Question about Motorola Mobility RAZR V3i Cellular Phone
Wont switch on even when charged or plugged in. Light comes on for a second when red key pushed on keypad
  • cdpo May 31, 2008
    yea mine does the samme only the keypad works and the screen wont work i switched out the battery and still cant get it to work.....
  • Anonymous May 31, 2008
    set not getting charged tried changing the charger also
    Scholar:
  • 173 Answers
Try takign otu the batery and putting it back in, if that doesnt do the trick reply back for more help
Posted on May 30, 2008
My nextbook 8 has a red flashing light and wont power on even after charging
Try taking out the battery and try turning it on with it plugged in. If it works, you need a new battery.
Jan 03, 2014 | Computers & Internet
Acer chromebook c7 wont charge
You may need to replace the battery, especially if you have had your Chromebook for awhile.
Nov 07, 2013 | Acer C710-2487 4096MB 11.6" Chromebook
My rebel t3i wont turn on!!!
I just bought a T3i and only used it 2 days of shooting. On third day, it's not turning on and it's 80 degree's. So not cold weather. Batteries are fully charged. When I put batter in and turn the switch on, the red light comes on for only a second and then nothing! Other times the red light won't even come on, period. As I said, I've only had it 3 days and it's dead....
May 06, 2013 | Canon EOS 600D Rebel T3i Digital Camera
I have a Golden GC321 When the battery charger is on there is a green light and next to it is a red light Does the red light ever go off when charging.
the gc 321 has a diagonistic sender built in, go to golden companion.com
and down load the owners manuel for it, its free and very helpful, when you 1st turn on the key , you count the times the red lite blinks an it will diagnose your problem, then you look it up in the manuel!
also go to monster.com and type in make and model, a set of keys is about $10
Mar 04, 2013 | Golden Technologies Golden CompanioN II -...
I want to change current keypad code linear LD050 model
To change the keypad code.
Step 1:
Erase the current code - On the upper right hand corner of the left hand side of the unit, you will see a "learn" button.
Press and hold the "learn" button for 12 seconds.
When you release the learn button, the red light above the button will blink 3 times and then come on bright for 15 seconds.
When the light goes out, the memory in the operator is erased.
Step 2:
Learn a new keypad code.
Press and release the "learn" button.
The red light will come on. You now have 15 seconds to complete the next task.
Go to your keypad and enter your desired code (1 to 6 digits long)
press start/stop on the keypad.
The red light will blink when the code is successfully stored.
Don't forget to re-enter all of your hand held remotes into the memory:
Press and release the learn button. When the red light comes on, press the button on the remote you wish to update.
Repeat for other remotes. By the way, If you hold the learn button down for 10 seconds, you'll have to start over and the memory will be erased.
Nov 14, 2012 | Home Security
Blackberry tablet wont power on
this happened to me, it needs charging, make sure the blackberry symbol on the lead is facing up, putting it in upside down moves the little tab inside the housing stopping you from charging properly, if it is a bit loose realign the tab with a thin nail file carefully just a touch then push the lead in symbol side up and switch on give it time it should charge..
May 04, 2012 | RIM Blackberry Playbook 7Inch Tablet...
Nokia e 71 no power even it comes keypads ineffective
someone told me their is a light sensor in the phone and the light that lights up the keys wont come on in daylight when you can read the keyboard clearly..
May 10, 2009 | Nokia E71 Smartphone
Wont switch on
Same thing happened to me and I freaked out. Sit it on the charger overnight and then try to turn it on. Basically, what happened with mine was I had completely drained the battery to the point that, even though it was charging, it didn't have enough juice in the pack to turn itself on. If this doesn't work, then try resetting (use the end of a paper clip to push the "button" next to the area where the USB plugs in. If that doesn't work, try Archos tech support.
Dec 15, 2008 | Archos 605 WiFi Digital Media Player
The rince light stays on and it wont run, you cant get to any other cycle
hi there,
sounds like you may have a stuck key on the keypad. disconnect the power and check the keys on the keypad as well as the pin connector behind the keypad that plugs into the board behind it for any dislogged or bent pins. replug all connections and plug the unit back into the wall. this should fix the problem. if the problem persists, replace the keypad. i know what you are thinking, new unit right?
Nov 06, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
While charging my O2 atom exec, the LED (Flash light) does not glow red ?
I have the same problem. What I did several time is to actually shut down the phone, remove the battery and leave it like that for several hours (3 to 4 hours). Then, I put the battery back in the phone, and it would charge again. However, due to the long time with no battery, the phone's clock would be reset to January 2007.
I found no other work around right now. However, I have to do this more and more often, almost once a week ...
Mar 21, 2008 | O2 Xda Atom Exec Smartphone
Motorola Mobility RAZR V3i Cellular Phone Logo
53 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
