Question about Dayton D-F79 Electric Space Heater- the Ideal Choice for Garages, Workshops
Hello im tryin to wire a dayton model 2yu68 unit heater 208v .30 amp bbreaker with 10 awg 3 wire and simple thermostat and still wont fire up
Are you using this heater for a residential application? 208V is typically only seen in a commercial/residential setting. It would be unusual for a home to be wired in what they call 3 phase which is how a 208 voltage is obtained.
Hope this helps. I would strongly advise that you consult with an electrician as 3 phase voltage is not for the average DIY'r.
Posted on Dec 28, 2010
  • wgrochowski Dec 28, 2010
    Sorry. I meant 208 voltage is typically seen in commercial/INDUSTRIAL settings and not in residential.
Wire a dayton 4lz94a thermostat for turning on a gas fired heating unit?
If the unit has a switch that does fire it up when turned on. using the same gage wire, you can make an addaptor with an extention cord buy cutting just the black wire ing the extention cord and hooking the black wire from the male plug side to the line in side of the thermostat and the black wire from the female side to the load side of the thermostat..
Feb 12, 2015 | Dayton Heating & Cooling
Need to know what size wire to use to wire up a DAYTON GARAGE HEATER model 3UG73 10/2 or 10/3NM to a 30AMPS circuit?
You want to use the 10/3 wire... the red and black are the hot, the white goes to the nuetral and the green/bare wire to the ground.
Use a 30 amp 2 pole breaker..
Heatman101
Feb 24, 2010 | Heating & Cooling
Unit comes on and runs for 5 minutes, the circuit trips off
30 is the correct size breaker for this unit. It sounds like there is a grounding issue going on in the system. Or off of the Thermostat. Something is grounding out causing the switch to trip. Are you running #10 wire to breaker and the unit? If not you will need to increase your wire size
Jan 03, 2010 | Dayton D-F79 Electric Space Heater- the...
Just installed new steam shower, it produces steam for about 5 minutes and then blows the fuse
Based from your comments, a new steam shower that blows the fuse in five minutes. You could have installed a new steam shower that is much bigger than what you previously have.
1. For a 5000 watts steam shower at 220 volts
power must have a fuse rating of 40 amps, supply
wires of at least No. 6 AWG Type THW ; and at
110 volts a fuse rating of 80Amps, supply wires
of at least No. 2 AWG type THW.
2. For a 4000 watts at 220 volts, Fuse: 30 amps,
Supply wire: No. 10 AWG type THW. At 110volts
60 amps, Supply wires : No. 4 AWG Type THW
3. For a 3000 watts at 220 volts, Fuse: 20 amps
Supply wire: No. 10 AWG type THW; At 110volts
Fuse: 40 amps, Supply wire: No. 6 AWG THW
4. For a 2000 watts at 220 volts, Fuse: 15 amps
Supply wire: No. 10 AWG THW and at 110 volts
Fuse: 30 amps, Supply wire: No, 8 AWG THW
Nov 27, 2009 | Hammering
How do you wire a dayton electric unit heater? Model-3e030,watts-15000, phase-3, motor amps-22, motor volts-120, heater volts-480, listed air heater-492b, cycles-60 ac.You have a...
red, white, and black will be your high voltage. Green will probably be for ground and yellow and orange go to the thermostat. I can confirm on Monday when I have access to manuals.
Oct 04, 2009 | Dayton Electric Heater
Problem wiring 240amp baseboard heaters
12 gauge wire sounds under sized for the application. And 20 amp 240 v breakers might be sufficient if you where wiring the heaters separately. But be sure that your wiring is not romex - because romex is an insulator and is not permitted in conduit. I would suggest that you up size your wire to 10 guage and your breaker to 30 amp as well. Then double check your heater wiring connections to insure that they're wired the same throughout.
May 03, 2009 | QMark FBE15002 electric baseboard heater...
Dayton 3ph 208V heater # 2yu72 not firing off - WHY?
I assume you mean its not Heating by not firing? If its 3 phase you may have lost 2/3's of your heat not just 1/3. Look at the safety's and find if 1 or more are open. Also there is a fuse able link on most elements and if you have had the heater try to run without a blower lately (or anytime in the past) the link may be out. These are usually installed where they "see" the heaters. If you have power to all the elements look for this or a bad element(s).
If your contactor is still not pulling in check for open safety's or bad timer.
Jan 20, 2009 | Dayton Electric Heater
Thermostat not firing central heating
the stat works using a bi metalic strip so that click you here is making a contact and telling the boiler to call for heating so if you getting no click you need a new room stat. Replace with same model and note the wiring most stats only use 2/3 wires depending on system
Dec 08, 2008 | Dayton Electric Heater
Dayton D-F79 Electric Space Heater- the Ideal Choice for Garages, Workshops Logo
220 people viewed this question
Top Dayton Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Dayton Pool and Spa Expert? Answer questions, earn points and help others
