Question about Dryers
I own a Hoover 5050ED Dryer and need a manual. Where can they be purchased?
  • dlkirkpatric Oct 17, 2010
    Yes thank you. It was great to have such a prompt answer
  • 10,319 Answers
I can not find a manual for you but here are instructions how to operate it
You can set your dryer to dry clothes automatically.
Just press start and it will dry on the normal temperature until it senses that the clothes are dry.
If it keeps stopping, it means it thinks your load of drying is dry. Check the load and take out any dry clothes before continuing the auto dry.
If you are still unhappy with the auto dry, you can manually select a drying temperature and duration. Press Manual, and press Select until your desired temperature is lit, then press Accept. Then press Select to move the duration, then press Accept once happy with it. Then you can press start and your dryer will carry out those instructions.
Posted on Oct 11, 2010
4 Suggested Answers
SOURCE: Hoover 5050ed clothes dryer/tumble dryer
Hi, I have had one of these dryers now for about 5 years and it has worked flawlessly. I only ever just let it work in full auto mode - basically put the load in, close the door, press in the door button, then press start on the panel. Never bothered to do anything else, it just works. cheers
Posted on Jun 12, 2008
  • 147 Answers
SOURCE: Needing Manual
do a search on googles for your model (include the word manual) and Ill bet many will come up. Most of the time you can get a operation manual at the company web site..
Posted on Sep 24, 2008
SOURCE: Can't get the dryer to work! - Hoover 5050ED Heavy Duty 5.0 Kg Auto Dry Plus
ditto and exactly 2 years later! Someone please help!
Posted on Mar 03, 2010
HOOVER AUTO DRY 5050ED KEEPS STOPPING
hi there, I have repaired many of these dryers. It will be a faulty heater element, most likely. They cost about $40. If you get a tradesman to fit it, they will prob charge you about $200 all up. Maybe its better to buy a new dryer for around $300? Good luck.
Lance in brisbane.
Jun 17, 2012 | Hoover Dryers
5050ed buzzes onstart up ,needs little manual turnover to start
it can be the idler pulley that tightens the drum belt,the drum belt itself has gotten old and glazed from age,or the motor that turns the drum the bearings can be getting dried out from age and heat and getting tight requiring help to start,also the motor start switch on this motor can be getting bad contacts inside this switch,all these issues require you to dismantle the unit to some extent to check them
Jan 29, 2011 | Hoover Dryers
User manual needed for Hoover washer/dryer
Hi.
In you browser box type in Hoover user manual.
Then scroll down to Hoover after sales service instruction manuals.. Click on this, and then on Laundry.then on Waher -dryers, follow instructions
You will find your model listed there,.
Please leave good feedback.
Thanks
Nov 29, 2008 | Hoover Washing Machines
Fitting the belt to the hoover 5050ed
nope,, but
all dryers are generically the same
remove the front panel and door
pull the drum
loop the belt around the drum, at apporximately the wear marks of the old belt
reinsert the drum
loop the belt around the motor pulley
pull the tensioner pulley hard against the spring to the end of its travel
loop the belt around the tensioner pulley
allow the tensioner to move back under spring pressure to tension the belt
rotate the drum by hand to make sure the belt is aligned and not coing to jump off the pulleys
reinstall front panel & door
26740a0.jpg the tensioner may be on the bottom belt run pusshing up, or the top run pulling down
breaking belts sometimes pull the tensioner out of its mounts, there is only one place that the tensioner will reinstall.
Its a standard whirpool dryer, rebadged as hoover, so the local parts guy has the belts rollers felts and glides as necessary, they are common to all the dryers whirlpool makes.
Oct 01, 2008 | Whirlpool LER4634J Electric Dryer
Needing Manual
Sep 23, 2008 | Dryers
If the dryer hasn't been mounted before, you'll need to punch the blank slots through. At the bottom of the dryer (because you wall mount it up-side-down, so these slots will then be at the top), you'll see a vertical hole in one layer of the metal on the back to each side. Knock these through to reveal the holes where the bracket can go in. You'll also want to replace the control panel decal with the wall mount one that has all the controls up the correct way when wall mounted.
Jun 04, 2008 | Dryers
Mar 03, 2008 | Hoover Dryers
Dryers Logo
2,512 people viewed this question
Top Dryers Experts
