-One InkJet Printer
My samsung clp 300 won't pick up the paper
I used to have the same problem.
Levelling the paper tray helped to solve it.
Make sure the printer + paper tray stands on an equal levelled surface (on which the tray doesn't hangs over the surface)
Nov 10, 2008 | Samsung CLP 300 Laser Printer
Canon PC-921 copy machine error message "P"
Load paper.If there is paper in the tray,there is a problem with the paper pick up.Try to use the Manual feed try.
Oct 26, 2008 | Canon PC-921 Black and White Copier
HP P3005 Will not pull from Tray 1
Click File > Print > Properties to check your settings.
To verify that tray 1 is working, put paper in tray 1. Press green check until you see Information Menu. Scroll using arrows until you see Print Menu Map then press green check. If it prints from tray 1, your problem is not with the printer, but with the PC settings.
i has follow this step, but need to press green check button to resume print menu map.
tray 1 manual feed set to A4 paper plain size
manual feed is on.
there is paper on tray 1
ps setting tray1 manual feed is A4 plain size paper.
send print to tray1 manual feed even there is paper at tray 1
i still need go to the printer and press green check button to resume print
Sep 23, 2008 | HP LaserJet P3005n Printer
HP laserjet P2015D , JAM LED in a solid state ??
Dear gentlemen,
Hope this helps you sort out the problem. Please check paper jammed pieces of paper remains from paper in to out paper path. Check if the paper is properly picked-up, else check rubber roller pick-up and the solinoid motors that control to fed on and off the tray to engage pick-up. Check paper path sensors if possible. If you can determine when is the paper Jam happens please advice. Other means you can also refer your manual and machine diagnostic menu which part of the operation the paper will jam.
Best regards,
Rosener Guyano
Jan 10, 2008 | HP LaserJet P2015dn Printer
Samsung ML2251N Laser Printer Logo
35 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
