Question about Altec Lansing GT5051 Computer Speakers
How to change the fuse for the Altec Lansing GT5051 speaker
5 Suggested Answers
  • 277 Answers
SOURCE: Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Posted on Mar 21, 2006
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
SOURCE: Compaq Presario v2000 ALTEC LANSING speakers not working
There is not driver problem. I can hear sound using headphones and no yellow exclamation next to the "Sounds, Video and Game Controllers".
Posted on Sep 24, 2008
Altec Lansing GT5051, I'm hearing a humming noise from the speakers as soon as I turn them on. The humming noise is heard even if speakers are not connected to source.If I try and play music with...
Sounds like a problem in the speakers' internal power supply, maybe a faulty capacitor. Speakers need to be looked at by a technician, or replaced with a new set.
Jun 05, 2011 | Altec Lansing GT5051 Computer Speakers
Altec lansing ada885 took a dose of 240V, burned fuse in place, replaced fuse, worked for about 2 hours, now nothing
Well is the new fuse still good or out again. if its good, then you probably fried the main board on the amplifier. These computer speakers do not handel big power serge's.
Mar 12, 2011 | Altec Lansing ADA 885 Computer Speakers
My altec lansing acs45.1 can't power on what is the problem?
check fuse see in main board 250v 7500ma 2nd check any voltage is corect? and 3rd is check the 7812 regulator
Nov 26, 2010 | Altec Lansing ACS 45.1 Computer Speakers
I plugged my 110 volts Altec Lansing speakers into 220 volts :( How can I fix it? Please help me. Thank You.
Check fuse, but if there wasn't a fuse , your Altec need repaired to fix broken components in power circuits, could be the resistors, diodes or even transformer.
Jul 03, 2010 | Altec Lansing BX1020 Computer Speakers
My Altec lansing multi media ada 745 just stopped working all of a sudden. It doesn't work for all media ie. ipod, tv, computer. We can hardly hear it. I changed the fuse but it still doesn't work. Wh
unplug the power from the speakers, reseat the all the connections for the satellite speakers, ensure the power switch on both the subwoofer and the Right Front Speaker are in the ON position.
If that doesn't resolve the issue, then you are most likely going to need to replace the speakers, as the fuse is the only serviceable componet.
May 20, 2009 | Dell Computers & Internet
Altec Lansing ada745 fuse
It is written on the sub. You can also take it out or look at the spare which is taped to the power cord wall plug. I believe it's T1A 250V fuse
May 15, 2008 | Altec Lansing Multimedia Computer Speakers
Speakers Died?
No, I think you've fried only the fuse of Altec Lansing. Check at the back of the main unit (subwoofer) if there's a fuse box (should look like head of the plastic bolt). If not than turn it off, unplug it and open op the main unit and check for the fuse. It should look like this:0a68355.jpg
If the metal wire inside of it is broken than you should buy new fuse of same amperage (it should be engraved on metal part of the fuse or printed on glass tube).
Apr 21, 2008 | Altec Lansing ACS 45.1 Computer Speakers
Altec Lansing GT5051 Computer Speakers Logo
149 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
