I have a Fujitsu FA-19W TFT Monitor with inbuilt speakers but can get no sound - the audio cable is connected correctly - when I go into my control panel is says no audio device installed. Do I need a separate sound card ? I am running Windows XP2000 - if I need a separate sound card - what do you suggest. There was no mention on the Fujitsu installation manual that a sound card was required. Your advice would be appreciated. Thanks
  • tempus1948 Oct 10, 2010
    Thanks - went to device manager - no yellow marks in sound, video etc., but several yellow question marks under 'other devices' - clicked on them all and a couple of driver updates were loaded - NVIDIA(R) then appeared under sound, video and speakers are now working - magic !
    Thanks for your help.
    President:
  • 1,932 Answers
Please go to computer properties and go to device manager.Check in the sound video and game controller whether there is a yellow mark in it.
Thank You
Posted on Oct 10, 2010
My viewsonic monitor is displaying the movie being played off my hp laptop but the sounds coming from the laptop. How do I get the sound to come out of the Viewsonics built in speakers?
Do you sure that your monitor has inbuilt speakers? if yes means you can get the sound by connecting sound output of the Laptop to the sound input of the monitor generally you need a 3.5mm audio pin cable at both the ends i.e the cable have 3.5mm audio male pin at both the ends
May 28, 2012 | HP Computers & Internet
H225W TFT;audio feed in monitor cable?
Since the monitor has a seperate jack (round, diameter 3.5mm) for audio in, the typical VGA cable doesn't include audio.Nevertheless the audio cable isn't so big (in diameter) as the VGA one.
Stelios.
Feb 23, 2010 | Computers & Internet
No inlet on my computer for my X223W LCD Monitors audio cord.
Is the monitor supplied with inbuilt speakers..? Most monitors no longer have inbuilt speakers and this is why there is no place to connect the audio cable. You will have to purchase a set of external speakers and connect these to the audio output of your system.
Dec 27, 2009 | Acer 22" X223w LCD Monitor
No sound out of my fujitsu siemens B17 . the setting on the screen is : Audio Volume 60% The realtek driver (sound card) is properly installed. When i connect speakers to my pc i have got sounds!
I do not want to offend you with simple comments, yet... did you connect the speaker connections from the computer to the PROPER socket on the monitor? There may be input AND output sockets that look the same. Also, on the monitor there is/are controls for the speaker volume from the monitor which is separate from the volume control on the computer.
I hope this helps.
Brock
Dec 13, 2009 | Fujitsu Siemens Siemens Basic Line B17-1...
I have a liteview moniter but when connected to my computer it has no sound is there somthing wrong with the comp or the moniter
Most monitors dont have built in sound so check for a sound connection from the monitor. Check the cable where it connects to the PC, if there is a small light stereo plug, stick it into the light green connector on the back of the PC tower. The standard video cable does not have the connections for audio. If you are using a HD monitor that has inbuilt speakers, try using the HDMI connector if it has one, this does have the audio inbuilt, Some DVI cables have inbuilt audio, some do not, look for small round 2.5 mm stereo plugs not connected into anything..
Oct 15, 2009 | Computers & Internet
Where do I plug in my new Technika speakers into on my Packard Bell desktop P.C.? there is only one cable (green) that will either fit into the back of the monitor (green audio jack) or only one green...
Ok, your speakers need to plug into the audio in jack on your pc, this is usualy found on the back of the motherboard. Like you said it will most probably be a green jack Most of the time its round the back of the pc. Its a good idea to have an audio file or something playing while you set this up so you can see if you get any sound.
Do you have sound on your pc normally? As it may be that your sound settings are not correct in windows
Go to the "control panel" and click sounds and audio devices
A menu will appear click the tab that says "audio"
Now look for the dropdown box under "sound playback" it should have something in it if its empty or says none click it and select something
Its also important to check the volume, do this by clicking on the volume button on the same page
make sure the faders are up
Realise it might be a bit complicated if you are new to pc's
any problems email me tim.otoo@gmail.com
The reason there is also a jack on your monitor is so that if you wish you can connect the "audio out" on your pc's motherboard to the "audio in" of your monitor and have sound come out your monitors inbuilt speakers
Jul 03, 2009 | Packard Bell Speaker Computer Speakers
No sound from my HP w1907 monitor
This is a failure in the audio section of the control circuit. Your cable could be at fault or the circuit itself. Try switching cables or try you monitor on a different sound source. if this does not work then it is the monitors sound circuits. This requires a trip to a service center for servicing. Hope this helps.
Apr 07, 2009 | HP w1907 LCD Monitor
Monitor INBUILT SPEAKER not working
The audio cable should be from your computer's Audio Out (Green) Jack to the Monitor's Audio In jack next to the AC connection.
If this solution has been helpful, please rate it. Thank you!
Oct 23, 2008 | HP L1908wm LCD Monitor
Sound
If your monitor have inbuilt speaker, then you need not to plug it, because the monitor cable will work for that. I have ViewSonic 19" with inbuilt speaker and its working without any extra cable or connection.
Thanks
Iqbal
Mar 23, 2008 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
