Question about Dryers
When the drier is on, the belt makes a terrible noise as if slipping.
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
This is a FREE answer, Please rate me
Posted on Oct 10, 2010
Screeching noise
belt slipping don't wash so much atone time
May 17, 2015 | Washing Machines
Dyson dc17 making loud sound
It may have a bad clutch belt. When the belt on the clutch begins to slip it makes a terrible noise. If the noise is gone when the brush roll is off you will have to take it to a dealer.
Jan 31, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson is just a standard DC14 that I have had for just over a year and it is makings a terrible noise. It had lost suction so I went online for advice and found that the belt had slipped off and also...
I'm sorry to hear you're having difficulties with your DC14. It's probably best if you get in touch with us directly, so one of our experts can run through some troubleshooting over the phone with you. They'll be able to determine exactly what's causing the noise, and to recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Sep 08, 2011 | Dyson Vacuums
My Whirlpool duet sport makes a terrible noise during spin cycle like drum hitting something or belt slipping. There are no error codes or smell of burning belt. HELP!!
the drum bearings are shot,you need to get them replaced,if the drum is actually hitting the sides if the tub this could be a broken spider thats on the rear of the inner drum that holds the drum on if this comes loose it can cause serious personal injury
May 29, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore series 80 model 11020892 fills with water --will not agitate or spin or empty water makes a terrible noise I need help!
Well the first thing is to check and see if the belt is broke on the drum (take the back off) or the belt is slipping ,hence the noise .Not a major deal but that is what it sounds like and that is good news because that is an easy fix. Get model and your nearest appliance store will have one. I probably won't empty water cause the other two cycles weren't working ,I'm pretty sure its the belt from what you have told me.Good luck! Oh and by the way it comes offf easy just undo the springs and well you'll see easy!
Mar 30, 2011 | Kenmore 24032\24036 Top Load Washer
My dryer (maytag atlantis) has started making a loud clunking noise with each revolution. its still drying fine but sounds terrible. any thoughts?
A loose belt will allow the drum to slip when clothes hit the paddles in the drum. It sometimes sounds like a pair of tennis shoes are in the dryer when it slips and is usually rythymic.
These machines also use drum rollers that can make a racket when they go bad.
http://www.repairclinic.com/Maytag-Dryer-Parts
Good luck.
Mar 02, 2011 | Maytag Dryers
2003 CTS 3.2L threw serpentine belt. Car made no
you bent a rod get the motor from someone other than dealer they will soak you
Oct 03, 2009 | Cadillac CTS Cars & Trucks
Dryer doesn;t spin
Sounds like the belt has broken. The terrible noise was probably the belt slipping until it gained traction.
May 17, 2009 | Dryers
Squeeky noise
I own a Frigidaire Heavy Duty Dryer The Model # is FDE436RES1. It is 10 years old. When running the dryer it makes a very loud squealing noise although the heat and the dryer still work. Is this a belt or roller problem or does it sound like something else. It is very high pitched and can be heard throughout the entire home. I do not know much about dryer troubleshooting so your help would be greatly appreciated. Thank You.
Oct 17, 2007 | Frigidaire GLER642A Electric Dryer
Dryers Logo
Top Dryers Experts
