Question about Metra Parrott Harnesses Bt 5520 Hands Free Kit
Volume too low on parrot vm3.18 - Metra Parrott Harnesses Bt 5520 Hands Free Kit
My Parrot v5.25c tells me the memory is full when trying to connect to my Galaxy S3
Hey everyone,
I have had the same issue with my VW Polo Comfortline 2012, trying to connect the Parrot v5,25C to a iPhone 4S.
I turned the ignition on and my phone Bluetooth together. I then hit the volume(-) button first then the volume(+) on the steering wheel, this has to be done in sequence - then + about 5/6 times. The car kit then said phone memory being erased and BOOM ready to pair again :-)
Its all up and running now with the pass code 1234 entered on the phone for activation.
I hope this helps!!
Feb 16, 2013 | Parrot CAR PAICK3300 GPS Receiver
No volume on parrot ck3100
check the settings on your phone first. turn it up on your phone and then go to settings and move up the phone setting volume.
Aug 25, 2012 | Parrot Hands-Free Car Kit with LCD Display...
Iphone volume
Have you tried to remove the device from your iphones blue tooth list, and reset the connection?
Mar 15, 2012 | Parrot SA Parrot Evolution Bluetooth Car...
Remote does not work on SK4000.
If you have verified that the battery is good in the unit, try this (from the folks at Parrot). The HCU is the main control unit.
1) Turn the HCU on
2) Clear the memory on the HCU by holding down the power button and accept call button (the two large buttons on the face of the HCU)
3) Wait until you hear the HCU make the request "please pair device"
4) Hold the volume up and the volume down keys on the remote for 15 seconds
5) Release the buttons on the remote.
It might be fixed now. Press the switch on the bottom of the remote to switch to radio and see.
Jun 04, 2011 | Parrot SA Parrot SK4000 Motorcycle...
I have a parrot ck3000, but i dont know how to erase the memory using only the steering wheel contols. i have tried to hold the call and answer buttons simultaneously but it does nothing, i have tried with...
You will need to plug in the original parrot control to do this. contact the supplier if you do not have it as they should have left it with you. Otherwise Parrot web site has a list of certified engineers.
Feb 19, 2011 | Parrot Par Ck3000 Evolution Ck3000...
My Nokia will connect with Parrot CK3100. On
you can adjust the ringtone and volume in the sttings menu.
Oct 18, 2009 | Parrot Hands-Free Car Kit with LCD Display...
No intruction manual
hi
kindly download the user manual from the below link....
http://www.parrot.com/usa/support/userguides/parrotminikit
thank you
have a nice day
May 07, 2009 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Parrot 3200 Ls doesn't cut out radio
problem is the 220 has an amplefier in boot the controls the radio, unless proper leads that connect there are used to interupt the radio when call happens it just some thing u have to put up with or buy the lead, try autoleads.com or look on parrot web site for the right leads
Mar 30, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Parrot CK3000 Evolution
after a reset try to push the parrot in pairing with your phone.< for any G3 phone the below should work. The menu could be differnet on yours this is for a nokia G3 phone. Object Push: * From your phone go to MENU / COMMUNIC. / CONTACTS * Select the desired contact to send * Go to OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH / ALL CONTACT DATA * Phone will search for available bluetooth devices * Select from the list Parrot Product and press SELECT * wait until the contact is transferred. After contact is sent, it is neccessary to register "Contact's Name"
Aug 14, 2008 | Parrot Par Ck3000 Evolution Ck3000...
Parrot memory full
I had same problem too.
I have googled 3 days and found the solution from MULTICAN manual.
•Reset the hands-free kit:
Repeat the following sequence five times:
press the "Volume (-)" button and then the "Volume (+)".
And also F.Y.I.
•Enter the menu:
Press the following sequence twice: [SEEK up] button then the [SEEK down] button.
•Go forward through the menu: Press the "Volume (+)" button.
•Go backwards through the menu: Press the "Volume (-)" button.
•Select a menu option: Press the "Phone" button.
•Cancel a function: Long press of the "Phone" button.
Jan 18, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Metra Parrott Harnesses Bt 5520 Hands Free Kit Logo
65 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
