I have a diamond tv and its loosing the screen,its becoming smaller each and every day. how do i fox it.
  • 597 Answers
The problem with the television is the lamp. It is faulty and needs replacement. Once the lamp is replaced the television will be in good condition once again.
Another problem can be the t-com board of the television, so whichever you find to be faulty, all you have to do is replace.
Good luck and take care
Posted on Oct 10, 2010
Cheat cheats codes
For what you need cheats?
The most important element in Hay Day are Gold and Diamonds. If you have plenty of Gold and Diamonds then you don't need any cheats.
So I would suggest you to earn Diamonds and other necessary elements require in the game.
To get diamonds faster you can check this website: http://irongaming.tv/
You can get as many diamonds and golds you want for free.
May 06, 2014 | iPhone Apps
I have a 73" mitsubishi diamond edition tv and
this is when dmd (digital mirror device) ic begins to fail. these dots will become more numerous until they fill the screen. replacement of dmd board will solve
Sep 27, 2011 | Televison & Video
Sansui tv sv2118 screen getting smaller from bottom (picture is shrinking smaller from bottom)
hit your TV on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board ( also on CRT circuit board ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or abnormal width, or rolls etc ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears normally for some time............so solution is .....TV main board & CRT circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again ................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer .............iam from bangalore -( computers, laptop, printers, etc )
Jun 08, 2011 | Sansui Televison & Video
After we have switched the TV on a dark line appears around the edge of the whole screen and then it gets bigger and bigger making the picture smaller and smaller - is there a simple solution please
hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size or abnormal width,etc ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting monitor lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again ................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer .............iam from bangalore - 09986222774 - sathyavijayasarathibabu@ymail.com ( computers, laptop, printers, etc )
Apr 25, 2011 | Panasonic Televison & Video
Mitsubishi vs-60607 60" screen is
when picture is getting smaller in size or goes away or moves towards one side then hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 22, 2011 | Mitsubishi VS-60607 TV
The screen seems like its fixing to go out! The picture starts off normal size then gets smaller and almost goes completely away!
when picture is getting smaller in size or goes away then hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some CRT computer monitors & CRT TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size & disappears...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re- soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 16, 2011 | Disney DTD1363-CAR 13" TV/DVD
My tv screen becomes smaller and then becomes normal with a sudden shock for a sec.
that is the symptoms of cold solder of circuit board. please apply fresh solder into your tv circuit board. please refer a qualified person if your not quaified or expert. beware risk of electricity.
Aug 14, 2009 | LG 32LG30 32 in. LCD HDTV
Will NOT acknowledge one channel
This problem was already posted by someone else and they were having the same issue as you.. they said that they contacted FOX engineers via email and they emailed them back stating there was a problem on there end and with in the next day the channel started to show up on the Olevia television.
Seems like FOX has changed there frequencies and some television were having trouble picking them up.. depending in the area..you might want to try contacting them in regards to your problem to see what they suggest..
Jul 10, 2009 | Olevia LT27HVX 27 in. LCD Television
I want to make the "time" smaller on my home screen
Try sweeping your thumb upwards on the clock this should drop the larger boxes back and bring up a smaller clock. It worked on my HTC Touch Diamond hope it helps
Jun 12, 2009 | HTC Touch Diamond Smartphone
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
