Question about Sony KP-61V45 61" Rear Projection Television
Sony kp-61V45 will not power on but you can hear static coming through the speakers. The power button will not light up
  • 597 Answers
The problem with the television is from the power panel of the television, it is receiving power but not getting it to the main panel of the television so as to power the screen that is why you are having the static sound from the speaker of the television.
Once you can replace the power panel of the television, your television will be in good condition once again. You can locate the power panel, it is the panel the power cable is connected to, so once you open up the back of the television, then trace the power cord to the panel it is connected to.
A replacement will do the job.
Take care
Posted on Oct 10, 2010
Sony kp-61v45 how to change projection lamp? my tv does not have a picture. however the sound is normal and can change channels. from my research it appears I need to change the lamp. however have no clue...
You Do Not have a Lamp in this Model it is Projection and has 3 Tubes R/B/G Tubes
You need to Check the Hori output Transistor and a small blue capacitor 2k it is a high voltage capaciotr that feeds to the Hori output.
Their is No Tubes avilable for this model you have to ship Bad Tube and have it rebuilt, another thing if you had a Bad Tube which ever one is bad Set would come on with that color of drive lines across the TV.
Jun 30, 2011 | Sony KP-61V45 61" Rear Projection...
So how much is the power panel for a kp-61v45
A power panel goes for about $200. You can get it from an electronic sgop that also deals in parts.
Take care
Oct 10, 2010 | Sony KP-61V45 61" Rear Projection...
Sony KP-57WS500 57 in. Rear Projection tv When I press the power button there is no picture but the "timer / Standby" light flashes. Sometimes when pressing the power buttonthe light flashes and I hear...
CK your hori output Transitor and behind it is a blue high voltage capacitor 2k sometimes they will have small burt hole on them ,If it is OK then Replace your STK ICs example STK392-110 Mats has them 1-800-628-1118
Feb 15, 2010 | Sony KP-57WS500 57" Rear Projection...
Continuous blinking red light
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
May 25, 2009 | Sony KP-61V45 61" Rear Projection...
Turning off PIP on KP-61v45
have you try menu options if this does not work U need original remote
Dec 13, 2007 | Sony KP-53S35 53" Rear Projection...
I had this problem with a universal remote.I tried everything you can think of.Finally I got it.I hit the setup button on top of tv and the volue down button to start the demo.I dont know exactly how long it ran but after awhile I hit a button and screen was normal...Yeah
Mar 10, 2007 | Sony KP-61V45 61" Rear Projection...
Picture in Picture Issue
hit the pip button again it should shut it off
Sony Color Rear Video Projector- KP-61V45
You have already diagnose the problem,the set has a loose conection in the high voltage area or horizontal drive circuits but dont be suprize if you find more loose conections or overheated areas,while you are looking for this loose conection giving you this problem take the time and correct any other questionable spot.If you are familiar with tv service this will give a place to start but if you are not too familiar be safe and call for assistance from a servicer,it should not be expensive.Let us know if youu need more help.
Oct 12, 2006 | Sony KP-61V45 61" Rear Projection...
Televison & Video Logo
75 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
