Question about Refrigerators
I am having water condensation on glass door cooler
    President:
  • 1,891 Answers
If mosture is building on surface / ck the defrost system / and the drain. either may cause this .. mm
Posted on Oct 10, 2010
Why is my beverage air cooler door glass frosted I can't see the display through it.
Excessive moisture is inside unit and has condensed on the warmer glass surface. Wipe it off and keep door openings as short as possible especially during hot , humid weather.
Try putting some rain X on the glass - water will bead and run down glass instead of collecting.
Sep 03, 2017 | Refrigerators
Glass door has condensation outside and slightly inside. 75bev
That would be normal if the day is very humid. Any cold surface will change the water in the air to a liquid. Like steamed up glass when you shower.
Aug 20, 2016 | U-Line 1175BEV Beverage Cooler
Causes of Presence Moisture in Microwave Door
Air from inside the oven is getting by the seals around the inside glass and condensing on the cooler outside glass layer.
Feb 10, 2015 | Whirlpool MH1150XM Convection/Microwave...
Reason of Moisture Presense in Microwave Door
Feb 10, 2015 | In Microwave Ovens
Glass in over the range microwave fogged up after boiling vegtables on range top
It will do. The glass is cooler than the water vapour and will condense, causing fogging.
Mar 28, 2011 | Samsung 1.8 Cu. Ft. Over-the-Range...
Condesation build up between glass in door... I get condensation build up between the glass in my whirlpool WFG374LVb oven ...whirlpool said that is normal...is that true?
Yes, while the glass is still relatively cool. Many oven doors today have access slots on the bottom of the door to enable you to clean the inside of the glass window. Steam can enter the door at this point and condense on the cooler outer glass.
Feb 24, 2010 | Kitchen Ranges
When I use the convection oven, the glass door totally steams up....is this normal? I don't remember it doing so when it was new, but maybe it did. The condensation is between the glass on the oven door...
It is not normal for this to happen. The seal must be perished or worn allowing moist warm air to come into contact with the cooler outer glass thus condensation is forming on the inside.
It is not a major issue as it will depend on the moisture content of what you are cooking but it will obviously prevent you seeing inside when it occurs.
It is one of those minor irritating things that can happen.
The only way to solve the problem long term is to have the thing resealed as normally it is a mastic seal rather than fibre one.
Jan 22, 2010 | GE Profile JKP18 Electric Single Oven
EVERSTAR COOLER HDBC36ID
Mine is 11 months old - pooling water on right (which is theside i keep colder for beer/soda/water), also my glass door on right has water between panes, I just called franklin (everstar) and they say a service guy will call in 5 days... I hope.
Did you get help and are you 'happy' with the service done?
Jun 22, 2009 | Franklin Industries FBC360D Beverage...
Magic chef wine cooler
That means couple of things. The cooler's glass door is poorly insulated, and the cooler is placed in a humid environment. To eliminate the sweating you can run a dehumidifier close to the cooler, or you can insulate the inside of the door with styrofoam but that's going to spoil the look of the cooler.
Aug 28, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Water has penetrated inside the door
Any water in between the glass and the door should evaporate eventually.
I wouldn't advise trying to open any seams in the door or removing the glass to get the water out as that would permanently damage your microwave.
Your models manual talks about steam/water condensation that gets trapped between the door and the glass and what to expect:
http://www.fixya.com/support/p113437-emerson_mw8107wa_1000_watts_microwave/manual-11318
Dec 26, 2007 | Emerson MW8107WA Microwave Oven
Refrigerators Logo
222 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
