My hp printer doesnt print because it can not get paper from the tray sometimes all papers are taken by it from the tray yet it still doesnt print
  • 634 Answers
Make sure that the tray is properly in a way of paper insertion.
Make sure you have installed printer drivers properly.
Posted on Oct 10, 2010
My HP Laserjet 4L has started jamming paper when I try to print more than one page.
Here is some tips to avoid paper jam..
  • If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams, reduce the amount of paper you place in the tray each time it is filled.
  • Make sure you or the tray feeding the paper into the printer is aligned properly and the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
  • Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what paper you should use with your printer your printer documentation will list the paper compatible with your printer.
  • Do not mix the paper you're feeding into the printer at one time. If you need to change the paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
  • If your printer uses a slot or tray for the paper make sure to not push the paper too far into the slot or tray.
  • Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
**If you need any kind of technical assistance you can contact support cell at here
Feb 26, 2013 | HP LaserJet 4L Printer
I have a brother_mfc_9840cdw_laser_printer and get a message of No Paper reload Paper in tray, and I have taken out the tray multiple times and placed paper in, I am at a loss of what to do please help
IS the application you are printing from choosing the correct tray? That printer has multiple trays correct? If so try putting paper in another tray and seeing if it prints. If so you have the wrong tray selected when you print from your app. Also pull out all the trays and make sure you do not have a paper jam that you can not see. Sometimes paper jams will display as out of paper messages
Mar 01, 2011 | Brother MFC-9840CDW Laser Printer
My HP 610C printer yellow light is blinking after the paper is taken in. The power light is steady. Therafter the yellow light blinks continuosly. Please help.
Follow each of these steps until the problem is resolved:
  • Remove the paper from both paper trays.
  • Press the power button once. Wait a moment for the paper jam to clear.
  • If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  • Remove the rear access door.
  • Remove the paper jam through the opening at the back of the printer.
  • Replace the rear access door.
  • Reload the paper into the paper In tray.
  • Print the document.
Sep 29, 2010 | HP Office Equipment & Supplies
The printer doesnt recognize paper
HEllo sir; On the paper tray there have a paper senser, is out off track or defective.
May 25, 2009 | HP DeskJet 3940 InkJet Photo Printer
My All In One 6180 doesnt find photo paper tray
Works on my mac You need to check your print dialogue box more carefully This is operator error- or driver inkypete
Apr 15, 2009 | HP Photosmart C5180 All-In-One InkJet...
My HP laserjet 3600N wont print it says its out of paper but its not. Have taken paper out, added new paper, put less in, put more in but still says out of paper - any ideas please
The problem is underneath tray 2 - there is a plastic tab that sits on a metal crossmember that engages the paper tray to "pop up" when you insert the tray . If you bend that cross member up that has the plastic tab it will engage the tray and let the paper been seen by the sensor. There must be a better Hp fix but have not found it yet.
Mar 23, 2009 | HP PSC 1210 All-In-One InkJet Printer
6122 Printer says it is out of paper and will not print test page
Hi Ken,
The user manual says this:
1. Verify the following:
There is sufficient paper in the paper tray (at least ten sheets).
The paper tray is not overly full.
The paper stack is touching the back of the paper tray.
2. Slide the paper guides so they fit firmly against the edges of the paper.
3. Press the Resume button to continue printing.
Sometimes my printer won't print if it has too little or too much paper in the slot. It's a relatively common sensor problem.
Try that.
If all else fails, here's a link to the user manual in pdf form:
http://h10032.www1.hp.com/ctg/Manual/c00044028.pdf
Good luck
Chris (ziraffa)
Dec 22, 2008 | HP DeskJet 6122 InkJet Printer
Paper Coming from wrong tray for incoming faxes
press setup on printer select preferences and select default tray as 2 and try making copy and also check while receiving fax and also follow this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01096354&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Oct 01, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
24 people viewed this question
k24674
jasbo
jasbo
