Question about Plantronics Radio Communications
I need to pair my plantronics (voyager) earpiece with my new phone. I don't have my instructions anymore. I cannot get it paired up with my phone. How do I do that if I don't have the numerical code for the earpiece? I disabled it from my old phone thinking that was the problem, but still no luck
  • 1,527 Answers
Hello, . Press and hold the power button until the indicator LED flashes red/blue. The Voyager Pro headset is now in pairing mode. If you don't see the red/blue flash, press and hold the power button to turn your headset off, and then press and hold the power button again until you see the red/blue flash. try 0000 as the code good luck
regards
shaun
Posted on Oct 10, 2010
Testimonial: "Thanks Shaun! I did everything you said & now I'm connected/handsfree again :) You're the best!!!!! Christie Woods"
  • shaun taylor Oct 10, 2010
    great stuff glad to help thanks
    shaun
Can sync earpiece to base. Please help.
Here are the pairing instructions for your Plantronics Voyager 500A base:
On the base, press and hold both speak volume fine adjust buttons until the blue talk/on line indicator light and red power indicator light start to flash.
Now put the headset into paring mode that you will be using with the base.
Pairing is complete when the talk/on line indicator on base illuminates solidly.
Here is the link to the 500A user guide:
Plantronics Voyager 510S User's Guide
Good luck from Headsets Direct!
Jun 20, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Voager pro plantronics how to use with my cell phone set up connection
The pairing instructions are found in the link below for the Plantronics Voyager Pro+. Follow them closely, and you phone's pairing instructions, and you're good to go.
Plantronics Voyager Pro+ User's Guide
Jun 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
The red light and blue light in on permanently. The earpiece has been charged all night but when I push the earpiece to sync, the blue light on top of the base doesn't flash therefore no connection. Please...
Unplug the AC power from the Plantronics 500A base, leave it unplugged at least overnight if possible, no lights should be illuminated on the base. Then plug the power back in, charge the headset, and try re-pairing the headset to the Plantronics 500A base unit. Here is the link for the pairing instructions:
Plantronics Voyager 500A User's Guide
Apr 02, 2011 | Plantronics Voyager 500A Deskphone Adapter...
I have a samsung rogue and I all I hear is mostly static with the Plantronics Voyager PRO
Make sure that it has a good connection, try to re-pair the headset to your phone. Before running through the pairing process, be sure to totally delete the headset from the phone's menu. You may want the headset turned off for this process.
Once you make your cell phone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
Dec 25, 2010 | Plantronics Voyager PRO Bluetooth Headset
Cant set to my phone
Dec 13, 2010 | Plantronics Voyager PRO Bluetooth Headset
My new sony ericsson doesn`t see a new plantrosonic voyager. The blue topth is not paired with any other phones. Please help.
Please bear in mind that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove again the battery for a few seconds, then replace the battery and turn it back on again. Once you've done that, follow the simple instructions on the link below for the Plantronics Voyager Pro. Once you have your phone prepared for pairing, the process is pretty standard.
Plantronics Bluetooth Pairing Instructions
Dec 07, 2010 | Plantronics Voyager PRO Bluetooth Headset
Hello I am trying to install a new headset to my CS70 desk phone. The ruber earpiece on mine broke. How can I pair the new earpiece?.
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone, PC or other device for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your other device to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Oct 14, 2010 | Plantronics CS70 Wireless Headset
I am trying to pair my Plantronics Explorer 330 headset to my new phone, an HTC Eris. the phone does not recognize the device. Do you have any ideas?
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
Dec 21, 2009 | Plantronics Explorer 330 Headset
How do i put my 510 earpiece in the pairing mode
Press and hold the switch for about 30sec ...after that it will be in pairing mode ...and enter 0000 as passkey
Oct 20, 2009 | Plantronics 510 Voyager Headset - PLN-510...
Radio Communications Logo
2,055 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
