Question about Garmin nuvi 1450 GPS Receiver
Your site says to remove the battery on my 1450 to do a hard reset. The 1450 has a non-removable battery !
  • tomgrimme136 Oct 10, 2010
    My Garmin NUVI will not boot. I have tried the reset method (holding down the power button) in the manual with no luck.
    The Fixya website says I should remove the battery, but the Nuvi 1450 does not have a removable battery. Help !
  • 11,800 Answers
Actually you can, just that it's harder than normal. See here
http://www.youtube.com/watch?v=SkfujctopKQ
And no, you don't need to buy anything, a blunt knife and a philips screwdriver will do.
Posted on Oct 10, 2010
    Brigadier General:
  • 3,513 Answers
No that's not the way. You need to press and hold the power button. Please check the page 10 of the use manual posted bellow.
http://www8.garmin.com/manuals/3130_OwnersManual.pdf
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
How do you change battery in garmin nuvi 1450
You don't. According to the manual, the battery is non-user-replaceable.
If your unit requires service, take it to the nearest authorized Garmin repair shop or contact Garmin directly.
Feb 16, 2012 | Garmin nuvi 1450 GPS Receiver
Tip
Garmin Nuvi 1450 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1450 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1450 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1450 Manual Download
Garmin Nuvi 1450 QuickStart Download
Garmin Nuvi 1450 Webupdate
Garmin Nuvi 1450 Favorites Backup
on May 27, 2010 | GPS
Tip
Garmin Nuvi 1450 Favorites Backup and Restoration Procedure Models: Nuvi...
Would you like to back up a copy of your Garmin Nuvi 1450 Favorites and Waypoints?
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
I hope that helps.
Freezes on 'loading maps,'garmin nuvi 1450
Try a hard reset,the Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  2. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  3. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  4. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
Then make sure the unit is fully charged,then go to the Garmin site and register your product. Then download Garmin Updater and connect your unit with a usb cable directly to your computer and not thru a USB hub. Let the update go directly to the GPS and not a folder. It will take a few hours even with a fast internet connection. I have attached a link to the Garmin site. Thanks for using FixYa
https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
May 04, 2011 | Garmin nuvi 1450 GPS Receiver
Tip
Garmin Nuvi 1450 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
on May 27, 2010 | Garmin nuvi 1450 GPS Receiver
Tip
Garmin Nuvi 1450 Favorites Backup and Restoration Procedure Models: Nuvi 1200,...
I hope that helps.
Lost Bios Password for Gateway Solo 1450. I have removed the CMOS battery for 5 min; that didn't work. Removed it again for an hour and that didn't work! I have tried all the back door pwds for the Phoenix...
From my experience there is no way to retrieve or remove a unknown hard drive (HDD) password. The bios passwords and windows passwords are no problem to remove, but the HDD password cannot be removed. Only option I know is to replace the hard drive. I have done this on about a dozen PC's
Dec 06, 2009 | Gateway Solo 1450 Notebook
How to hard reset my rim 7290
Not sure you can remove your call bar by resetting the phone - If this is company policy it is more than likely done through the network provider.
A hard reset will include the power cycle, power off removing battery, and power on.
If you have a reset button on your model - at the back or under the battery cover you can press this with a paper clip.
Apr 19, 2008 | RIM BlackBerry 7290
Garmin nuvi 1450 GPS Receiver Logo
1,078 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
