Question about Zodiac Pacer Pool Cleaner
How do I stop the pool cleaner from stopping at the stairs and not moving around the pool?
  • 640 Answers
These pool cleaners should not be having problems moving around the pool. I am going to give you several things to try. Check the return line water flow and redirect it if necessary. Make sure that your hose is long enough to reach all ends of the pool. Make sure that your hose has proper balance. Check that your main drain and all suction lines are completely closed except the one you are using. Check for debris in the filter, pump basket, and the cleaner's flapper.
Posted on Oct 28, 2010
Polaris 9300 Sport Robotic Pool Cleaner stops in water after running about 10 seconds.
Check your pool cleaners filter screen in the in-line filter system and make sure that it is clear of debris. Also check the skimmer, basket, pump basket, and pool filter to make sure that they don't have anything blocking suction. A loss of suction would definitely make the cleaner stop moving. Make sure that your hoses and connections do not have leaks that could be causing air to to escape.
Oct 10, 2011 | Polaris 3900 Sport Pool Cleaner ()
InBaracuda got stuck in stair - on releasing it I found a black spot on wall and the suction rubber was soft and sticky.
You cleaner was probably overheating from being stuck on the stairs. To ensure that the pool cleaner does not get stuck on stairs, there are a few things that you can do. Utilize return flow by making sure that your return inlets are pointing downward and toward the center of the pool during cleaning. Confirm that you have proper hose length. Adjust the flow to your cleaner or adjust hose weight. Finally, you can install a wheel deflector if necessary.
Feb 27, 2011 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Overall poor performance 1. does not go to both sides of pool 2. either hangs up on stairs or after adjusting sits and spins on stair / sides 3.
If the pool cleaner does not cover the entire pool, check the hose length reaches within 6" of the farthest point of the pool. Set your thrust jet for 11:00 position. This will optimize random turning. If it is hanging on the stairs, check the pool cleaners wheel RPM. It should be between 28-32. Verify that the back-up valve is cycling.
Feb 19, 2011 | Polaris 380 In Ground Pool Cleaner
Hayward continues to get stuck on pool light and stairs, and will not break away unless done so manually. Also, It continues to rise out of the pool no matter what adjustment I put it on, thus making my...
In the automatic pool cleaner is getting stuck, make sure you have proper water flow and that the wings and shoes aren't worn. The hose could be too short and there could be a steering failure. Check your gear box and check and clean your rear screen. If the cleaner is rising out of the pool, make sure that the head is not "floating" or holding water. Remove all air from the cleaner head. Stop all the air from entering the pool thru the return line. If you see fine bubbles, give the hose a good tug. Also, readjust your return lines so that they are not interfering with your operation.
Nov 08, 2010 | Hayward Navigator Pool Cleaner
MY POOL CLEANER WILL RUN FOR A FEW MINUTES, THEN STOP. SO METIMES IF I SHAKE THE HOSE IT WILL START AGAIN. ANY ANSWERS?
Hi , most pool cleaners run by the force of the sucked up water moving gears inside the cleaner .. if yours is this way, then any blockage in the cleaner or in the hose attached would restrict the flow and keep the cleaner from moving.
Apr 30, 2010 | Zodiac Baracuda G3 Automatic In Ground...
My baracuda g4 is not moving and the head of it has a hole from getting stuck in my pool stairs. Does anybody has a solution for this problem or I'm the only one with this problem. Thank you
You will need to get your head rebuilt at a pool store. But the problem with it getting stuck in the stairs is from currents that develope in the water. So you will need to redirect the clean water returns so they aim down into the pool and away from the stairs. This should fix the root cause as it were.
Apr 25, 2010 | Zodiac Baracuda G3 Automatic In Ground...
The Hayward creepie crawlie that cleans our pool works fine until it comes to the steps - then it stops - head towards the steps - and if it does move again, it turns over. Do I need to get a rebuilding...
Make sure there is extra hose and extnsion cord to allow the pool cleaner to manuver around the entire pool floor. I don't know why the pool cleaner has problems with steps, was there a tramatic fall down a flight of steps or something.
Aug 12, 2009 | Pool & Spa
Our KK. will work great for maybe 5 minutes, but then stops. It is still chugging, but does not move. Had this problem last summer and bought a new KK. Had the pool replumbed. Have put new gasket on leaf...
There are a couple of things that will cause Kreepy to not move. Basic things to look at to resolve this issue:
1. Check the Footpad, the very bottom part of the cleaner, there should be raised sections on the clear rubber ring. There should be texturing on those sections, should feel like a soft sandpaper. If the sections are smooth, that needs to be replaced.
2. Is the Seal flat on the pool surface? If not, you may need to move the first weight about 8 to 10 inches from the Swivel Head.
3. Does the cleaner stop moving in the same area? When your system is running, can you see the water "rippling across" the top of the water from the return lines? If so, the issue may be your return lines. The cleaner follows the hose, so where the hose floats the cleaner will follow. If the return lines are not allowing the hose to move, then the cleaner will stop moving. Pentair recommends that your return lines should be angled downward at a 4 to 7 o'clock angle, all going in the same direction. This will take a day, or so, to re-direct the flow of water in the pool. However, by moving the flow of water from the top, or toward the center of pool, to a downward circular movement will allow the hose to float freely around the pool.
Jul 05, 2009 | Universal Kreepy Krauly In-Ground Pool...
Jet Vac stops moving around the pool
every pool has a dead spot where the vacume gets stuck! expesially when the vacs get a little age on them! juist keep an eye on it and work with it! or replace the vac!
May 26, 2009 | Pentair Jet - Vac Pressure Side Inground...
Zodiac Pacer Pool Cleaner Logo
206 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
