Question about Intel Desktop Board D845GLVA (BOXD845GLVAL) Motherboard
During setup on sata harddisk machine hang or setup not complete or showing NTLDR MISSING error
  • Intel Master
  • 27,725 Answers
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Oct 10, 2010
NTLDR is missing
Check your setup settings (BIOS) to make sure your booting from the correct drive. If the computer is trying to boot from the cd drive or USB, rather than the hard drive, you will receive this error message.
Dec 05, 2011 | E-Machines T5212 PC Desktop
Hi, I'm using Asrock P4I45GV R5 Motherboard. but when i attempt to install OS, it shows NTLDR Missing. but HDD is working properly. at the next time when i try to boot from the CD it fails. and i need to...
just go to in bios setup using F2 or del key and change the booting sequence.and set 1 cd-rom 2.hdd
now save and restart system now you are able to boot from cd rom r dvdrom
Apr 10, 2011 | Asrock P4I45GV R5 Motherboard
I have lost NTLDR and error is ntldr is missing press any key to restart
Vista doesn't use ntldr. If it's being called for, that means the mbr was
not overwritten to point to Vista's bootloader and it's still looking for
XP's. Check the system BIOS for a protection setting that disallows writing
to the mbr (bootsector antivirus protection is a common term for it). This
needs to be disabled during setup or Vista will not be able to alter the mbr
correctly.
Thanks for choosing Fixya
Sandeep
Mar 21, 2011 | Microsoft Windows Vista Home Premium...
NTLDR is missing is displayed when i turn on the computer
The "NTLDR is missing", error displays very shortly after the computer is first started; after the Power On Self Test (POST) is complete. Windows XP might only initially load when the NTLDR error message appears. Causes of this error message include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Get more help and information for Windows XP hope this helps you.
Mar 01, 2011 | Microsoft Windows XP Professional
NTLDR is missing problem
NTLDR is NT Loader program and corrupted or missing NTLDR will not allow you to boot up.
Keep your Operating system Bootable CD ready and boot your computer with CDROM. Follow below instructions to repair NTLDR
1. In Windows XP Setup menu press "R" to repair
2. It will show you windows to login (1. Windows )
press 1 and provide administrator user id and password.
3. one in command prompt you have to copy paste NTLDR file from cdrom to c:\ type the following command
Your cd drive letter you need to figure out. Here I am taking it as d:\
or make sure you below command runs by changing drive letter if not able to determine CD drive letter
copy d:\i386\ntldr c:\
Restart the computer and it should work.
Else, again boot from CD ignore Repair option to go in recovery console, and hit enter. It will show you the agreement . Press F8 to accept . Next screen will show you option to repair to continue to fresh installation.
Here press "R" to repair. Not sit back it will take time to repair complete system.
Hope this helps
Jun 10, 2010 | Compaq Armada M700 Notebook
NTLDR missing
For NTLDR missing error you need repair your windows .
For that you need recovery disk or bootable winxp disk.
Then boot it with disk.
Enter in bios and set first boot device as your cd or dvd rom then put disk in it then follow the procedure to repair it.
Aug 08, 2009 | ASUS K8N-DRE/SATA NVIDIA nForce 2200...
NTLDR is missing
Reference number: CH000465
NTLDR is Missing. Issue:NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Cause:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
You can go to these sites to view solutions (to much to post here) Very easy to understand:
http://www.computerhope.com/issues/ch000465.htm
May 22, 2009 | E-Machines eMachines Desktop PC
Bios not detecting bootable harddisk
Repair windows xp using bootable windows xp cd..
Mar 09, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
While installing window xp setup shows ''harddisk drive is missing
You need to go into BIOS and turn on normal SATA, in order to install XP.
Jan 03, 2009 | Computers & Internet
Ntldr
First check your bios & make sure it see's your hard drive & it's setup correctly. If it is there could can be other reasons for the missing NTLDR.
Suggest you take you Windows CD and boot to it. If your CD does not boot. Re-start the PC & start pressing the F8 key every two seconds. This will bring up a boot menue. Choose your cdrom drive.
Once in the Windows XP setup menu press the "R" key to repair Windows. Log into your Windows installation by pressing the "1" key and pressing enter. You will then be prompted for your administrator password, enter that password. Copy these two files to you Hd. copy e:\i386\ntldr c:\
copy e:\i386\ntdetect.com c:\
Replace the drive letter listed above for your cdrom's drive letter.
Once copy has been complete re-boot your Pc.
If you still get missing NTLDR. Do a complete reinstall of windows. Your personal data should stay intact.
Please post back if this has not fixed missing NTLDR, there are more fix's that can be applied. I only listed the most common.
Feb 12, 2008 | AOpen Motherboards: AX4SG-UN (AAX4SGUN)
Intel Desktop Board D845GLVA (BOXD845GLVAL) Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
