Question about Hamilton Beach BrewStation 47214 Coffee Maker
Leaks after coffe dispenses
After you get your cup of coffee it seems to leak and I have replaced the little seal where the coffee is dispensed through. We love this coffee maker but some times when I check back to see if there is coffee in the pot I find a huge puddle of coffee all over the counter.
  • jack79 Jun 19, 2008
    cleaned pot put in new seal,,,,,,,,,,,,,,leaks more than before,,,,,,,,,,carefully ckeck all parts
  • Anonymous Aug 10, 2008
    I've had the coffeemaker for about 8 months and it is now a slow leak, even with a new seal, in every possible position the seal sits. I think the spring that holds the seal tight must have worn out. Made great coffee but ... It's not worth the mess at this point.
I've found that the reason is usually because the "coffee tank filter screen" is sitting crooked in its placement and causes the valve to be propped open. But with boiling hot coffee in the tank, it's hard to fix. Sometimes we can tap it with a butter knife and it will sit back into place, and sometimes we've drained all the coffee into a pitcher, waited for the plastic parts to cool, repositioned the filter, and put the coffee back in and turned the pot back on. Depends on how far the valve is propped open and how quickly the coffee is coming out. Hope that helps! :)
Posted on Jun 11, 2008
    Problem Solver:
  • 7 Answers
I just got the heavy dripping problem started this problem. This happened after my wife made the coffee and switched from brown filters to while filters which (as expected) ripped apart when she tried to dispose of it and spilled into the machine.
Here is the solution that worked for me:
Hold the coffee reservoir upside run warm water through the hole which coffee gets dispensed through. While doing this push and pull the little lever back and forth for about 10-15 seconds. This will clear out the coffee grinds stuck into the seal area and you will get a proper seal gain and leaking will stop. Well at lease this fixed my problem. If you have a loose spring in the same area on the other hand (Which I find surprising based on how much use this spring would get for home use) this will not help you. Good luck.
Posted on Aug 23, 2008
Hello, i have a krups xp7220 and i have two problems with her.
A common place for a leak under the machine is the barista seal that goes in the bottom of the boiler around that eject rod. Barista seal part number is MS5002202, Seals on the tamping piston are MS5002040 (there can be 1 or 2 of these piston seals) If fixing the leaks does not fix error 6 then I expect it will end up being the distributor. Part number MS2A01500
Jun 17, 2017 | Krups Coffee Makers & Espresso Machines
Coffee leaks out of the top gasket where the coffee comes out.
Use and Care guide can be found here. See Page 10 for Troubleshooting.
PROBLEM:
Coffee leaks from dispenser.
PROBABLE CAUSE
• Coffee grounds trapped in coffee tank dispensing mechanism under seal in coffee tank.
See "Cleaning with Vinegar." Refer to page 9.
Jan 31, 2011 | Hamilton Beach 48465 12-Cup Coffee Maker
I need a new cup for my coffe maker!
If you mean the carafe, you're out of luck getting the original. A company called focus electrics handles replacement parts for this brand. Their parts page for this model lists nothing at all.
If you need a new carafe because yours is leaking, join the club. This seems to be a pretty common problem. You can try tightening the screws holding the gasket to the bottom.
If you don't mind losing the one-hand dispensing feature, you might try a universal replacement carafe which may fit. These are usually found with the coffeemakers at retail stores. Or you can buy a new coffeemaker. Sometimes the difference in price between parts and a new machine is pretty small.
Good luck, and thanks for using Fixya!
Feb 13, 2010 | Back to Basics CC500 12-Cup Coffee Maker
Coffee is coming out all around the coffe dispenser and very little through the dispenser.
brew unit filters are blocked. take out brew unit, remove screws and clean and replace stainless steel filters.
Jan 27, 2010 | Miele CVA615 Espresso Machine
Gaggia Titanium dumps ground coffe inside unit
Hi
You have 2 knobs in the bean hopper. The small one is set to the most positive. Turn it back 1 click from the plus and that should take care of your problem. When you have a clean brew unit it will make the first coffee but a little coffee is left in the brew unit and when it tries to make the second coffee a full charge and the little that was left cause an over charge, and dumps the coffee without making anything.
Jun 17, 2009 | Gaggia Titanium Espresso Machine
Out of 10 cups of coffe maybe i get 4 cups
Try to make a cup of water (the) and see if you can make a full cup.
Try to take out the brewing unit (central unit) and wash it in warm water.
/Best regards
/Mirran
Jan 29, 2009 | Saeco Incanto Classic Espresso Machine
Leaks when dispensing
I think I just pulled off an effective fix on mine... went from leaking all over the counter to no leaks in the last three pots.. not sure if we have the same model.. in fact I don't even know what model I have... it's a plain white unit with a singe button. Anyway, here's what I did:
  • Remove the bucket
  • Turn bucket over
  • On my unit, the bucket itself is mounted inside of the white outer trim, and the assembly is held together by four recessed phillips screws. Remove those four screws and seperate the bucket from the outer shell.
  • Reach into the bucket and pull the rubber gasket seal from the dispenser.
  • On the bottom of the bucket, raise the dispenser lever until the spring pops out.
  • Stretch the spring a bit.. not too much, you want to be able to put it back!
  • Clean the gasket seal and the gasket seating surface.
  • Put it all back together :)
The stretched spring causes the gasket to seal more tightly than it did before, and in my case, stopped the leaks.
Oct 31, 2007 | Hamilton Beach BrewStation 47214 Coffee...
Hamilton Beach BrewStation 47214 Coffee Maker Logo
321 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
jason
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
