Question about LG DLG5988 Stainless Steel Gas Dryer
Horrible noise When I start my dryer it makes a horrible noise like the bearrings are out...also the sensor does not work...clothes are sopping wet when the machine stops...
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
The noise could be coming from the blower housing, as this unit does not have bearings, it does have 4 rollers however. If the unit is working on timed dry and not sensors there may be a problem with them. Check your venting though, if it is too short it may not have enough back pressure for the sensors to operate properly. This could also cause your thermosats to blow, the one is a manual reset, either way you are going to have to get a gas tech out there.
Sgt 48
Posted on May 30, 2008
Spin cycle not working.
would make one think perhaps the timer or control board needs serviceman to fix
May 11, 2015 | Washing Machines
My washer/dryer combo Frigidaire washer dosn't spin water out of clothes completely after spin cycles the clothes is still very wet. On the 1st spin cycle drum dosn't spin just makes noise,the 2nd and...
Good Afternoon Friend,
I understand your Frigidaire laundry center, model# FGX831CS, is not spinning water out of your clothes completely. I see that on the first spin cycle the drum is not spinning and is just making noise, and on the second spin cycle the drum spins to the left very slowly and loudly. First check to see if your washer is overloaded. Try taking some clothes out and spinning them again. Secondly, make sure that the load is not out of balance. Try rearranging the clothes to allow for proper spinning. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 19, 2014 | Frigidaire FGX831CS Top Load Stacked...
Have a year old Whirlpool Ultimate Care II. After wash is spun and load is done the clothes are still sopping wet. Tried extra rinse but that doesn't help. Afraid of damaging dryer when putting clothes...
Check to make sure a nail has not gotten stuck in one of the hole in thew bottom of the drum. Check to see that no article of clothing has gotten jammed between the tubs or the top.
Dec 03, 2010 | Washing Machines
Loud noise when on spin cycle. Kenmore front loader. Cloths still sopping wet
This is a common problem on this machine Your rear bearing is bad and requires outer drum and bearing kit.not worth fixing buy a new machine.hope this helps.please rate my response :)
Dec 09, 2009 | Washing Machines
Roper top load washing machine #8280871, worked well for a little while, now clothes are sopping wet and it will not spin or do anything after it rinses. Help, what part do I need to fix this?
If it is making noise when it is supposed to be spinning or agitating there is a coupling made of plastic with rubber flex joints on both sides replace this and should start working again 1195967 is the part # usually run 15-20 bucks
Nov 15, 2009 | Washing Machines
I have a LTF2940ES1 horrible noise and wet clothes
you ahve a clogged pump
remove the toe kick
the pump will be right there on the right
get a towel and disconnect the hoses
you will see a sqaure sump take that hose off
and clean it out
check to make sure there is nothing in the pump
reassemble and should be fine
Oct 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Dryer making horrible squeeling noise
this is normally a problem with rollers that have gotten dry bearings , take the drum out check the rollers if they turn hard or act sticky you may clean them up and and oil with turbine oil , do not use wd-40 or 3in 1 as these will dry the bearing, check the idler pulley while you have this apart also oiling it if need be
Dec 30, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Clothes are still sopping wet when finished
If your clothes are wet after the wash it is quite possible your outlet filter is blocked. Check this out and clean out. This requires periodic cleaning, according to your usage. Refer to your user manual.
Aug 28, 2007 | Malber WD1000 Front Load Washer/Dryer
Machine runs, but clothing won't dry
It sounds like your heating element is shot. The elements on this machine are very sensitive and if you use too much cleaning fluid the part will wear down after a while. You will need to get the part replaced (yuck) and start to use a little less washer fluid. Please let me know about your experience with the company (danfrogel@yahoo.com)
Sep 16, 2006 | Malber WD1000 Front Load Washer/Dryer
LG DLG5988 Stainless Steel Gas Dryer Logo
75 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
