Question about Coralife Zilla Aqualight Power Center
I dropped half my light in the tank should it still work if I dry it out?
  • 4,340 Answers
Usually yes, completely dry. Open up if you need to and blow with hair dryer...but let it sit 24 hours to be sure.
Posted on Oct 10, 2010
1999 PLY GRND VOYAGER GAS GAUGE WOULD NOT READ GAS AFTER HALF TANK, JUST REPLACE THE WHOLE FUEL PUMP AND STILL NOT FIX
You forgot to mention the FLOATER in your tank,To do this, you have to drop the tank but be extra careful you're working with gasoline.De-pressurised it first before you start. Oh yes, disconnect battery.!!
Dec 09, 2011 | 1999 Plymouth Grand Voyager
2000 Mitsubishi diamante runs great till weather turned cold now having problems with idle dropping at lights and dying. New plugs and wires new battery cables and wires and good battery. Need opinion
  • This will happen to a lot of people as the weather begins to cool. I suggest making sure you get gas from a reputable service station for one. Just as important make sure to put a bottle of HEAT in your tank with every fill up(half a bottle for half a tank fill up on fuel).
  • What happens is there is already a certain amount of water no matter where you get fuel from as the storage tanks have a lot of water in them. That alone with the colder weather makes for rough starts and at times poor running conditions in the colder months because water freezes and makes the gas hard to pass through to the injectors and greatly effecting the engine firing properly. Heat will dry this water up and make your fuel flow much easier and burn a little better too.
  • Try this and you will notice a difference. Just about anyone will during the colder months.
  • Hope this helps.
Nov 03, 2011 | 2000 Mitsubishi Diamante
MY 90 BIRD WILL NOT RUN UNLESS I POUR FUEL IN THE INJECTORS MYSELF.once the fuel runs out it dies
Is there gas in the tank? Many GM fuel gauges have shown half-full when in actuality, the tank has run dry. Check injector circuits with a noid light or regular test light to see if the light flashes. If the light flashes, but the injectors are not spraying, check fuel pressure with a gauge. If no fuel pressure, ensure that the fuel pump fuse is not blown (many GM cars have the fuel pump fuse in an inline fuse holder) If the fuse is good, check that the fuel pump is receiving power and ground (positive and negative) If it is, and there is still no fuel pressure, the pump is bad, and the gas tank will have to be dropped to get the pump out. Good Luck.
Aug 21, 2011 | 1990 Pontiac Firebird
Gas gauge stays on full
very common. The sender in the gas tank is the problem.
It will need to be replaced some day
Both my gas tanks do the same thing in my F250. 1 tank stays full all the time and the other drops from full to about a half tank when I get to half a tank and then works so so till empty.
Dec 22, 2009 | 1992 Pontiac Firebird
Gas gauge is not reading correctly. Shows a full
the problem is caused by a defective gas gauge sending unit, this part is located inside the gas tank, you must remove the gas tank to replace it.
Dec 02, 2009 | 2002 Cadillac Deville
Fuel gage drops to e after half tank fuel gage
Hi
Faulty fuel sender unit located inside fuel tank.
Regards
Phillip
Oct 16, 2009 | 2005 Chrysler Pacifica
Contaminated petrol in mercedes clk230
Disconnect the fuel inlet line at the fuel injector supply rail and bypass the fuel pump relay, make sure u have a container made of plastic to catch this gas in or a grounded to car metal one, do it outside, there is always a grave danger of explosion from gas fumes when u are doing this, if u know the gas station who sold this fuel to u make them pay to have it drained.
Mar 12, 2009 | 2000 Mercedes-Benz CLK
Fuel gauge drop to empty
Sounds like the gas tank sending unit went bad.
Mar 11, 2009 | 2003 Jeep Liberty
Main fuel gauge
the sensors on the float go bad its on your fuel pump youd have to replace the whole unit
Oct 04, 2008 | 1983 Toyota Land Cruiser
Coralife Zilla Aqualight Power Center  Logo
53 people viewed this question
Top Coralife Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Coralife Hardware and Accessory Expert? Answer questions, earn points and help others
