Question about Casio 76 Key Smartmedia Keyboard
I need to find replacement keys D-F-A for WK3700... Where can I go?!?!?!
    President:
  • 1,138 Answers
Try this link:http://www.casio-europe.com/euro/support/repair/emi/ Hope this helps.
Posted on Oct 13, 2010
How do I get into the keys of my Clavinova 409 - they're sticking
Firstly take a look at the keys that are sticking. Are they leaning slightly to the left? The gap on either side should be equal, you should be able to slide a business card freely into the gap.
If they are leaning to one side it is a sure bet that the key has broken on the fixing under the bank of switches.
You will need to dismantle the keyboard and remove the broken key ( and the bit that has probably broken off ) and replace it.
Replacement keys can be found at www.beckettsmusic.co.uk if required. If you need further assistance contact via the links on the site.
Dec 22, 2014 | Music
How do I replace one key?
You will need to gain access to the keybed, remove screw from back of keybed the fix it to the base of the keyboard. Slide the keybed back making a gap of about 2cm at the front of the keybed.
Look at the back of the key towards where it pivots and you will see a small arrow, push something like a credit card between the keys at this point and the key will pop up, you can then slide forward releasing the key.
If you need more info please ask.
Jun 07, 2014 | Yamaha YDP-161 Arius Graded Hammer Piano...
How do i replace one key on Yamaha YDP161?
A YDP uses the same key type as a basic Yamaha Clavinova. As you have stripped the keyboard to reveal the keys take a look at the end where the key hinges. There will be an arrow pointing to one side. You will need to remove att the screws holding the key base (black plastic ) to the wooden base. Slide the whole keyboard back a couple of inches, push down where the arrow points between the keys, the offending key will pop up. Slide forward and jiggle out. Replace key. reassemble. If the tag on the back of the old key has snapped off remove the piece of debris that might be there before refitting.
dan@beckettsmusic.co.uk
replacement keys can be found online
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=17431
I have a Casio digital piano and some keys stopped working after my daughter finished "cleaning" the piano. I'm thinking maybe a fuse needs to be replaced?? Some keys plays and some do not. Any
Old reply so hopefully it's fixed. Dust or hair can get through the gaps and land on or near the contacts of the electronic key sensors. To be on the safe side (rather than doing a diy) take it in to the technicians. They'll have it fixed in a jiffy
Feb 25, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
How do you replace keys
Get replaceement keys from Yamaha America (musical instruments). Search Google for the phone number in California. You will need the model number and the key position that is broken and maybe the SN of your unit.
Download a service manual for instructions here: http://elektrotanya.com/yamaha_psr-e213_ypt-210_sm.pdf/download.html
When you go to this site DO NOT click on the download button but wait a minute for "Get Manual" to appear in the BOTTOM RIGHT and click on that link. You will get a PDF file of your SERVICE manual that has everything you need to understand how the keys are attached. BE VERY CAREFUL when opening the unit as there are tender ribbon cables between to two halves of the case. The manual probablly has a part number for the key in the parts list.
May 13, 2012 | Yamaha Music
How do i hook up my casio wk3700 to an interface for computers?
If you just want to record, use a cable with the proper ends to go from the stereo lineout jacks on your Casio into the soundcard line in on your computer. Use recording software such as Audacity. If you want to connect using Midi you will need an adapter such as this product:http://www.roland.com/products/en/UM-1EX/ You use it to connect the Midi In/Out jacks on your Casio to the USB port on your computer. Using midi opens up a world of possibilities. Please let me know if this helps.
Nov 28, 2009 | Casio Music
Need to replace black keys on Korg triton. Is it a major job to take the keyboard apart and replace the keys? In Bermuda there is very limited repair resources. I have replaced keys before on my old...
Typically lots of screws to remove. Be careful unplugging any ribbon cables. The cables are easily damamged by exerting force on just the edges.
Have new parts available BEFORE taking it apart for repair.
Oct 02, 2009 | Korg Music
How doI open a Yamaha P120 to fix sticky keys?
I've had the very same problem twice so far. The only solution I figured is to simpy purchase an equivalent key (contact Yamaha service in your country for this) and to replace the broken one. The reason why the key doesn't work smoothly as the other one is not dirt therefore any cleaning won't help. The key is cracked deep in the place where it's attached to its 'axis'. So you'll need to remove all the screws and unmount the cover (it needs a sideshift to open once the screws are removed), be careful with the speaker wires. However you'll need firm moves anyway. Opening is tricky and gets me surprised anytime I do it so you'll need some courage :). Replacing the key is even more tricky. You'll have to remove the broken one by pulling it horizontaly (use some force, it's broken anyway). Placing a new key you'll need to uplift the 'hammer' and then slide a new one. I'm sure you'll figure it out once you see it with your own eyes (it's really hard to decribe but not so hard to do it). Hope you'll do fine. I haven't tried glueing the crack for I doubt it would work for long. Good luck!
Jan 28, 2009 | Yamaha Full-Size Keyboard
Casio 76 Key Smartmedia Keyboard Logo
89 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
