Power Supply I am needing to buy a new power supply for my HP 516X System # DK397A and am not sure exactly which one to buy I was given a part # but that didn't help me any. Can you tell me of a brand that would work in my computer so we can get it up and running again....Thanx
GO **** YOURSELF
Posted on Jun 29, 2008
  • 30 Answers
The power supply should be FSP200-60SPV-D - 200 Watt ATX Power Supply, its the common replacement power supply for HP, Compaq. You go to a store and ask for the FSP200-60SPV-D - 200 Watt ATX Power Supply, its the one you need
Posted on May 31, 2008
Replace power jack
Power supply failures in a HP computer can cause your computer to fail to turn on, to operate erratically or cause certain system components not function.
However, the power supply is one of the easiest parts of a computer to replace.
You don't need any special skills to do this.
If you're nervous about opening up your computer case and potentially damaging a computer component, don't be.
All you are really doing is plugging in power supply cables after securing the power supply.
The process should take 10 minutes maximum.
Shut down your HP computer.
Disconnect the power cable from the power supply on the back of your computer.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
Unscrew the side panel from the back of the case and slide it off.
Newer HP computers may have a case door you can open for access or have access buttons to press.
Look at the back of your HP computer case for a set of four screws near the top of the case. Remove these screws and set them aside.
Carefully slide your power supply out of the mounting brackets and set it on a clean working surface.
Do not disconnect any of the power connectors yet.
Slide your replacement HP power supply into the case and use the mounting screws to attach it to the chassis.
Use your old HP power supply as a guide to connect your new power supply to all the computer components.
Switch the power cables from each device from the old supply to the new supply so you don't miss connecting any cables.
Check that all the components have power cables inserted and the old HP power supply is completely disconnected from the system.
Close the HP computer case and plug the power cable into the new HP power supply.
http://www.fonerbooks.com/r_power.htm
Apr 15, 2014 | HP Hewlett Packard Pavilion Slimline...
Need the schematic for the power supply for compaq presario sr1630nx
You do not ever attempt to repair a power supply. Between the high energy capacitors and the excessive voltage and amperage, there are no usable parts. You would have to buy the exact same model. Since this computer is about 5 to ten years old, you should be wise and do like the professionals do and get a new power supply. For Christ's sake, they are only 15 to 45 US. Be safe, do not electricute yourself for that price.
Feb 08, 2011 | HP Compaq Presario SR1630NX PC Desktop
Have hp compaq d530 problems turning on. Wont boot, showing 1 green flash when power button is depressed & thats it!,,,,, ASSISTANCE!!!!!!! johnhall248@yahoo.com
That is most likely a bad power supply but it could also be a bad mainboard. You can find replacement power supplies for under $50 so try that first.
Mar 18, 2010 | HP Compaq Evo d530 PC Desktop
Power Supply for HP Media Center m1270 PC
Are you sure it's the power supply?
Most modern power supply units are of the ATX type. Brand should not matter. Your PC used a 300 watt power supply when new. You can purchase a power supply with more output (watts) if you like, but not less. You will have to purchase from a computer specialty store most likely - take the dead one in and compare it side by side with the new one before buying.
Dec 11, 2009 | HP Media Center m1270n (PP132AA#ABA) PC...
HP d330 fried during pwr serge, fixed, boots but no screen signal
there are several possibilities. 1. replace the ram, make sure that its a good working ram module. 2. review all your work from system board to power supply. 3. try running it temporarily without the cmos battery. 4. check your monitor. 5. check your VGA. 6. retry and retry.
Jul 13, 2009 | HP Compaq Business Desktop dc5800
How much watts of power do i have?
the 9600GSO uses arounf 250 watts under load. While I cannot fing exact spec for the HP PSU I would be surprised if it were more that 350W. Is there any indication on the case or can you open the case up and look at the PSU?
9600 GSO Power
You need somthing in the order of 450W or greater. Get an Enermax, Corsair or other good quality PSU.
Jul 25, 2008 | HP PAVILION A6230N DESKTOP PC
Power Supply for HP Pavillion 516X
Hewlett Packard Part Number: 09504107
May 30, 2008 | HP Computers & Internet
Power supply replacment
You should be able to replace the power supply. It is usually held in place by 4-6 screws. Unplug the cables on the motherboard and drives. Reconnect the new ones and away you go. A generic supply will be fine if it is of the correct physical size. Bring the old one with you when you go to get the new one.
Dan
Mar 18, 2008 | HP Pavilion A520n (DW233A#ABA) PC Desktop
Hp pavilion a330
the simplest solution maybe just so simple... just a suggestion try unpluging the power connector to the motherboard then just press the power button to clear and shorted circuit and grounds then replug the motherboard power... if still no power try a new power supply.... better buy a new one than more parts will be damaged if you got a broken power supply.... how to check your power supply??? plug the power cord then use a hair pin to plug the red wire (wire in the middle) the just plug the other end to any black wire... if the fan of you power supply works your power supply still good to go... use some tester for the voltage values of wires...
Jan 23, 2008 | HP Pavilion a330n (Refurbished)...
Power supply
Yes, It is a GOOD IDEA to get a bigger wattage PSU in case that you want to add extras to your HP. No you do not need a new case unless it is beat up, or you just do not like it anymore....
Jan 14, 2008 | HP Media Center m7250n (ED842AA) PC...
Computers & Internet Logo
88 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
