Question about HP Compaq nx6110 PC Laptop
Hangs after it is started. or sometimes it don't start processing completely
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
    Problem Solver:
  • 17 Answers
It's not working properly because of viruses ,,,,,,, Window format kar do.........
Posted on Oct 10, 2010
98 gmc safari. Starts sometimes and doesn't other times. Fuel pump tests fine, new fuel filter and crankshaft sensor. Can't afford to keep doing process of elimination.
Check battery cables at battery may be loose or corroded don't disconnect unless memory is maintained always remove neg first and don't reconnect until pos is connected and tight
Apr 02, 2012 | GMC Safari Cars & Trucks
Tip
How to clean up start up processes
Questions about optimize start up:
How to remove program from start up?
My computer boots very slow? How do I clean up start up processes?
Windows startup very slow, how to fix it?
Why clean up start up processes?
Windows Startup program will load the default programs or processes you add to your computer. The test result shows a new system only boot within 30 seconds. As you install antivirus program or other applications, it becomes very slow. Sometimes, the startup gets bloated not due to your computer behaviors. Malicious software is prone to add useless processes on startup without your known. You are not aware that your computer becomes more and more slow until serious computer problem occurs. Don’t ignore a slow start up, it is the root of Blue Screen and computer freezing.
How to clean up start up processes?
The first thing you should do is to remove spyware or adware from your computer. I prefer to AVG, it is a free anti-virus program. If you want to clean virus completely, you need boot in safe mode and disconnect your Internet.
Hok is a professor with over ten year’s computer experience. He suggest us use ErrorFix. This is a pc optimize tool which can clean up system registry entries, useless program, start up processes and junk files. With this program, your computer will be obviously improved. Just a few clicks, you can remove processes that slow your computer.
What’s more to speed up your computer?
Do not download Peer-to-Peer Download Software! Maybe you are using some software such like YouTube Downloader. These are probably some of the least likely contenders for system-slowdown but they are popular on the internet. Those kinds of program can take up memory space and damage your computer. Also they can automatically add itself as your start up.
on May 26, 2010 | Computers & Internet
Hanging on booting after memory count
Sounds like the boot files might be corrupt. Click Start/All Programs/Accessories then look for the Command Prompt. If you don't see CMD, click RUN and type cmd in the box and press enter. A black window will open allowing you to type in commands. Try the following command by typing: sfc /scannow (it will run a while and when it finishes try rebooting). If sfc fails to fix the problem try this command: chkdsk /r
Chkdsk will run an hour or more so be patient and let it do it's thing. You'll even notice that the percentage of completion will go from high to a lower percentage in the process. That's ok, just be patient and let it run until completion.
Mar 09, 2012 | HP dc7600 Convertible Minitower PC Desktop
How can i install windows xp on laptop CQ60-104TU without flushing the BIOS
When your operating system stops working correctly, you might need to re-install it. In many cases, when you continue operating the same computer for years, installing and un-installing programs over and over again, sometimes certain operating system files don't work as well as they once did. When that happens, you can also start a re-installation of your operating system. If you use the same operating system for a number of years, it is often helpful to re-install the system software every now and then.
1. Put the original CD or DVD for the operating system in your CD or DVD drive.
2. Shut down your computer and restart the computer. Boot from the CD, if your system asks. This will start the installation process and will pause when a blue installation screen appears.
3. As the screen directs, press the "Enter" key to continue the installation process.
4. Press the "F8" key to continue the installation, agreeing with the Windows Operating System licensing agreement.
5. Press the "R" key on the next screen to attempt the repair process. This process will attempt to re-install all the operating system files that are on the installation disk without bothering any of the customization that you have done to your operating system. This process may take a few hours to complete, but when it completes, you should have Windows XP re-installed and working on your laptop.
I hope you find it very helpful. Best regards.
Aug 15, 2011 | Compaq Presario Notebook
Hi, I have an Acer Desjtop Aspire X1800 running Windows 7 64 bit. It has 4GB RAM, and 2.50Ghz processor, with Intel core2 quad Q8300. HD is 916GB. You would think this kind of setup wouldn't be prone...
Do a Crtl-Alt-Del and Select Task Manager. Look at the Processes and notice
which one is using up all your CPU time. A Virus or Malware/Spyware etc...
may take control of your PC and slow it down to a crawl. If everything looks
OK, then suspect your hardwares: DVD or Hard Drive(s). If one of the device
(mostly the Hard Drive) has an interface problem, as the CPU tries to access
it but has difficulties doing so, it will keep trying to access it again and again,
thus chewing up all the CPU time.
If you can't figure what it is, I suggest using one small hard drive only and do
a clean complete Format and Windows Installation.
Jul 17, 2011 | Computers & Internet
Start up is very slow and its hanging all the process is stopping with hang what can i do will u pls help me to come out of this problem
this problem may be attributed to many programs loading during start up
Startup tasks can be easily disabled with the help of a utility by Microsoft called Autoruns. You can download Autoruns from this link. After download, unzip and run Autoruns.exe . It will load like snapshot below. Click on Logon tab as shown in red circle in picture below.
Logon tab shows all the tasks which are automatically start every time windows starts. Have a close look and disable some of the tasks which you don't need at startup. For example, in some computers, at logon, web cam software, acrobat reader, real player up-dater, yahoo messenger , etc. applications start running while you may not be needing the all the time.
To disable un-necessary items to load at logon, simply un-check those items in the log-on tab as above. These applications can be started later when needed from start menu. After un-checking, just restart your computer and see the difference.
Jun 16, 2011 | HP Pavilion dv2000t Notebook
DVD-R formatting fails
#1
Insert your ( memory card , flash disk , cellphone , .... ) into your computer.
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Jul 12, 2010 | Cyberhome DVR 1600 DVD Recorder
Ipod hang gogear display
my ipod get hanged while playing song how can i solve this problem
Jul 20, 2009 | Philips GOGEAR SA6045 MP3 Player
I started up the Eee 701 netbook and it found 18 updates to the OS/software installed. I started to install them. During the process, the downloads/installs started to hang. So I restarted the pc and it...
Hi there.
You can try and resolve this problem by performing a system restore.
Click on the start menu/orb, select all programs, then accessories, then system tools and system restore.
Open the program and take the computer back to before it installed the updates.
If system restore is not in the menu, type rstrui in the search bar.
I also recommend you leave the computer to finish its update process because it can take some time to complete.
Please post back if anymore help is required.
Good luck
Jun 10, 2009 | ASUS Eee PC 701SD 8G Notebook
My windows vista hangs often;
Download process explorer
http://technet.microsoft.com/en-us/sysinternals/bb896653.aspx'
Extract the program, make a shortcut and copy the shortcut to
START MENU- PROGRAMS - STARTUP
Now every time you start the computer process explorer will start up and you can kill any processes you need
also you can disable programs from startup by
start -> run -> msconfig -> startup tab
Dec 08, 2008 | Microsoft Windows Vista Ultimate Edition
HP Compaq nx6110 PC Laptop Logo
26 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
