Question about HP vs15 15"LCD Flat Panel Monitor
Monitor stays asleep
I've tried turning it on and off, unplugging it, and everything else, but the monitor goes to sleep after being on for only a couple of seconds. Also, instead of the natural clear light that computers usually have, the light is red. HELP!! My computer is only 2 years old...
    Sergeant:
  • 458 Answers
Check in the BIOS and see what your monitor settings are.
Did you change the sleep mode or power off mode? What do you do to make it come back on? Sounds like it might be getting too hot and/or going bad. Try it on another machine and see what it does. Also try another video card because the video card could be going bad.
Posted on May 30, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    Can you please let me know if this solved your problem?
    Rate this as a fixya if your problem is solved please.
    If you need more help let me know.
I have a Acer X203H Monitor. Everything is connected I've checked a million times. When my computer turns on it displays fine on the monitor, but the first or sometimes second time the computer goes to...
I would try this monitor with another PC first to verify that it is not PC problem.
Most common failures in the monitors are due to bad caps in the power supply/inverter board, we want to find out first if it is the monitor or the PC problem.
See examples of failed ACER due to bad caps here:
http://s807.photobucket.com/albums/yy352/budm/ACER/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 24, 2011 | Acer X203H Monitor
Monitor will not awake from sleep mode. Pilot light is amber when asleep. If the monitor is turned off pilot light goes from amber to off or black or nothing. Turning the monitor back on the pilot light...
That means your monitor is not receiving a signal from your video card.
A couple things to check:
*Make sure your cable is ok - unplug and replug the cable to see if it is a loose connection. Or try a different cable.
*Make sure your computer is not in sleep mode - Move your mouse or otherwise ensure your computer is awake and sending a video signal
*If you have another computer, try the monitor on the other system and see if it works.
Sep 03, 2017 | LG L196WTQ-BF 19" Monitor
The monitor starts up and goes into sleep mode
After repairing the on/off button for $100.00 and then rehooking up the monitor to my pc, the monitor has power but stays asleep even when I push in the menu button, I can't get anything to happen. HP techs tell me that the problem is with my computer although it worked perfectly fine before I unhooked all to send out the monitor.
I hooked all back up again as before but now the monitor will only say "monitor going to sleep" and nothing happens.
Wishing I had a solution. Thanks
Sep 10, 2010 | HP f2105 21" LCD Monitor
Monitor willnot come out of sleep mode
turn off everything and restart computer in safe mode,do this by holding down f8 as you reboot,then go in your setting and remove time limit on sleep mode.
Apr 10, 2009 | HP w1907 LCD Monitor
Computer asleep
If you go to control panel > display settings > Screen Saver > Power (win XP) or Control Panel > Power Settings (Vista).
This will allow you to turn off the sleep or change the amount of time until the computer goes to sleep or turns the monitor off.
Mar 26, 2009 | HP w1907 LCD Monitor
Monitor displays slowly after the computer starts.
try to turn off you screen saver just turn off power monitor to see monitor easy wake up after long time.if ok means windows screen saver have problem if still same look like is you monitor something wrong need to check
Jan 03, 2009 | Dell Dimension 2400 PC Desktop
Dell LCD monitor quickly goes sleep, on, off over and over
I would recommend that you try it on another computer to see if you are able to reproduce the results. If that is the case you should look at any new drivers, software or updates that have been installed. If the issue continues with another PC, it sounds as though the monitor's power supply is possibly failing. in that case I would suggest you simply replace the whole monitor. Unless you are not shy with a soldering iron. ;) good luck!
Nov 19, 2008 | Dell E197FP LCD Monitor
Monitor in sleep mode
my computer is on but screen is black and has power. How can I fix it?
Aug 27, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Going to Sleep
Due to the power surge, it is highly possible that the monitor was given a boot by your computer on it's way out.
This will short out a very small transistor inside the monitor on the video board and in turn, then monitor cannot see that there is a signal so goes to sleep.
If you get brave enough to venture inside the screen, then check near the cable input. The transistors are only around 3mm and have 3 legs (two one side and one in the middle on the other).
If you find anything like that burnt (get a magnifying glass) then replacing the board is the easiest option. Just don't be tempted to wipe the board before you look at everything very closely, you may wipe away the tiny bit of evidence you are looking for.
Hope it helps =)
Feb 12, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
HP vs15 15"LCD Flat Panel Monitor Logo
200 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
